I don’t know. Did it import your metadata? I know it was refined in the past, and not born whole and perfect.
Let’s also point out that your Item import carried with it an Item typing issue - the OH3 binding wants you to use Number:xxx quantity types, not plain Number. (This would apply to many other bindings too). This isn’t something the tool could fix, it is a trap that relies on users reading release notes.
Maybe the import tool fails to set up default unit when a plain Number does not need a default unit.
I must admit I didn’t read them carefully. I’m glad I finally came around to moving over to new openHAB 3 stuff at all after years of OH2. It’s quite the learning curve, I must say.
Heck nobody does that - there was a lot else going on I’m sure.
It’s an opportunity to review all your Items associated with this binding at least. Getting the detail right affects stuff you chart, not just UI displays.
