Netatmo - types and measurements lists are different sizes
Hello, who can explain to me what this error means and how I can fix it. I have no idea where to look.
I am using OH3 (latest snapshot). If you need more details ask me.
[WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.IllegalArgumentException: types and measurements lists are different sizes.
	at org.openhab.binding.netatmo.internal.handler.AbstractNetatmoThingHandler.getMeasurements(AbstractNetatmoThingHandler.java:249) ~[?:?]
	at org.openhab.binding.netatmo.internal.station.NAModule4Handler.updateDayMeasurements(NAModule4Handler.java:74) ~[?:?]
	at org.openhab.binding.netatmo.internal.station.NAModule4Handler.updateMeasurements(NAModule4Handler.java:57) ~[?:?]
	at org.openhab.binding.netatmo.internal.station.NAMainHandler.lambda$7(NAMainHandler.java:65) ~[?:?]
	at java.util.Optional.ifPresent(Optional.java:183) ~[?:?]
	at org.openhab.binding.netatmo.internal.station.NAMainHandler.lambda$5(NAMainHandler.java:64) ~[?:?]
	at java.util.concurrent.ConcurrentHashMap$KeySetView.forEach(ConcurrentHashMap.java:4698) ~[?:?]
	at org.openhab.binding.netatmo.internal.station.NAMainHandler.updateReadings(NAMainHandler.java:63) ~[?:?]
	at org.openhab.binding.netatmo.internal.handler.NetatmoDeviceHandler.updateChannels(NetatmoDeviceHandler.java:127) ~[?:?]
	at org.openhab.binding.netatmo.internal.handler.NetatmoDeviceHandler.updateChannels(NetatmoDeviceHandler.java:110) ~[?:?]
	at org.openhab.binding.netatmo.internal.handler.NetatmoModuleHandler.requestParentRefresh(NetatmoModuleHandler.java:120) ~[?:?]
	at org.openhab.binding.netatmo.internal.handler.NetatmoModuleHandler.lambda$0(NetatmoModuleHandler.java:55) ~[?:?]
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
with kind regards
It would mean one of the measures for your additional indoor module is no more provided by the API. This concerns the channels min/max for the current day (and theiir corresponding dates). For this module, you have min/max humidity and min/max CO2. Total of 8 channels with the dates.
Can you tell us what of these channels you linked ?
Can you unlink these channels one by one to identify which one is triggering the problem ?
Same error here.
Difficult to say which Property is involved (by the way : it could probably be displayed when the problem is happening by the binding itself).
2022-05-01 21:22:17.527 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'netatmo.items'
...skipping...
        at org.openhab.binding.netatmo.internal.station.NAModule1Handler.updateDayMeasurements(NAModule1Handler.java:70) ~[?:?]
        at org.openhab.binding.netatmo.internal.station.NAModule1Handler.updateMeasurements(NAModule1Handler.java:57) ~[?:?]
        at org.openhab.binding.netatmo.internal.handler.NetatmoDeviceHandler.lambda$0(NetatmoDeviceHandler.java:83) ~[?:?]
Could be :
Number:Length           NetatmoCapteurPLUIERain                                  "Précipitations"                     <rain>           (gDevice_NetatmoModulePluie)               ["Measurment", "Rain"]           {channel="netatmo:NAModule3:home:050000xxxxxx:Rain"}
Number:Length           NetatmoCapteurPLUIESumRain1                              "Précipitations 1h"                  <rain>           (gDevice_NetatmoModulePluie)               ["Measurment", "Rain"]           {channel="netatmo:NAModule3:home:050000xxxxxx:SumRain1"}
Number:Length           NetatmoCapteurPLUIESumRain24                             "Précipitations 24h"                 <rain>           (gDevice_NetatmoModulePluie)               ["Measurment", "Rain"]           {channel="netatmo:NAModule3:home:050000xxxxxx:SumRain24"}
Number:Length           NetatmoCapteurPLUIESumRainThisWeek                       "Rain this week"                     <rain>           (gDevice_NetatmoModulePluie)               ["Measurment", "Rain"]           {channel="netatmo:NAModule3:home:050000xxxxxx:SumRainThisWeek"}
Number:Length           NetatmoCapteurPLUIESumRainThisMonth                      "Rain this month"                    <rain>           (gDevice_NetatmoModulePluie)               ["Measurment", "Rain"]           {channel="netatmo:NAModule3:home:050000xxxxxx:SumRainThisMonth"}
Things :
Thing NAMain 70ee50xxxxxx "Netatmo / Station météo intérieure" @ "Salon" [ id="70:ee:50:xx:xx:xx" ]
Thing NAModule1 020000xxxxxx "Netatmo / Module TEMPERATURE" @ "Balcon" [ id="02:00:00:xx:xx:xx", parentId="70:ee:50:xx:xx:xx" ]
Thing NAModule2 060000xxxxxx "Netatmo / Capteur VENT" @ "Balcon" [ id="06:00:00:xx:xx:xx", parentId="70:ee:50:xx:xx:xx" ]
Thing NAModule3 050000xxxxxx "Netatmo / Capteur PLUIE" @ "Balcon" [ id="05:00:00:xx:xx:xx", parentId="70:ee:50:xx:xx:xx" ]
Running OpenHAB3.3.0-SNAPSHOT from docker container (pulled a couple of days ago, end of april).
