Hi
on my Openhab 4.2.0 the netatmo binding delivers the channel “live#picture” for my Presence cameras (outdoor) as expected. However my Welcome camera (indoor) remains NULL
If this helps, the last-event#snapshot is also NULL for all cameras.
Any thoughts? Is this an error in my config? A binding issue?
Perhaps I have a misconception? Is there any kind of documentation I can read? More than the binding documentation.
I would expect the “Live Monitoring” channels to be filled all the time when the APP (Home + Control & Security | Legrand - Netatmo - Bticino) also shows that live content is available.
And the same with “Last Event” channels. They should be all filled with data for the last event and replaced as soon as there is a new (last) event.
But my Welcome Live never gets filled and the “Last Event” snapshots get filled but go back to NULL aber some time.
I have a similar issue. I am using a Netatmo Presence together with the Netatmo Binding. So far, it works in general. When there is a new event, the “:last-event#typ” and “:last-event#time” channels both get updated. Also the url “:last-event#local-video-url” gets updated, however this is updated to null.
Once that happened, no further update appears. Waiting or a restart of openhanded also does not help. However, when I uninstall the add-on and reinstall it again, the value is correctly loaded. The bug is fully reproducible. Nothing special in the logs:
2025-05-20 23:21:45.653 [DEBUG] [mo.internal.handler.ApiBridgeHandler] - executeUri GET https://api.netatmo.com/api/getevents?home_id=XXXXXXXX
2025-05-20 23:21:45.771 [DEBUG] [l.handler.capability.CacheCapability] - HomeCapability requesting fresh data for netatmo:home:XXXXXXXX:netatmo_home
2025-05-20 23:21:45.771 [DEBUG] [mo.internal.handler.ApiBridgeHandler] - executeUri GET https://api.netatmo.com/api/homesdata?home_id=XXXXXXXX
2025-05-20 23:21:45.834 [DEBUG] [mo.internal.handler.ApiBridgeHandler] - executeUri GET https://api.netatmo.com/api/homestatus?home_id=XXXXXXXX
2025-05-20 23:21:46.016 [DEBUG] [handler.capability.RefreshCapability] - 'netatmo:home:XXXXXXXXXX:netatmo_home' next refresh in PT2M30S
Could that have the same reason and did you, @Thomas_Hartung, find a final solution?
As you can see, I use a motion sensor to change visibility of the netatmo. And of course the refresh doesn’t make total sense. But like this I get the latest snapshot from the camera.
