Hello has anyone configured one sitemap with multiple thermostats ? I am going through the tutorial and getting information to come through correctly - meaning I have configured the connect correctly - but I am not realizing how I can divide the information between two thermostats say one called upstairs and one downstairs.
The thing I am having trouble reconciling is how does OpenHab know which device to use and what that equals so a mapping file from nest to openhab so to speak
Hope that makes sense!
Understand that thanks Rich for the reply!
I am just trying to understand where Nest.com references that … meaning Living Room must be the location of that Nest ? Right ? I just wanna make sure because I am not seeing data in my openhab and need to troubleshoot backwards so first off I wanted to make sure I was interpreting it correctly.
Am I on the right track?
Also one side question - apologies for the multiple. Have you been successful in putting in the logging to your logback.xml specific to NEST as described in the wiki?
You set the name of the Nest device when you initially configure it. It asks you to enter the location which becomes its name. When you go to Net’s website where you can remotely control the unit, the name is at the very bottom under the icon for the device:
OK so I was on track with the naming - thank yoU!
Logging I was having trouble with - I am not sure how to troubleshoot with this…
Do you remember with the log if you just put it at the end of your log file or where specifically?
Thank you Rich!
I now have logging continuing - normal logging . However looks like that bit of logging for nest no workie … But at least normal logging is continuing.
I will keep digging as to why but at least all other operations are going swimmingly
Ill attach my xml here just in case you see something my eyes wont show me …
The only thing I notice is that your newlines are different than what was already there (i.e. when I open in Notepad on Windows your additions are all on one line while everything else is on multiple lines). You might try running dos2unix on it to normalize the newlines.
Beyond that I don’t see any errors.
Make sure the openhab user has permission to create a new file in the logs directory.
I just rebooted the box its on and all started working magically, not sure what that is but Ill deal with it later
I think I am able to set temp, looks like I made too many initial requests at first - logs showing I did anyway… will let it sit and configure habmin and see later if i can still turn up heat and down
