Hi All,
Because OpenHAB brought me much fun I bought a Nest so I can experiment further
I, however, run into some weird behaviour in reading out the Nest data.
I started with installing the Nest Binding. Then I configured the nest.cfg file with the ID, Secret and Pin number from the website.
In my items file I put:
String NestHome_name “Name [%s]” {nest="<[structures(Koninginnestraat 73).name]"} // writeable as of 1.9
String NestHome_country_code “Country Code [%s]” {nest="<[structures(Koninginnestraat 73).country_code]"}
String NestHome_postal_code “Postal Code [%s]” {nest="<[structures(Koninginnestraat 73).postal_code]"}
String NestHome_time_zone “Time Zone [%s]” {nest="<[structures(Koninginnestraat 73).time_zone]"}
String NestHome_away “Home/Away [%s]” {nest="=[structures(Koninginnestraat 73).away]"}
String NestHome_structure_id “Structure Id [%s]” {nest="<[structures(Koninginnestraat 73).structure_id]"}
Switch NestHome_rhr_enrollment “Rush Hour Rewards Enrollment [%s]” {nest="<[structures(Koninginnestraat 73).rhr_enrollment]"} // as of 1.9
In my sitemap file I put:
Text item=NestHome_name Text item=NestHome_country_code Text item=NestHome_time_zone Text item=NestHome_away Text item=NestHome_structure_id Text item=NestHome_rhr_enrollment
With this I sometimes see some data on the sitemap in Basic UI. However, when I add:
String NestTStat_hvac_mode “HVAC Mode [%s]” {nest="=[thermostats(Woonkamer).hvac_mode]"}
to the items file, and
Text item=NestTStat_hvac_mode
everything seems to crash, and no data on from all nest items are shown.
What happens here? And importantly what am I doing wrong an how should I fix this?
Would really appreciate some help here:)
