Hi @volfan6415!
First of all, I too congrats to you.
the next, To be something to report. It would be great to say: not much to report, but I have some question and would go through step by step.
1; MediaType item:
I tried out with movie, serie, music and other video as extras (it doesn’t show anything by trailers). Item reports back as movie, episode, audio and video in this order. I don’t have any other type of content in my collection. So far so good, but not at 100%. The reason why I say that is the “MediaType” item doesn’t change back its status after a movie or episode finished. Just stayed so and keeps the value what quered by the start of playing. Same with item “Duration” too. My solution is, to update the item when Item “ShowTitle” changed back to ON. Something like this:
rule "Update Mediatype Item"
Item LivingRoom1_9083_ShowTitle changed to UNDEF
LivingRoom1_9083_MediaType.postUpdate(UNDEF)
I don’t know why but that item works as it should and after a stop, it just return to state UNDEF. So i just use it to trigger the postUpdate command and put the “MediaType” item in the right state. Maybe, is there a way to change it?
2; Do I need my server as an Emby device or not?
List of things on Paper UI:
- Server as device
- Server as controller
- My mediaplayer as device (Emby Android TV App running on Himedia Q5 Pro)
I ask that, because I see many logentry where the 1st deviceid does not equal to 3rd deviceid.
Example:
adding new emby device
Disovered device binhex-arch-emby1 with id b31e0e5798b148c1be61bfb971d50294
Checking to see if handler is null
b31e0e5798b148c1be61bfb971d50294 does not equal 252f96534265e60 the event is for device named: binhex-arch-emby1
the deviceId for: binhex-arch-emby1 matches the deviceId of the thing so we will update stringUrl
Received event from EMBY server passing it to the bridge handler with hostname ip and port
Received event from emby server
I’m getting the same entry in logs, even if that thing has been removed.
Is it normal? Should it be so? Should I remove the 1st device from Paper UI or just let it there?
3; Reliability
A few times a day, and I mean, maybe 1 or 2 times, the binding closing connection due to “Unhandled Error”. But few seconds later come back online and everything is normal. It used to happen during the day too when I’m not home. Happened time to time with your setup too?
But out of this 3 point, i didn’t find any glitch how the binding operates. These aren’t painfull mistakes. I guess, its good news to you.
Keepin up with the great work!
