Hi there,
I have installed openHAB2 on a RPi3 the other day and I want to read data from my Novelan Heatpump.
I installed the Novelan/Luxtronic binding via PaperUI but it cannot connect to the heatpump due to a network error:
Ping is working, also from RPI3, Novelan firmware version is v 1.60, also the NovelanApp works.
Configuration should be fine?
# IP address of the Novelan (Siemens) Heatpump to connect to (required)
ip=192.168.7.4
# port number of the Novelan (Siemens) Heatpump to connect to (optional, defaults to 8888)
#port=
# refresh interval in milliseconds (optional, defaults to 60000)
#refresh=
In the log I find:
2018-03-28 17:42:50.201 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.7.11:8080
2018-03-28 17:42:50.253 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.7.11:8443
2018-03-28 17:42:57.483 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘NovelanWP.items’
2018-03-28 17:42:58.161 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘influxdb.persist’
2018-03-28 17:43:00.930 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-03-28 17:43:06.206 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-03-28 17:43:06.872 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2018-03-28 17:43:06.961 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-03-28 17:43:07.119 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2018-03-28 17:43:07.262 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-03-28 17:43:07.409 [INFO ] [b.core.service.AbstractActiveService] - Heatpump Refresh Service has been started
2018-03-28 17:43:07.457 [WARN ] [lanheatpump.internal.HeatPumpBinding] - couldn’t establish network connection [host ‘192.168.7.4’]
Let me know if you need more info, I am a newbee and no programmer.
I am also running successfully Grafana and influxDB on the RPi3 for a couple of months now, this should not be an issue? I have restarted the openhab2.service several times but the error keeps coming back.
Would be great if someone has an idea what I am doing wrong or how I can get more info about that error?
so here is what i have done so far.
I conencted via telnet to the heatpump and checked with netstat if there is something I can make sense of, i could not
After that I forced the heatpump control unit to reboot and I rebooted the RPi3, no change, still the same network error.
I asked Novelan support for help and they recommended me to update my heatpump firmware to the latest version (v1.8.1). So I did. In case you try to do the same, safe yourself some time and format your USB-Stick with FAT16 before…
So, now the network connect error in the log is gone, on top of that I can now also access the the heatpump via browser, that was not possible before
However there are intersting new line items to be found, that I can make no sense of:
2018-04-08 12:59:29.197 [INFO ] [lanheatpump.internal.HeatPumpBinding] - found new value for reverse engineering !!!! No idea what the heatpump will do in state 4.
2018-04-08 12:59:29.201 [INFO ] [lanheatpump.internal.HeatPumpBinding] - found new value for reverse engineering !!!! No idea what the heatpump will do in state 15.
Anybody an idea how I can stop these entries? They seem to be not critical, but they are written every minute and I am afraid they will eat up my diskspace…
Now I can continue my journey to transfer the heatpump data into my influxdb and visualize with Grafana
