Thanks @glhopital ! I’m on OH3 and all things have been defined through the UI, that means that I can’t comment them out. Do I really need to remove all Netatmo things (Weather station IN/OUT modules, rain gauge sensor, anemometer, thermostat) before installing the .jar and then redefine them from scratch? I have already the dashboard and the entire model defined… Is this the only way?
hello @achimera. Sorry to say that yes, you must remove your existing things if you want to take benefits from the new versions. Things are completely different between these bindings. But what you can do, instead of removing your things, items is deactivate things and change item links from former thing channels to their equivalent in the new binding. This will help keep as much as possible of your existing dashboards.
