The problem with my netatmo binding is, that it stops getting data from the api.netatmo.com after a random amount of time. If I restart the binding, it works for 30min up to 10 hours, but then it stops again. I tried the DEBUG log:level and get some output which is not really clear for me.
Every 10min the binding asks at api.netatmo.com for data. Usually it looks like this (extract from /var/log/daemon.log)
Jan 27 12:09:36 openHABianPi karaf[23580]: ---> HTTP GET https://api.netatmo.net/api/getstationsdata?device_id=70%3Aee%3A50%3A03%3A6e%3A7a
Jan 27 12:09:36 openHABianPi karaf[23580]: ---> END HTTP (no body)
Jan 27 12:09:37 openHABianPi karaf[23580]: <--- HTTP 200 https://api.netatmo.net/api/getstationsdata?device_id=70%3Aee%3A50%3A03%3A6e%3A7a (469ms)
Jan 27 12:09:37 openHABianPi karaf[23580]: Server: nginx
Jan 27 12:09:37 openHABianPi karaf[23580]: Date: Sat, 27 Jan 2018 11:09:37 GMT
Jan 27 12:09:37 openHABianPi karaf[23580]: Content-Type: application/json; charset=utf-8
Jan 27 12:09:37 openHABianPi karaf[23580]: Transfer-Encoding: chunked
Jan 27 12:09:37 openHABianPi karaf[23580]: Connection: keep-alive
Jan 27 12:09:37 openHABianPi karaf[23580]: Cache-Control: no-cache, must-revalidate
Jan 27 12:09:37 openHABianPi karaf[23580]: Expires: 0
Jan 27 12:09:37 openHABianPi karaf[23580]: X-XSS-Protection: 1; mode=block
Jan 27 12:09:37 openHABianPi karaf[23580]: Access-Control-Allow-Origin: *
Jan 27 12:09:37 openHABianPi karaf[23580]: Strict-Transport-Security: max-age=10886400; includeSubDomains
Jan 27 12:09:37 openHABianPi karaf[23580]: X-Powered-By: Netatmo
Jan 27 12:09:37 openHABianPi karaf[23580]: OkHttp-Selected-Protocol: http/1.1
Jan 27 12:09:37 openHABianPi karaf[23580]: OkHttp-Sent-Millis: 1517051377224
Jan 27 12:09:37 openHABianPi karaf[23580]: OkHttp-Received-Millis: 1517051377434
Jan 27 12:09:37 openHABianPi karaf[23580]: {"body":{"devices":[{"_id":"70:ee:50:03:6e:7a","cipher_id":"enc:16:vHjFpXEeYxEu4n8lICd4VVrU7hOLgK1NQ03BNtm7R+sGrfh38os5GboD8bMSlqul","last_status_store":1517051353,"modules":[{"_id":"02:00:00:03:76:34","type":"NAModule1","last_message":1517051349,"last_seen":1517051349,"dashboard_data":{"time_utc":1517051298,"Temperature":5.9,"temp_trend":"up","Humidity":93,"date_max_temp":1517050991,"date_min_temp":1517018490,"min_temp":3.9,"max_temp":5.9},"data_type":["Temperature","Humidity"],"module_name":"Au\u00dfen","last_setup":1404917719,"battery_vp":5296,"battery_percent":71,"rf_status":63,"firmware":44},{"_id":"05:00:00:00:4a:80","type":"NAModule3","last_message":1517051350,"last_seen":1517051350,"dashboard_data":{"time_utc":1517051337,"Rain":0,"sum_rain_24":0,"sum_rain_1":0},"data_type":["Rain"],"module_name":"Regen","last_setup":1405003549,"battery_vp":5836,"battery_percent":93,"rf_status":63,"firmware":8},{"_id":"03:00:00:01:17:80","type":"NAModule4","last_message":1517051350,"last_seen":1517051330,"dashboard_data":{"time_utc":1517051330,"Temperature":21.5,"temp_trend":"stable","Humidity":41,"CO2":658,"date_max_temp":1517011858,"date_min_temp":1517028108,"min_temp":21.1,"max_temp":21.6},"data_type":["Temperature","CO2","Humidity"],"module_name":"Wohnzimmer","last_setup":1406047102,"battery_vp":6218,"battery_percent":100,"rf_status":76,"firmware":44},{"_id":"03:00:00:01:24:44","type":"NAModule4","last_message":1517051350,"last_seen":1517051343,"dashboard_data":{"time_utc":1517051292,"Temperature":20.2,"temp_trend":"stable","Humidity":46,"CO2":655,"date_max_temp":1517014895,"date_min_temp":1517007667,"min_temp":20.2,"max_temp":20.4},"data_type":["Temperature","CO2","Humidity"],"module_name":"Patrick","last_setup":1406047423,"battery_vp":4689,"battery_percent":27,"rf_status":66,"firmware":44},{"_id":"03:00:00:01:6c:bc","type":"NAModule4","last_message":1517051350,"last_seen":1517051343,"dashboard_data":{"time_utc":1517051292,"Temperature":19.9,"temp_trend":"stable","Humidity":47,"CO2":676,"date_max_temp":1517024531,"dat
Jan 27 12:09:37 openHABianPi karaf[23580]: e_min_temp":1517007667,"min_temp":19.5,"max_temp":20.4},"data_type":["Temperature","CO2","Humidity"],"module_name":"Schlafzimmer","last_setup":1419093375,"battery_vp":5270,"battery_percent":59,"rf_status":55,"firmware":44}],"place":{"altitude":36,"city":"Hamburg","country":"DE","timezone":"Europe\/Berlin","location":[10.1343,53.66096]},"station_name":"Lindenpalais","type":"NAMain","dashboard_data":{"AbsolutePressure":1024.5,"time_utc":1517051338,"Noise":33,"Temperature":19.9,"temp_trend":"stable","Humidity":56,"Pressure":1028.8,"pressure_trend":"up","CO2":713,"date_max_temp":1517044416,"date_min_temp":1517007675,"min_temp":19.8,"max_temp":20.2},"data_type":["Temperature","CO2","Humidity","Noise","Pressure"],"co2_calibrating":false,"date_setup":1404917359,"last_setup":1404917359,"module_name":"B\u00fcro","firmware":132,"last_upgrade":1440092625,"wifi_status":69,"friend_users":["53bd8f761977591844d947c6","53d7bb6d197759f13aa1ce34"]}],"user":{"mail":"netatmo@stefandanz.de","administrative":{"country":"DE","reg_locale":"de-DE","lang":"de-DE","unit":0,"windunit":0,"pressureunit":0,"feel_like_algo":0}}},"status":"ok","time_exec":0.078970909118652,"time_server":1517051377}
Jan 27 12:09:37 openHABianPi karaf[23580]: <--- END HTTP (3232-byte body)
but after an unknown amount of tries, it comes up with this:
Jan 27 12:19:42 openHABianPi karaf[23580]: ---> HTTP GET https://api.netatmo.net/api/getstationsdata?device_id=70%3Aee%3A50%3A03%3A6e%3A7a
Jan 27 12:19:42 openHABianPi karaf[23580]: ---> END HTTP (no body)
Jan 27 12:19:42 openHABianPi karaf[23580]: ---- ERROR https://api.netatmo.net/api/getstationsdata?device_id=70%3Aee%3A50%3A03%3A6e%3A7a
Jan 27 12:19:42 openHABianPi karaf[23580]: java.net.UnknownHostException: api.netatmo.net: Temporärer Fehler bei der Namensauflösung
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at java.net.Inet6AddressImpl.lookupAllHostAddr(Native Method)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at java.net.InetAddress$2.lookupAllHostAddr(InetAddress.java:928)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at java.net.InetAddress.getAddressesFromNameService(InetAddress.java:1323)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at java.net.InetAddress.getAllByName0(InetAddress.java:1276)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at java.net.InetAddress.getAllByName(InetAddress.java:1192)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at java.net.InetAddress.getAllByName(InetAddress.java:1126)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at com.squareup.okhttp.internal.Network$1.resolveInetAddresses(Network.java:29)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at com.squareup.okhttp.internal.http.RouteSelector.resetNextInetSocketAddress(RouteSelector.java:224)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at com.squareup.okhttp.internal.http.RouteSelector.nextProxy(RouteSelector.java:193)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at com.squareup.okhttp.internal.http.RouteSelector.next(RouteSelector.java:113)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at com.squareup.okhttp.internal.http.HttpEngine.createNextConnection(HttpEngine.java:344)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at com.squareup.okhttp.internal.http.HttpEngine.nextConnection(HttpEngine.java:329)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at com.squareup.okhttp.internal.http.HttpEngine.connect(HttpEngine.java:319)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at com.squareup.okhttp.internal.http.HttpEngine.sendRequest(HttpEngine.java:241)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at com.squareup.okhttp.Call.getResponse(Call.java:271)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at com.squareup.okhttp.Call$ApplicationInterceptorChain.proceed(Call.java:228)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at io.swagger.client.auth.OAuth.intercept(OAuth.java:108)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at com.squareup.okhttp.Call$ApplicationInterceptorChain.proceed(Call.java:225)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at com.squareup.okhttp.Call.getResponseWithInterceptorChain(Call.java:199)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at com.squareup.okhttp.Call.execute(Call.java:79)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at retrofit.client.OkClient.execute(OkClient.java:53)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at retrofit.RestAdapter$RestHandler.invokeRequest(RestAdapter.java:326)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at retrofit.RestAdapter$RestHandler.invoke(RestAdapter.java:240)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at com.sun.proxy.$Proxy171.getstationsdata(Unknown Source)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at org.openhab.binding.netatmo.handler.NetatmoBridgeHandler.getStationsDataBody(NetatmoBridgeHandler.java:233)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at org.openhab.binding.netatmo.internal.station.NAMainHandler.updateReadings(NAMainHandler.java:42)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at org.openhab.binding.netatmo.internal.station.NAMainHandler.updateReadings(NAMainHandler.java:1)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at org.openhab.binding.netatmo.handler.NetatmoDeviceHandler.updateChannels(NetatmoDeviceHandler.java:108)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at org.openhab.binding.netatmo.handler.NetatmoDeviceHandler.lambda$0(NetatmoDeviceHandler.java:82)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at java.util.concurrent.FutureTask.run(FutureTask.java:266)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
Jan 27 12:19:42 openHABianPi karaf[23580]: #011at java.lang.Thread.run(Thread.java:748)
Jan 27 12:19:42 openHABianPi karaf[23580]: ---- END ERROR
almost an hour later:
Jan 27 13:11:10 openHABianPi karaf[23580]: ---> HTTP GET https://api.netatmo.net/api/partnerdevices
Jan 27 13:11:10 openHABianPi karaf[23580]: ---> END HTTP (no body)
Jan 27 13:11:14 openHABianPi karaf[23580]: <--- HTTP 404 https://api.netatmo.net/api/partnerdevices (3827ms)
Jan 27 13:11:14 openHABianPi karaf[23580]: Server: nginx
Jan 27 13:11:14 openHABianPi karaf[23580]: Date: Sat, 27 Jan 2018 12:11:14 GMT
Jan 27 13:11:14 openHABianPi karaf[23580]: Content-Type: application/json; charset=utf-8
Jan 27 13:11:14 openHABianPi karaf[23580]: Transfer-Encoding: chunked
Jan 27 13:11:14 openHABianPi karaf[23580]: Connection: keep-alive
Jan 27 13:11:14 openHABianPi karaf[23580]: Cache-Control: no-cache, must-revalidate
Jan 27 13:11:14 openHABianPi karaf[23580]: Expires: 0
Jan 27 13:11:14 openHABianPi karaf[23580]: X-XSS-Protection: 1; mode=block
Jan 27 13:11:14 openHABianPi karaf[23580]: Access-Control-Allow-Origin: *
Jan 27 13:11:14 openHABianPi karaf[23580]: Strict-Transport-Security: max-age=10886400; includeSubDomains
Jan 27 13:11:14 openHABianPi karaf[23580]: X-Powered-By: Netatmo
Jan 27 13:11:14 openHABianPi karaf[23580]: OkHttp-Selected-Protocol: http/1.1
Jan 27 13:11:14 openHABianPi karaf[23580]: OkHttp-Sent-Millis: 1517055074260
Jan 27 13:11:14 openHABianPi karaf[23580]: OkHttp-Received-Millis: 1517055074433
Jan 27 13:11:14 openHABianPi karaf[23580]: {"error":{"code":31,"message":"No devices."}}
Jan 27 13:11:14 openHABianPi karaf[23580]: <--- END HTTP (45-byte body)
and this is the last output from the binding. it does not try again. So I need to restart the binding to get answers again. But anyway: it will stop again. This is now the case for at least a week, when I switched to openhabian 1.4. So I guess, it is some kind of network/dns issue…entries in /etc/hosts ?
I am using a fritz.box to connect to the internet…
Any help appreciated
