I’m trying for several times now to get the network binding with arpping working. Unfortunately we have an iPhone which is virtually every 20 minutes offline without that arpping.
However I can’t get the arpping working.
Here’s my setup:
Raspberry PI
Running openhab via docker, using the official docker image (meanwhile added apt-get install ping)
Version 2 bindings do not use a .cfg file. In PaperUI > Configuration > System enable legacy bindings, and install version 1 of network binding. See if that will work with the configuration you have.
I don’t think that’s right. The binding respects the .cfg file. Tried it with just turning everything off via network.cfg, and got different settings in paperUI:
I think more that it’s something to do with docker.
