Well, not much success …
First, both channels from the eufyBridge PushConnected and CloudConnected stay NULL
A few error like this
CameraEntree: Unable to send update for property (wifiSignalLevel:)Integer to 4: channel not found
But, after the StartListening that worked, almost nothing is updated. The polling seems to work
2022-03-22 17:12:06.552 [DEBUG] [y.internal.EufyContainerSocketClient] - Sending {“messageId”:“2”,“command”:“driver.poll_refresh”}
2022-03-22 17:12:07.224 [DEBUG] [y.internal.EufyContainerSocketClient] - Received message: {“type”:“result”,“success”:true,“messageId”:“2”,“result”:null}
But it only updates the pictureUrl property of the first camera.
And If change the mode to Away, or a At Home, nothing is pushed to openhab.
Here’s the full debug log
2022-03-22 17:04:06.550 [DEBUG] [y.internal.EufyContainerSocketClient] - Session connected for org.openhab.binding.eufy.internal.EufyContainerSocketClient@f7e478
2022-03-22 17:04:06.551 [DEBUG] [y.internal.EufyContainerSocketClient] - Started scheduler
2022-03-22 17:04:06.561 [DEBUG] [y.internal.EufyContainerSocketClient] - Received message: {"type":"version","driverVersion":"1.6.6","serverVersion":"0.8.4","minSchemaVersion":0,"maxSchemaVersion":9}
2022-03-22 17:04:06.565 [DEBUG] [y.internal.EufyContainerSocketClient] - Preferred schema version is 8, max available is 9, requesting 8
2022-03-22 17:04:06.566 [DEBUG] [y.internal.EufyContainerSocketClient] - Sending {"version":8,"messageId":"0","command":"set_api_schema"}
2022-03-22 17:04:06.570 [DEBUG] [y.internal.EufyContainerSocketClient] - Received message: {"type":"result","success":true,"messageId":"0","result":null}
2022-03-22 17:04:06.577 [DEBUG] [y.internal.EufyContainerSocketClient] - Sending {"messageId":"1","command":"start_listening"}
2022-03-22 17:04:06.583 [DEBUG] [y.internal.EufyContainerSocketClient] - Received message: {"type":"result","success":true,"messageId":"1","result":{"state":{"driver":{"version":"1.6.6","connected":true,"pushConnected":true,"mqttConnected":false},"stations":[{"name":"maison","model":"T8010","serialNumber":"T8010N23210xxxxx","hardwareVersion":"P0","softwareVersion":"2.1.8.8h","lanIpAddress":"192.168.1.133","macAddress":"8C:85:80:8C:48:90","currentMode":0,"guardMode":0,"connected":true,"type":0,"timeFormat":0,"alarmVolume":26,"alarmTone":1,"promptVolume":16,"notificationSwitchModeSchedule":true,"notificationSwitchModeGeofence":true,"notificationSwitchModeApp":true,"notificationSwitchModeKeypad":true,"notificationStartAlarmDelay":true}],"devices":[{"name":"Arrière-cour","model":"T8113-Z","serialNumber":"T8113N6321xxxxx","hardwareVersion":"T8113-Z","softwareVersion":"5.4.6","stationSerialNumber":"T8010N23210xxxxx","enabled":true,"state":1,"battery":93,"batteryTemperature":20,"lastChargingDays":32,"lastChargingTotalEvents":125,"lastChargingRecordedEvents":71,"lastChargingFalseEvents":54,"batteryUsageLastWeek":0,"motionDetected":false,"personDetected":false,"personName":"","antitheftDetection":false,"motionDetection":true,"rtspStream":true,"watermark":2,"wifiRSSI":-64,"pictureUrl":"https://cdn-eu.eufylife.com/thumb/2022/03/20/station/T8010N23210xxxxx/FRHBcD6RD9IHoM3A./camera01_20220320131409.jpg?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAJYLV2xxxxxxxxx%2F20220322%2Feu-central-1%2Fs3%2Faws4_request&X-Amz-Date=20220322T155839Z&X-Amz-Expires=86400&X-Amz-SignedHeaders=host&X-Amz-Signature=fb0b8853594e7276dda6a41454acead10ca9554150fd9b390a386ccd20923aab","type":8,"motionDetectionType":0,"light":false,"microphone":true,"speaker":true,"speakerVolume":96,"audioRecording":true,"powerSource":0,"powerWorkingMode":1,"recordingEndClipMotionStops":true,"recordingClipLength":60,"recordingRetriggerInterval":5,"lightSettingsBrightnessManual":100,"notificationType":3,"motionDetectionSensitivity":4,"statusLed":false,"rtspStreamUrl":"rtsp://xxxxx:xxxxx@192.168.1.133/live1","chargingStatus":2,"wifiSignalLevel":4,"nightvision":2},{"name":"Porte d'entrée","model":"T8113-Z","serialNumber":"T8113N6321xxxxx","hardwareVersion":"T8113-Z","softwareVersion":"5.4.6","stationSerialNumber":"T8010N23210xxxxx","enabled":true,"state":1,"battery":31,"batteryTemperature":21,"lastChargingDays":93,"lastChargingTotalEvents":5129,"lastChargingRecordedEvents":1057,"lastChargingFalseEvents":4072,"batteryUsageLastWeek":0,"motionDetected":false,"personDetected":false,"personName":"","antitheftDetection":false,"motionDetection":true,"rtspStream":true,"watermark":2,"wifiRSSI":-55,"pictureUrl":"https://security-app-eu.eufylife.com/v1/s/g/sDxxxgt6","type":8,"motionDetectionType":0,"light":false,"microphone":true,"speaker":true,"speakerVolume":96,"audioRecording":true,"powerSource":0,"powerWorkingMode":0,"recordingEndClipMotionStops":true,"recordingClipLength":60,"recordingRetriggerInterval":5,"lightSettingsBrightnessManual":100,"notificationType":3,"motionDetectionSensitivity":7,"statusLed":false,"rtspStreamUrl":"rtsp://xxxxx:xxxxx@192.168.1.133/live0","chargingStatus":2,"wifiSignalLevel":4,"nightvision":1},{"name":"Piscine","model":"T8113","serialNumber":"T8113N132144xxxxx","hardwareVersion":"eufy2_mini","softwareVersion":"1.7.4","stationSerialNumber":"T8010N23210xxxxx","enabled":true,"state":1,"battery":93,"batteryTemperature":17,"lastChargingDays":-1,"lastChargingTotalEvents":153,"lastChargingRecordedEvents":136,"lastChargingFalseEvents":17,"batteryUsageLastWeek":0,"motionDetected":false,"personDetected":false,"personName":"","antitheftDetection":false,"motionDetection":true,"rtspStream":true,"watermark":2,"wifiRSSI":-69,"pictureUrl":"https://security-app-eu.eufylife.com/v1/s/g/9SxxxCa8","type":8,"motionDetectionType":2,"light":false,"microphone":true,"speaker":true,"speakerVolume":93,"audioRecording":true,"powerSource":0,"powerWorkingMode":1,"recordingEndClipMotionStops":true,"recordingClipLength":60,"recordingRetriggerInterval":5,"lightSettingsBrightnessManual":100,"notificationType":3,"motionDetectionSensitivity":6,"statusLed":false,"rtspStreamUrl":"rtsp://xxx:Maxxxxilcara106@192.168.1.133/live2","chargingStatus":2,"wifiSignalLevel":3,"nightvision":2}]}}}
2022-03-22 17:04:06.604 [DEBUG] [ernal.discovery.EufyDiscoveryService] - Discovered Station: maison (T8010N23210xxxxx)
2022-03-22 17:04:06.606 [DEBUG] [ernal.discovery.EufyDiscoveryService] - Discovered Camera: Arrière-cour (T8113N6321xxxxx)
2022-03-22 17:04:06.607 [DEBUG] [ernal.discovery.EufyDiscoveryService] - Discovered Camera: Porte d'entrée (T8113N6321xxxxx)
2022-03-22 17:04:06.609 [DEBUG] [ernal.discovery.EufyDiscoveryService] - Discovered Camera: Piscine (T8113N132144xxxxx)
2022-03-22 17:04:06.647 [DEBUG] [nternal.handlers.BaseEufyThingHander] - EufyStation: Unable to send update for property (alarmTone:)Integer to 1: channel not found
2022-03-22 17:04:06.648 [DEBUG] [nternal.handlers.BaseEufyThingHander] - EufyStation: Unable to send update for property (alarmVolume:)Integer to 26: channel not found
2022-03-22 17:04:06.649 [DEBUG] [nternal.handlers.BaseEufyThingHander] - EufyStation: Sent update to channel eufy:station:eufy:EufyStation:connected: ON
2022-03-22 17:04:06.651 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:antitheftDetection: OFF
2022-03-22 17:04:06.651 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:antitheftDetection: OFF
2022-03-22 17:04:06.655 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:antitheftDetection: OFF
2022-03-22 17:04:06.654 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:antitheftDetection: OFF
2022-03-22 17:04:06.666 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:audioRecording: ON
2022-03-22 17:04:06.655 [DEBUG] [nternal.handlers.BaseEufyThingHander] - EufyStation: Sent update to channel eufy:station:eufy:EufyStation:currentMode: 0
2022-03-22 17:04:06.667 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:autoNightvision: OFF
2022-03-22 17:04:06.668 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:battery: 93
2022-03-22 17:04:06.668 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:batteryTemperature: 17
2022-03-22 17:04:06.669 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:chargingStatus: 2
2022-03-22 17:04:06.670 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:enabled: ON
2022-03-22 17:04:06.670 [DEBUG] [nternal.handlers.BaseEufyThingHander] - EufyStation: Sent update to channel eufy:station:eufy:EufyStation:guardMode: 0
2022-03-22 17:04:06.671 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:microphone: ON
2022-03-22 17:04:06.673 [DEBUG] [nternal.handlers.BaseEufyThingHander] - EufyStation: Unable to send update for property (promptVolume:)Integer to 16: channel not found
2022-03-22 17:04:06.680 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:audioRecording: ON
2022-03-22 17:04:06.681 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:autoNightvision: OFF
2022-03-22 17:04:06.666 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:audioRecording: ON
2022-03-22 17:04:06.683 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:audioRecording: ON
2022-03-22 17:04:06.683 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:autoNightvision: OFF
2022-03-22 17:04:06.685 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:autoNightvision: OFF
2022-03-22 17:04:06.685 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:battery: 31
2022-03-22 17:04:06.686 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:batteryTemperature: 21
2022-03-22 17:04:06.686 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:chargingStatus: 2
2022-03-22 17:04:06.686 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:battery: 93
2022-03-22 17:04:06.687 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:enabled: ON
2022-03-22 17:04:06.687 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:microphone: ON
2022-03-22 17:04:06.688 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:motionDetected: OFF
2022-03-22 17:04:06.688 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:batteryTemperature: 20
2022-03-22 17:04:06.688 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:motionDetection: ON
2022-03-22 17:04:06.689 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:chargingStatus: 2
2022-03-22 17:04:06.689 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:motionDetectionSensitivity: 7
2022-03-22 17:04:06.690 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:motionDetected: OFF
2022-03-22 17:04:06.690 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:enabled: ON
2022-03-22 17:04:06.690 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:motionDetection: ON
2022-03-22 17:04:06.690 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:microphone: ON
2022-03-22 17:04:06.691 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:motionDetectionSensitivity: 6
2022-03-22 17:04:06.691 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:motionDetectionType: 2
2022-03-22 17:04:06.691 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:motionDetected: OFF
2022-03-22 17:04:06.691 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:notificationType: 3
2022-03-22 17:04:06.691 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:motionDetectionType: 0
2022-03-22 17:04:06.692 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:notificationType: 3
2022-03-22 17:04:06.692 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:motionDetection: ON
2022-03-22 17:04:06.692 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:personDetected: OFF
2022-03-22 17:04:06.693 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:motionDetectionSensitivity: 4
2022-03-22 17:04:06.698 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:battery: 93
2022-03-22 17:04:06.712 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:personDetected: OFF
2022-03-22 17:04:06.714 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:personName:
2022-03-22 17:04:06.715 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:personName:
2022-03-22 17:04:06.719 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:motionDetectionType: 0
2022-03-22 17:04:06.720 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:notificationType: 3
2022-03-22 17:04:06.721 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:personDetected: OFF
2022-03-22 17:04:06.723 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:personName:
2022-03-22 17:04:06.727 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:batteryTemperature: 20
2022-03-22 17:04:06.727 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:chargingStatus: 2
2022-03-22 17:04:06.728 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:enabled: ON
2022-03-22 17:04:06.728 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:microphone: ON
2022-03-22 17:04:06.731 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:motionDetected: OFF
2022-03-22 17:04:06.732 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:motionDetection: ON
2022-03-22 17:04:06.743 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:motionDetectionSensitivity: 4
2022-03-22 17:04:06.744 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:motionDetectionType: 0
2022-03-22 17:04:06.744 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:notificationType: 3
2022-03-22 17:04:06.745 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:personDetected: OFF
2022-03-22 17:04:06.745 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:personName:
2022-03-22 17:04:07.083 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:picture: raw type (image/jpg): 18126 bytes
2022-03-22 17:04:07.084 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:pictureUrl: https://cdn-eu.eufylife.com/thumb/2022/03/20/station/T8010N23210xxxxx/FRHBcD6RD9IHoM3A./camera01_20220320131409.jpg?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAJYLV2KOLW6PU4FSA%xxxx%2Feu-central-1%2Fs3%2Faws4_request&X-Amz-Date=20220322T155839Z&X-Amz-Expires=86400&X-Amz-SignedHeaders=host&X-Amz-Signature=fb0b8853594e7276dda6a41454xxxxxx150fd9b390a386ccd20923aab
2022-03-22 17:04:07.084 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:powerSource: 0
2022-03-22 17:04:07.084 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:recordingClipLength: 60
2022-03-22 17:04:07.085 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:recordingEndClipMotionStops: ON
2022-03-22 17:04:07.085 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:recordingRetriggerInterval: 5
2022-03-22 17:04:07.086 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:rtspStream: ON
2022-03-22 17:04:07.086 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:rtspStreamUrl: rtsp://xxxxx:xxxx@192.168.1.133/live1
2022-03-22 17:04:07.087 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:speaker: ON
2022-03-22 17:04:07.087 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:speakerVolume: 96
2022-03-22 17:04:07.091 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:state: 1
2022-03-22 17:04:07.091 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:statusLed: OFF
2022-03-22 17:04:07.092 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:watermark: 2
2022-03-22 17:04:07.092 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Unable to send update for property (wifiSignalLevel:)Integer to 4: channel not found
2022-03-22 17:04:07.110 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:picture: raw type (image/jpg): 19705 bytes
2022-03-22 17:04:07.111 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:pictureUrl: https://security-app-eu.eufylife.com/v1/s/g/xxxxt6
2022-03-22 17:04:07.111 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:powerSource: 0
2022-03-22 17:04:07.112 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:recordingClipLength: 60
2022-03-22 17:04:07.112 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:recordingEndClipMotionStops: ON
2022-03-22 17:04:07.113 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:recordingRetriggerInterval: 5
2022-03-22 17:04:07.113 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:rtspStream: ON
2022-03-22 17:04:07.114 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:rtspStreamUrl: rtsp://xxxxx:xxxxx@192.168.1.133/live0
2022-03-22 17:04:07.115 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:speaker: ON
2022-03-22 17:04:07.115 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:speakerVolume: 96
2022-03-22 17:04:07.117 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:state: 1
2022-03-22 17:04:07.117 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:statusLed: OFF
2022-03-22 17:04:07.121 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:watermark: 2
2022-03-22 17:04:07.124 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Unable to send update for property (wifiSignalLevel:)Integer to 4: channel not found
2022-03-22 17:04:07.137 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:picture: raw type (image/jpg): 22485 bytes
2022-03-22 17:04:07.138 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:pictureUrl: https://security-app-eu.eufylife.com/v1/s/g/9Saxxxxa8
2022-03-22 17:04:07.139 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:powerSource: 0
2022-03-22 17:04:07.139 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:recordingClipLength: 60
2022-03-22 17:04:07.140 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:recordingEndClipMotionStops: ON
2022-03-22 17:04:07.140 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:recordingRetriggerInterval: 5
2022-03-22 17:04:07.141 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:rtspStream: ON
2022-03-22 17:04:07.141 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:rtspStreamUrl: rtsp://xxxx:xxxx@192.168.1.133/live2
2022-03-22 17:04:07.142 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:speaker: ON
2022-03-22 17:04:07.143 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:speakerVolume: 93
2022-03-22 17:04:07.144 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:state: 1
2022-03-22 17:04:07.144 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:statusLed: OFF
2022-03-22 17:04:07.145 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:watermark: 2
2022-03-22 17:04:07.145 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Unable to send update for property (wifiSignalLevel:)Integer to 3: channel not found
2022-03-22 17:04:07.178 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:picture: raw type (image/jpg): 18126 bytes
2022-03-22 17:04:07.179 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:picture: raw type (image/jpg): 18126 bytes
2022-03-22 17:04:07.180 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:pictureUrl: https://cdn-eu.eufylife.com/thumb/2022/03/20/station/T8010N23210xxxxx/FRHBcD6RD9IHoM3A./camera01_20220320131409.jpg?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAJYLV2KOLW6PU4FSxxxxx2%2Feu-central-1%2Fs3%2Faws4_request&X-Amz-Date=20220322T155839Z&X-Amz-Expires=86400&X-Amz-SignedHeaders=host&X-Amz-Signature=fb0b8853594e7276dda6a41454acexxxxxfd9b390a386ccd20923aab
2022-03-22 17:04:07.181 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:powerSource: 0
2022-03-22 17:04:07.181 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:recordingClipLength: 60
2022-03-22 17:04:07.182 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:recordingEndClipMotionStops: ON
2022-03-22 17:04:07.183 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:recordingRetriggerInterval: 5
2022-03-22 17:04:07.183 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:rtspStream: ON
2022-03-22 17:04:07.184 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:rtspStreamUrl: rtsp://xxxxx:xxxxx@192.168.1.133/live1
2022-03-22 17:04:07.185 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:speaker: ON
2022-03-22 17:04:07.186 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:speakerVolume: 96
2022-03-22 17:04:07.187 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:state: 1
2022-03-22 17:04:07.188 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:statusLed: OFF
2022-03-22 17:04:07.188 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Sent update to channel eufy:camera:eufy:CameraTerrasse:watermark: 2
2022-03-22 17:04:07.189 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraTerrasse: Unable to send update for property (wifiSignalLevel:)Integer to 4: channel not found
2022-03-22 17:04:07.189 [DEBUG] [nternal.handlers.BaseEufyThingHander] - EufyStation: Unable to send update for property (alarmTone:)Integer to 1: channel not found
2022-03-22 17:04:07.190 [DEBUG] [nternal.handlers.BaseEufyThingHander] - EufyStation: Unable to send update for property (alarmVolume:)Integer to 26: channel not found
2022-03-22 17:04:07.190 [DEBUG] [nternal.handlers.BaseEufyThingHander] - EufyStation: Sent update to channel eufy:station:eufy:EufyStation:connected: ON
2022-03-22 17:04:07.191 [DEBUG] [nternal.handlers.BaseEufyThingHander] - EufyStation: Sent update to channel eufy:station:eufy:EufyStation:currentMode: 0
2022-03-22 17:04:07.192 [DEBUG] [nternal.handlers.BaseEufyThingHander] - EufyStation: Sent update to channel eufy:station:eufy:EufyStation:guardMode: 0
2022-03-22 17:04:07.192 [DEBUG] [nternal.handlers.BaseEufyThingHander] - EufyStation: Unable to send update for property (promptVolume:)Integer to 16: channel not found
2022-03-22 17:04:07.195 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:antitheftDetection: OFF
2022-03-22 17:04:07.196 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:audioRecording: ON
2022-03-22 17:04:07.197 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:autoNightvision: OFF
2022-03-22 17:04:07.197 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:battery: 31
2022-03-22 17:04:07.198 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:batteryTemperature: 21
2022-03-22 17:04:07.199 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:chargingStatus: 2
2022-03-22 17:04:07.199 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:enabled: ON
2022-03-22 17:04:07.199 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:microphone: ON
2022-03-22 17:04:07.200 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:motionDetected: OFF
2022-03-22 17:04:07.201 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:motionDetection: ON
2022-03-22 17:04:07.201 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:motionDetectionSensitivity: 7
2022-03-22 17:04:07.202 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:motionDetectionType: 0
2022-03-22 17:04:07.202 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:notificationType: 3
2022-03-22 17:04:07.202 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:personDetected: OFF
2022-03-22 17:04:07.203 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:personName:
2022-03-22 17:04:07.319 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:picture: raw type (image/jpg): 19705 bytes
2022-03-22 17:04:07.320 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:picture: raw type (image/jpg): 19705 bytes
2022-03-22 17:04:07.320 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:pictureUrl: https://security-app-eu.eufylife.com/v1/s/g/sDxxxx6
2022-03-22 17:04:07.321 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:powerSource: 0
2022-03-22 17:04:07.322 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:recordingClipLength: 60
2022-03-22 17:04:07.323 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:recordingEndClipMotionStops: ON
2022-03-22 17:04:07.324 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:recordingRetriggerInterval: 5
2022-03-22 17:04:07.324 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:rtspStream: ON
2022-03-22 17:04:07.325 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:rtspStreamUrl: rtsp://xxx:xxxx@192.168.1.133/live0
2022-03-22 17:04:07.326 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:speaker: ON
2022-03-22 17:04:07.327 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:speakerVolume: 96
2022-03-22 17:04:07.327 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:state: 1
2022-03-22 17:04:07.329 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:statusLed: OFF
2022-03-22 17:04:07.330 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:watermark: 2
2022-03-22 17:04:07.331 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Unable to send update for property (wifiSignalLevel:)Integer to 4: channel not found
2022-03-22 17:04:07.333 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:antitheftDetection: OFF
2022-03-22 17:04:07.335 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:audioRecording: ON
2022-03-22 17:04:07.335 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:autoNightvision: OFF
2022-03-22 17:04:07.336 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:battery: 93
2022-03-22 17:04:07.337 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:batteryTemperature: 17
2022-03-22 17:04:07.337 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:chargingStatus: 2
2022-03-22 17:04:07.338 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:enabled: ON
2022-03-22 17:04:07.338 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:microphone: ON
2022-03-22 17:04:07.339 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:motionDetected: OFF
2022-03-22 17:04:07.339 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:motionDetection: ON
2022-03-22 17:04:07.339 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:motionDetectionSensitivity: 6
2022-03-22 17:04:07.340 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:motionDetectionType: 2
2022-03-22 17:04:07.340 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:notificationType: 3
2022-03-22 17:04:07.341 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:personDetected: OFF
2022-03-22 17:04:07.341 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:personName:
2022-03-22 17:04:07.461 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:picture: raw type (image/jpg): 22485 bytes
2022-03-22 17:04:07.462 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:picture: raw type (image/jpg): 22485 bytes
2022-03-22 17:04:07.463 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:pictureUrl: https://security-app-eu.eufylife.com/v1/s/g/9xxxa8
2022-03-22 17:04:07.463 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:powerSource: 0
2022-03-22 17:04:07.464 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:recordingClipLength: 60
2022-03-22 17:04:07.464 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:recordingEndClipMotionStops: ON
2022-03-22 17:04:07.465 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:recordingRetriggerInterval: 5
2022-03-22 17:04:07.465 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:rtspStream: ON
2022-03-22 17:04:07.466 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:rtspStreamUrl: rtsp://xxxxx:xxxxx@192.168.1.133/live2
2022-03-22 17:04:07.473 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:speaker: ON
2022-03-22 17:04:07.474 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:speakerVolume: 93
2022-03-22 17:04:07.475 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:state: 1
2022-03-22 17:04:07.475 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:statusLed: OFF
2022-03-22 17:04:07.476 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Sent update to channel eufy:camera:eufy:CameraPiscine:watermark: 2
2022-03-22 17:04:07.476 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraPiscine: Unable to send update for property (wifiSignalLevel:)Integer to 3: channel not found
2022-03-22 17:12:06.552 [DEBUG] [y.internal.EufyContainerSocketClient] - Sending {"messageId":"2","command":"driver.poll_refresh"}
2022-03-22 17:12:07.224 [DEBUG] [y.internal.EufyContainerSocketClient] - Received message: {"type":"result","success":true,"messageId":"2","result":null}
2022-03-22 17:20:06.553 [DEBUG] [y.internal.EufyContainerSocketClient] - Sending {"messageId":"3","command":"driver.poll_refresh"}
2022-03-22 17:20:07.232 [DEBUG] [y.internal.EufyContainerSocketClient] - Received message: {"type":"result","success":true,"messageId":"3","result":null}
2022-03-22 17:28:06.555 [DEBUG] [y.internal.EufyContainerSocketClient] - Sending {"messageId":"4","command":"driver.poll_refresh"}
2022-03-22 17:28:07.276 [DEBUG] [y.internal.EufyContainerSocketClient] - Received message: {"type":"result","success":true,"messageId":"4","result":null}
and my items definition if it’s usefull to anyone
Switch EufyBridge_cloudConnected {channel="eufy:container:eufy:cloud-connected"}
Switch EufyBridge_pushConnected {channel="eufy:container:eufy:push-connected"}
Number EufyStation_alarmTone {channel="eufy:station:eufy:EufyStation:alarmTone"}
Number EufyStation_alarmVolume {channel="eufy:station:eufy:EufyStation:alarmVolume"}
Switch EufyStation_connected {channel="eufy:station:eufy:EufyStation:connected"}
Number EufyStation_currentMode {channel="eufy:station:eufy:EufyStation:currentMode"}
Switch EufyStation_guardMode {channel="eufy:station:eufy:EufyStation:guardMode"}
Switch EufyStation_promptVolume {channel="eufy:station:eufy:EufyStation:promptVolume"}
Switch EufyCameraTerrasse_antitheftDetection {channel="eufy:camera:eufy:CameraTerrasse:antitheftDetection"}
Switch EufyCameraTerrasse_audioRecording {channel="eufy:camera:eufy:CameraTerrasse:audioRecording"}
Switch EufyCameraTerrasse_autoNightvision {channel="eufy:camera:eufy:CameraTerrasse:autoNightvision"}
Number EufyCameraTerrasse_battery {channel="eufy:camera:eufy:CameraTerrasse:battery"}
Number EufyCameraTerrasse_batteryTemperature {channel="eufy:camera:eufy:CameraTerrasse:batteryTemperature"}
Number EufyCameraTerrasse_chargingStatus {channel="eufy:camera:eufy:CameraTerrasse:chargingStatus"}
Switch EufyCameraTerrasse_enabled {channel="eufy:camera:eufy:CameraTerrasse:enabled"}
Switch EufyCameraTerrasse_microphone {channel="eufy:camera:eufy:CameraTerrasse:microphone"}
Switch EufyCameraTerrasse_motionDetected {channel="eufy:camera:eufy:CameraTerrasse:motionDetected"}
Switch EufyCameraTerrasse_motionDetection {channel="eufy:camera:eufy:CameraTerrasse:motionDetection"}
Number EufyCameraTerrasse_motionDetectionSensitivity {channel="eufy:camera:eufy:CameraTerrasse:motionDetectionSensitivity"}
Number EufyCameraTerrasse_motionDetectionType {channel="eufy:camera:eufy:CameraTerrasse:motionDetectionType"}
Switch EufyCameraTerrasse_personDetected {channel="eufy:camera:eufy:CameraTerrasse:personDetected"}
String EufyCameraTerrasse_personName {channel="eufy:camera:eufy:CameraTerrasse:personName"}
String EufyCameraTerrasse_picture {channel="eufy:camera:eufy:CameraTerrasse:picture"}
String EufyCameraTerrasse_pictureUrl {channel="eufy:camera:eufy:CameraTerrasse:pictureUrl"}
Number EufyCameraTerrasse_powerSource {channel="eufy:camera:eufy:CameraTerrasse:powerSource"}
Number EufyCameraTerrasse_recordingClipLength {channel="eufy:camera:eufy:CameraTerrasse:recordingClipLength"}
Switch EufyCameraTerrasse_recordingEndClipMotionStops {channel="eufy:camera:eufy:CameraTerrasse:recordingEndClipMotionStops"}
Number EufyCameraTerrasse_recordingRetriggerInterval {channel="eufy:camera:eufy:CameraTerrasse:recordingRetriggerInterval"}
Switch EufyCameraTerrasse_rtspStream {channel="eufy:camera:eufy:CameraTerrasse:rtspStream"}
String EufyCameraTerrasse_rtspStreamUrl {channel="eufy:camera:eufy:CameraTerrasse:rtspStreamUrl"}
Switch EufyCameraTerrasse_speaker {channel="eufy:camera:eufy:CameraTerrasse:speaker"}
Number EufyCameraTerrasse_speakerVolume {channel="eufy:camera:eufy:CameraTerrasse:speakerVolume"}
Number EufyCameraTerrasse_state {channel="eufy:camera:eufy:CameraTerrasse:state"}
Switch EufyCameraTerrasse_statusLed {channel="eufy:camera:eufy:CameraTerrasse:statusLed"}
Number EufyCameraTerrasse_watermark {channel="eufy:camera:eufy:CameraTerrasse:watermark"}
Number EufyCameraTerrasse_wifiSignalLevel {channel="eufy:camera:eufy:CameraTerrasse:wifiSignalLevel"}
Switch EufyCameraPiscine_antitheftDetection {channel="eufy:camera:eufy:CameraPiscine:antitheftDetection"}
Switch EufyCameraPiscine_audioRecording {channel="eufy:camera:eufy:CameraPiscine:audioRecording"}
Switch EufyCameraPiscine_autoNightvision {channel="eufy:camera:eufy:CameraPiscine:autoNightvision"}
Number EufyCameraPiscine_battery {channel="eufy:camera:eufy:CameraPiscine:battery"}
Number EufyCameraPiscine_batteryTemperature {channel="eufy:camera:eufy:CameraPiscine:batteryTemperature"}
Number EufyCameraPiscine_chargingStatus {channel="eufy:camera:eufy:CameraPiscine:chargingStatus"}
Switch EufyCameraPiscine_enabled {channel="eufy:camera:eufy:CameraPiscine:enabled"}
Switch EufyCameraPiscine_microphone {channel="eufy:camera:eufy:CameraPiscine:microphone"}
Switch EufyCameraPiscine_motionDetected {channel="eufy:camera:eufy:CameraPiscine:motionDetected"}
Switch EufyCameraPiscine_motionDetection {channel="eufy:camera:eufy:CameraPiscine:motionDetection"}
Number EufyCameraPiscine_motionDetectionSensitivity {channel="eufy:camera:eufy:CameraPiscine:motionDetectionSensitivity"}
Number EufyCameraPiscine_motionDetectionType {channel="eufy:camera:eufy:CameraPiscine:motionDetectionType"}
Switch EufyCameraPiscine_personDetected {channel="eufy:camera:eufy:CameraPiscine:personDetected"}
String EufyCameraPiscine_personName {channel="eufy:camera:eufy:CameraPiscine:personName"}
String EufyCameraPiscine_picture {channel="eufy:camera:eufy:CameraPiscine:picture"}
String EufyCameraPiscine_pictureUrl {channel="eufy:camera:eufy:CameraPiscine:pictureUrl"}
Number EufyCameraPiscine_powerSource {channel="eufy:camera:eufy:CameraPiscine:powerSource"}
Number EufyCameraPiscine_recordingClipLength {channel="eufy:camera:eufy:CameraPiscine:recordingClipLength"}
Switch EufyCameraPiscine_recordingEndClipMotionStops {channel="eufy:camera:eufy:CameraPiscine:recordingEndClipMotionStops"}
Number EufyCameraPiscine_recordingRetriggerInterval {channel="eufy:camera:eufy:CameraPiscine:recordingRetriggerInterval"}
Switch EufyCameraPiscine_rtspStream {channel="eufy:camera:eufy:CameraPiscine:rtspStream"}
String EufyCameraPiscine_rtspStreamUrl {channel="eufy:camera:eufy:CameraPiscine:rtspStreamUrl"}
Switch EufyCameraPiscine_speaker {channel="eufy:camera:eufy:CameraPiscine:speaker"}
Number EufyCameraPiscine_speakerVolume {channel="eufy:camera:eufy:CameraPiscine:speakerVolume"}
Number EufyCameraPiscine_state {channel="eufy:camera:eufy:CameraPiscine:state"}
Switch EufyCameraPiscine_statusLed {channel="eufy:camera:eufy:CameraPiscine:statusLed"}
Number EufyCameraPiscine_watermark {channel="eufy:camera:eufy:CameraPiscine:watermark"}
Number EufyCameraPiscine_wifiSignalLevel {channel="eufy:camera:eufy:CameraPiscine:wifiSignalLevel"}
Switch EufyCameraEntree_antitheftDetection {channel="eufy:camera:eufy:CameraEntree:antitheftDetection"}
Switch EufyCameraEntree_audioRecording {channel="eufy:camera:eufy:CameraEntree:audioRecording"}
Switch EufyCameraEntree_autoNightvision {channel="eufy:camera:eufy:CameraEntree:autoNightvision"}
Number EufyCameraEntree_battery {channel="eufy:camera:eufy:CameraEntree:battery"}
Number EufyCameraEntree_batteryTemperature {channel="eufy:camera:eufy:CameraEntree:batteryTemperature"}
Number EufyCameraEntree_chargingStatus {channel="eufy:camera:eufy:CameraEntree:chargingStatus"}
Switch EufyCameraEntree_enabled {channel="eufy:camera:eufy:CameraEntree:enabled"}
Switch EufyCameraEntree_microphone {channel="eufy:camera:eufy:CameraEntree:microphone"}
Switch EufyCameraEntree_motionDetected {channel="eufy:camera:eufy:CameraEntree:motionDetected"}
Switch EufyCameraEntree_motionDetection {channel="eufy:camera:eufy:CameraEntree:motionDetection"}
Number EufyCameraEntree_motionDetectionSensitivity {channel="eufy:camera:eufy:CameraEntree:motionDetectionSensitivity"}
Number EufyCameraEntree_motionDetectionType {channel="eufy:camera:eufy:CameraEntree:motionDetectionType"}
Switch EufyCameraEntree_personDetected {channel="eufy:camera:eufy:CameraEntree:personDetected"}
String EufyCameraEntree_personName {channel="eufy:camera:eufy:CameraEntree:personName"}
String EufyCameraEntree_picture {channel="eufy:camera:eufy:CameraEntree:picture"}
String EufyCameraEntree_pictureUrl {channel="eufy:camera:eufy:CameraEntree:pictureUrl"}
Number EufyCameraEntree_powerSource {channel="eufy:camera:eufy:CameraEntree:powerSource"}
Number EufyCameraEntree_recordingClipLength {channel="eufy:camera:eufy:CameraEntree:recordingClipLength"}
Switch EufyCameraEntree_recordingEndClipMotionStops {channel="eufy:camera:eufy:CameraEntree:recordingEndClipMotionStops"}
Number EufyCameraEntree_recordingRetriggerInterval {channel="eufy:camera:eufy:CameraEntree:recordingRetriggerInterval"}
Switch EufyCameraEntree_rtspStream {channel="eufy:camera:eufy:CameraEntree:rtspStream"}
String EufyCameraEntree_rtspStreamUrl {channel="eufy:camera:eufy:CameraEntree:rtspStreamUrl"}
Switch EufyCameraEntree_speaker {channel="eufy:camera:eufy:CameraEntree:speaker"}
Number EufyCameraEntree_speakerVolume {channel="eufy:camera:eufy:CameraEntree:speakerVolume"}
Number EufyCameraEntree_state {channel="eufy:camera:eufy:CameraEntree:state"}
Switch EufyCameraEntree_statusLed {channel="eufy:camera:eufy:CameraEntree:statusLed"}
Number EufyCameraEntree_watermark {channel="eufy:camera:eufy:CameraEntree:watermark"}
Number EufyCameraEntree_wifiSignalLevel {channel="eufy:camera:eufy:CameraEntree:wifiSignalLevel"}
EDIT:
Well some events seems to be pushed
2022-03-22 17:50:32.306 [DEBUG] [y.internal.EufyContainerSocketClient] - Received message: {“type”:“event”,“event”:{“source”:“device”,“event”:“person detected”,“serialNumber”:“T8113N63210xxxxx”,“state”:true,“person”:“Unknown”}}
2022-03-22 17:50:32.307 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:personDetected: ON
2022-03-22 17:50:32.308 [DEBUG] [nternal.handlers.BaseEufyThingHander] - CameraEntree: Sent update to channel eufy:camera:eufy:CameraEntree:personName: Unknown
