Completely new to this.
I have setup the Netatmo bridge and main indoor station. The problem is while it says it is online I am not getting any reading when looking at it in the Basic UI.
Any ideas please.
Thanks,
Andrew.
Any ideas please.
Thanks,
Andrew.
The problem can either be that BasicUI is not updating or that the Item is not updating or that the binding itself is not configured correctly.
Are you getting any log statements in events.log indicating the Item is updated?
Are you seeing any errors in the logs from this binding?
Firstly thank you coming back to me.
Below is the only ref I can find in events.log.
2017-01-26 21:38:31.452 [hingStatusInfoChangedEvent] - ‘netatmo:NAMain:102ebf74’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2017-01-26 21:38:31.546 [hingStatusInfoChangedEvent] - ‘netatmo:netatmoapi:a80e8847’ changed from UNINITIALIZED to INITIALIZING
2017-01-26 21:38:38.140 [hingStatusInfoChangedEvent] - ‘netatmo:netatmoapi:a80e8847’ changed from INITIALIZING to ONLINE
2017-01-26 21:38:38.187 [hingStatusInfoChangedEvent] - ‘netatmo:NAMain:102ebf74’ changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2017-01-26 21:38:38.187 [hingStatusInfoChangedEvent] - ‘netatmo:NAMain:102ebf74’ changed from INITIALIZING to ONLINE
Do you have an Item bound to and netatmo:NAMain:102ebf74 channels? What are those Items. How are you putting this on your sitemap?
