I am trying to make a rule that is shutting down the radiator/heater, if a window is open.
The open window is detected by a window contact. The window contact is triggering a rule that is basically doing:
I get the update in the console:
[vent.ItemStateChangedEvent] - Thermo_Livingroom_SetPointMode changed from program to away
but just 1 second later:
[vent.ItemStateChangedEvent] - Thermo_Livingroom_SetPointMode changed from away to program
So the system is switiching back to the old state. How is that possible.
My first idea was that i have to set the channel SetpointEndTime, but this is read only channel.
Do I overlook something?
Thanks for the help
This is …not desired …but normal. Currently the binding caches api answer until a refresh is needed. And for the thermostat the refresh is not triggered by an update of the setpoint mode. The PR #3336 will solve this. It’s pending merge.
The channel will be updated at next API refresh by itself. So one of your options is to set Thermostat refresh rate at a higher rate. The alternative is to use a proxy item to catch the value until refresh.
