Hi All,
I’ve started working on a binding to support Emerald Heat Pumps which are quite popular here in Australia. There is a python library that supports these - emerald_hws_py/src/emerald_hws/emeraldhws.py at main · ross-w/emerald_hws_py · GitHub
I’ve been reviewing this code to give me ideas on how to implement support for OpenHAB.
So far, I have a bridge Thing which can authenticate against Emerald’s servers, and retrieve a list of devices. Interestingly, this json also gives me a bunch of data on the heat pump - but is seemingly read-only.
The python code connects to amazon aws iot - see emerald_hws_py/src/emerald_hws/emeraldhws.py at main · ross-w/emerald_hws_py · GitHub and seems to authenticate using cognito and some library boto3.
Has anyone else tried connecting to this using a binding on openhab? Can I use the AWS SDK from an openhab binding?
I’m also still trying to wrap my head around how a bridge & binding talk to each other, and what I need to do to translate my list of detected HWS into a notification, but I’ll work it out ![]()
TIA,
Paul
