Java Runtime Environment: which java platform is used and what version
openHAB version:
Issue of the topic: please be detailed explaining your issue
Please post configurations (if applicable):
Items configuration related to the issue
Sitemap configuration related to the issue
Rules code related to the issue
Services configuration related to the issue
If logs where generated please post these here using code fences:
Platform - Synology DS 1517+
CPU/RAM - INTEL At GHz/ CPU cores 4/ RAM 16GB
OS - DSM 6.2.1-23824 update 4
JAVA - 1.8.0_201
openHAB - 2.4.0.000
Following the instructions on how to setup openHAB. Set to install Network Binding and the circle just spins. It never gets installed.
My Synology NAS is using a 10 GB network card. Could this be the issue?
I reload the page and it shows as uninstalled. The right column says Install. I click it and it starts spinning again.
I looked at the log and found this error several times at the end of the log (probably listed the same number of times I tried to install Network Binding).
2019-02-20 15:51:25.116 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-binding-network’: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-binding-network; type=karaf.feature; version="[2.4.0,2.4.0]"; filter:="(&(osgi.identity=openhab-binding-network)(type=karaf.feature)(version>=2.4.0)(version<=2.4.0))" [caused by: Unable to resolve openhab-binding-network/2.4.0: missing requirement [openhab-binding-network/2.4.0] osgi.identity; osgi.identity=org.openhab.binding.network; type=osgi.bundle; version="[2.4.0,2.4.0]"; resolution:=mandatory [caused by: Unable to resolve org.openhab.binding.network/2.4.0: missing requirement [org.openhab.binding.network/2.4.0] osgi.wiring.package; filter:="(osgi.wiring.package=org.apache.commons.net.util)"]]
