I get an error “Cache expiry time must be greater than 0”
Hello.
The THING-Syntax is change.
old: Thing network:device:XXXXXX [ hostname=“XXX.XXX.XXX.XXX”,port=0, retry=1, timeout=2000, refresh_interval=5000, use_system_ping=“false”, dhcplisten=“false”]
new: Thing network:pingdevice:XXXXXX [ hostname=“XXX.XXX.XXX.XXX”]
Bad the new Binding has no funktion.
I’ve added the thing via the PaperUI
"network:pingdevice:10_10_10_10": {
"class": "org.eclipse.smarthome.core.thing.internal.ThingImpl",
"value": {
"label": "Galaxy S",
"channels": [
"acceptedItemType": "Switch",
"kind": "STATE",
"uid": {
"segments": [
"network",
"pingdevice",
"10_10_10_10",
"online"
"channelTypeUID": {
"segments": [
"network",
"online"
"label": "Online",
"description": "Gibt an ob das Gerät aktuell online oder offline ist.",
"configuration": {
"properties": {}
"properties": {},
"defaultTags": []
"acceptedItemType": "Number",
"kind": "STATE",
"uid": {
"segments": [
"network",
"pingdevice",
"10_10_10_10",
"latency"
"channelTypeUID": {
"segments": [
"network",
"latency"
"label": "Pingzeit",
"description": "Gibt an wie lange ein Ping in Millisekunden an das Gerät dauert.",
"configuration": {
"properties": {}
"properties": {},
"defaultTags": []
"acceptedItemType": "DateTime",
"kind": "STATE",
"uid": {
"segments": [
"network",
"pingdevice",
"10_10_10_10",
"lastseen"
"channelTypeUID": {
"segments": [
"network",
"lastseen"
"label": "Zuletzt gesehen",
"description": "Gibt Zeit/Datum an wann das Gerät zuletzt gesehen wurde.",
"configuration": {
"properties": {}
"properties": {},
"defaultTags": []
"configuration": {
"properties": {
"hostname": "10.10.10.10",
"refresh_interval": 60000,
"retry": 1,
"timeout": 5000
"properties": {
"uses_dhcp_listen": "no",
"presence_detection_type": "",
"uses_ios_wakeup": "no",
"uses_arp_pings": "no"
"uid": {
"segments": [
"network",
"pingdevice",
"10_10_10_10"
"thingTypeUID": {
"segments": [
"network",
"pingdevice"
/etc/openhab2/services/binding.cfg
binding.network:cacheDeviceStateTimeInMS=2000
binding.network:arpPingToolPath=arping
and hi works?
No, since I have not changed anything yet.
I just wanted to tell you that I did not configure the things and items manually, but via the PaperUI
Note, you need to be on a very recent SNAPSHOT for those changes to be in effect.
And it isn’t that the binding has lost functions. Some of the functions have moved to a binding config file rather than needing to be part of the Thing definition.
I almost always use the latest snapshot version
Same issue here…
Hello @mAr86sEb05,
next time I’d recommend to describe your error better, give your openHAB and binding version, maybe add the right tags or mentionings.
Anyhow, I had the same issue and posted it here: iPhone Presence Detection with hping3 and ARP
Seems like a solution is on its way.
since the last update it works again.
thanks
