I am running OH 2.4 and want to install netatmo binding 2.5.7. As is, it does not work.
The netatmo device is an indoor module (measuring temperature, humidity, CO2, noise). I bought it recently, and if it is not working with openhab I would send it back.
I know I should update to OH3 but it is too much effort for now.
How can I install the netatmo binding needed for OH2.4?
Regards
Björn
Platform: raspberry pi 3
openhab: 2.4
binding version: 2.5.7
You might consider an alternative of upgrading your whole system from 2.4 to last OH2 release 2.5.12, where at least all correct binding versions are available.
I had to send the air quality sensor back. It does not allow to install a second additional CO2 sensor. I found out after a longer back and forth conversation with support.
A remote openhab binding seemed to be a good idea. Possibly also for a netatmo alternative CO2 sensor.
