Hi guys,
I’m using openhab 2.5.10-1 with netatmo binding also 2.5.
I’m running into an issue that, when I change anything it’s being applied, but on the sitemap it goes back to the initial value. Example:
- I change from “program” to “off”
- The thermostat goes off
- In my basucui I see it returning to “program” (although in reality stays as off)
In the logs i’m unable to see anything:
2020-11-07 01:15:31.777 [ome.event.ItemCommandEvent] - Item ‘Termostato_SetpointMode’ received command off
2020-11-07 01:15:31.836 [nt.ItemStatePredictedEvent] - Termostato_SetpointMode predicted to become off
2020-11-07 01:15:31.840 [thome.event.ItemStateEvent] - Termostato_SetpointMode updated to off
2020-11-07 01:15:31.882 [vent.ItemStateChangedEvent] - Termostato_SetpointMode changed from program to off
2020-11-07 01:15:34.487 [event.ThingStatusInfoEvent] - ‘netatmo:netatmoapi:c758a303’ updated: ONLINE
2020-11-07 01:15:34.495 [event.ThingStatusInfoEvent] - ‘netatmo:NAPlug:c758ca03:70ee500be9e2’ updated: ONLINE
2020-11-07 01:15:34.509 [event.ThingStatusInfoEvent] - ‘netatmo:NATherm1:c758c303:040000ac897a’ updated: ONLINE
2020-11-07 01:15:34.516 [thome.event.ItemStateEvent] - Termostato_Temperature updated to 22.200000762939453125
2020-11-07 01:15:34.530 [thome.event.ItemStateEvent] - Termostato_Setpoint updated to 18.00
2020-11-07 01:15:34.545 [thome.event.ItemStateEvent] - Termostato_SetpointMode updated to program
2020-11-07 01:15:34.556 [thome.event.ItemStateEvent] - Nivel_Bateria updated to 45.00
2020-11-07 01:15:34.566 [vent.ItemStateChangedEvent] - Termostato_SetpointMode changed from off to program
Any ideas?
Thanks in advance!
