I’m still not able to get a fresh 2.5 dev environment for Eclipse.
I followed https://www.openhab.org/docs/developer/
without success. When Eclipse starts it takes a moment and then the startup scripts ends with an error:
After IDE has installed everything, remember to close all binding projects except the ones you need.
So reduce the time and there will probably be some mistakes
ok, I used a little trick: created a new binding with the script and then copied the code from my old code dir into the new one
checked it in and done
need to re-test=WIP
