I do not get a version in dl900 for the NX584:
I ‘enrolled’ it again, but the same result.
Sorry, that was the limit of my knowledge. I have a NX8e, so a bit different.
FYI, I worked it out.
Very strange, but I have to set the NX-584 to ASCII. The bridge thing in openhab is set to Binary.
That way it works!!! Everything is online now.
That is great. What version of OH are you running? As I mentioned above I seem to have an issue with THINGS coming online after a restart - required Bridge Thing to be disabled and re-enabled.
Currently I’m using OH 3.2.0 running in docker on an Intel NUC running Ubuntu 22.04.1 server.
I had some issues with the latest OH 3.3.0 version and my Sonos speakers. They became randomly disconnected. And all of a sudden the volume was set to the maximum… Never have that with the 3.2.0 version.
I have no problems with the CADDX Bridge Thing running OH 3.2.0 after restarting the Docker container. It comes automatic ‘ONLINE’ without any problem.
As you mentioned above: Input field for number/free text for openHAB UIs
Do you have the code working in openhab3? I would like to enter the code also before ARMING/DISARMING the alarm. Thanks in advance!
Georgios fixed it a while back and had been fine till i upgraded to 3.3.
I am hoping he will see my post above snd take a look again.
Take a look at:
This allows entering PIN etc.
Hello @Mark_VG,
yes, I’m still here. It’s vacation period currently.
I haven’t upgraded, and do not experience the issue.
Yes, a log would be helpful. Thanks
Thanks Georgios.
Hope you enjoy you holidays. Would really appreciate if you can look when you get a chance. Seems to be similar to when you fixed last time.
Attached are the openhab.log file as well as a Caddx DEBUG log. I can send the TRACE if it will be better?
openhab.log (6.6 KB)
caddx.log (181.4 KB)
I restarted openHAB and the THINGS were as follows:
Disabled and re-enabled the Bridge Thing and got:
Hi @Mark_VG,
Looks like a timing issue.
The bridge requests on initialization the state of all the zones, partitions, etc. The problem is (probably) that the binding is not yet ready e.g. Not all zones/partitions/etc have been yet loaded.
I’ll need some time to update my dev environment and look into it. Will keep you posted.
Hi Georgios
Also seeing this on a restart:
14:00:25.717 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.openhab.binding.caddx.internal.handler.CaddxBridgeHandler@37b7d31a': For input string: "15.0"
java.lang.NumberFormatException: For input string: "15.0"
at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65) ~[?:?]
at java.lang.Integer.parseInt(Integer.java:652) ~[?:?]
at java.lang.Integer.valueOf(Integer.java:957) ~[?:?]
at java.lang.Integer.decode(Integer.java:1436) ~[?:?]
at org.openhab.binding.caddx.internal.CaddxMessage.<init>(CaddxMessage.java:111) ~[?:?]
at org.openhab.binding.caddx.internal.handler.CaddxBridgeHandler.sendCommand(CaddxBridgeHandler.java:258) ~[?:?]
at org.openhab.binding.caddx.internal.handler.CaddxBridgeHandler.lambda$0(CaddxBridgeHandler.java:165) ~[?:?]
at java.util.concurrent.ConcurrentHashMap.forEach(ConcurrentHashMap.java:1603) ~[?:?]
at org.openhab.binding.caddx.internal.handler.CaddxBridgeHandler.initialize(CaddxBridgeHandler.java:165) ~[?:?]
at jdk.internal.reflect.GeneratedMethodAccessor99.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
14:00:25.743 [ERROR] [.core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing 'caddx:bridge:e59e4935': For input string: "15.0"
M
Hi @Mark_VG,
Please run the following and send me the debug log.
latest jar
Unfortunately, I could not test it. Hopefully it is working.
Also send me the full log with the error, so that i can have some context.
Hi Georgios
Thanks for looking into this.
Appears to be something missing?
07:36:28.437 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/C:/openHAB/addons/org.openhab.binding.caddx-3.4.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.caddx [274]
Unresolved requirement: Import-Package: org.openhab.core.io.transport.serial
at org.eclipse.osgi.container.Module.start(Module.java:463) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:445) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.7.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.7.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [bundleFile:3.7.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.7.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.7.4]
Do I need something else in ADDONS as well?
Attached is a full debug log of starting with the New JAR and then reverting to the original and then restrting the BRIDGE THING. This includes the error I mentioned.
caddx.log (392.3 KB)
Hi @Mark_VG,
you also need the serial feature. Try the following on the console
feature:install openhab-transport-serial
Thank you. Will do that.
Does that survive an openHAB restart?
Just want to be sure i get you the logs you need on restart.
EDIT: Attached are the logs. Had to restart the Bridge Thing to get the zones etc online
caddx.log (290.0 KB)
The difference i see is that on the 1st run the zones have a .0 at the end.
childHandlerInitialized. Zone 20.0
After the restart we get
I don’t know why that happens. Will look into it.
How did you configure the binding?
Thank you.
Everything is configured via GUI.
Hi @Mark_VG can you try the following jar:
Thanks Georgios. Thant seem sot have worked. The THINGS initialize and then stay OFFLINE for a while, then all come ONLINE.
Will monitor for a day or two and then confirm.
Thanks so much for looking at it.
Mark, please send the caddx.log so that i can confirm that it behaves as intended.
Also can you check that you do not get anymore the NumberFormat exception.
