Sorry, but I didn’t find a similar case in the community and I have got a simple question
Why does the openHab indicator for my Windows 10 Notebook shows “offline”?
I have got 3 things and 2 of them are working properly (for the router and the printer).
If I send a ping from another device to the Windows 10 Notebook I will get a response.
as far as I remember the network binding uses different methods to detect if a device is online.
Thus even in case the device is reachable via pings it could mean that an other method is used to detect if the device is online and that method might not work.
This is why I think the question about the firewall still might be valid.
In my environment I am using
use_system_ping="true", dhcplisten="true"
in my thing definition.
An other possible cause could be that the hostname that is part of the thing definition is misspelled or DNS does not work with this hostname ( sorry, I do not know if you used IP or hostname in your test to ping the windows machine ).
