I must say that the Netatmo 2.2.0 binding is simply not working for me. I have the weather station with an external module and the welcome camera.
The Paper UI usually manage to discover all the things and I can usually see them in the Paper UI - for a few minutes.
Within minutes (the record so far has been 2 hours) the binding bombs spectacularly with a flood of error messages in the log and it stops updating.
2018-04-12 13:22:43.085 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'Shazar1.sitemap'
2018-04-12 13:23:02.113 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2018-04-12 13:23:08.300 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2018-04-12 13:23:23.303 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content: java.net.SocketTimeoutException: Connect Timeout
2018-04-12 13:23:38.977 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2018-04-12 13:23:46.743 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content due to a timeout
2018-04-12 13:23:50.751 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content: java.net.SocketTimeoutException: Connect Timeout
2018-04-12 13:23:52.510 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content: java.net.ConnectException: Connection refused: no further information
2018-04-12 13:24:01.757 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content: java.net.SocketTimeoutException: Connect Timeout
2018-04-12 13:24:01.760 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content: java.net.SocketTimeoutException: Connect Timeout
2018-04-12 13:24:09.058 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
org.glassfish.jersey.server.internal.process.MappableException: org.eclipse.jetty.io.EofException
at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:92) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1130) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:711) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:444) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:434) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:329) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [85:org.eclipse.jetty.security:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at java.lang.Thread.run(Unknown Source) [?:?]
Caused by: org.eclipse.jetty.io.EofException
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:199) ~[79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:420) ~[79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.WriteFlusher.completeWrite(WriteFlusher.java:375) ~[79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.SelectChannelEndPoint$3.run(SelectChannelEndPoint.java:107) ~[79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.SelectChannelEndPoint.onSelected(SelectChannelEndPoint.java:193) ~[79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.ManagedSelector$SelectorProducer.processSelected(ManagedSelector.java:283) ~[79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.ManagedSelector$SelectorProducer.produce(ManagedSelector.java:181) ~[79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:249) ~[90:org.eclipse.jetty.util:9.3.22.v20171030]
... 5 more
Caused by: java.io.IOException: An established connection was aborted by the software in your host machine
at sun.nio.ch.SocketDispatcher.writev0(Native Method) ~[?:?]
at sun.nio.ch.SocketDispatcher.writev(Unknown Source) ~[?:?]
at sun.nio.ch.IOUtil.write(Unknown Source) ~[?:?]
at sun.nio.ch.SocketChannelImpl.write(Unknown Source) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:179) ~[79:org.eclipse.jetty.io:9.3.22.v20171030]
... 5 more
2018-04-12 13:24:16.768 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content: java.net.SocketTimeoutException: Connect Timeout
2018-04-12 13:24:30.057 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content: java.net.SocketTimeoutException: Connect Timeout
2018-04-12 13:24:30.058 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content: java.net.SocketTimeoutException: Connect Timeout
2018-04-12 13:24:34.842 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content: java.net.SocketTimeoutException: Connect Timeout
2018-04-12 13:24:52.477 [WARN ] [.internal.proxy.BlockingProxyServlet] - Proxy servlet failed to stream content: java.net.SocketTimeoutException: Connect Timeout
2018-04-12 13:25:09.263 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
... 5 more
... 5 more
2018-04-12 13:25:31.931 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
... 5 more
... 5 more
Restarting the OH server doesn’t help. The Netatmo API remains stuck in the “Initializing” stage and any interaction with the Paper UI thing will cause a renewal of the error flood.
I uninstalled and reinstalled the Netamo binding 4 times and each time observed the same fragility with the binding crashing almost immediately. I’m at the stage where I’m willing to give up with Netamo and OH.
