Yeah, I could try to put those map as a new thing type.
However, it will take some time, because of lack spare time for a week or two. You can reach me by the end of the next week about this.
Thank you, I will.
Hi @wars
It works! nice job.
I have a questions what is the difference between:
and
val deviceSn = “************”
I know now that deviceSn it is serial number of your inverter
what about solarman_SN ? is it logger s/n or also inverter s/n ? I do not see that is used in any of the script.
solarman_SN
is just the item which I also get from the solarman API, but indeed, this will probably the same and actually not necessarry. I just listed all items which I received back from the API.
I’m still using this script, but also switched to the modbus implementation to receive all values in realtime. (because I didn’t want to run an extra pi next to my inverter to grab modbus, I’m using a device from Waveshare)
Cześć @Piotr_Bojko !
I just would like to ping you if you had opportunity take a look on this?
-Grzegorz
I will try to hit this just after a christmass.
Does anyone want to help me and gather the logs from SN 23xxx loggers using current version of binding? Following logs are the most important:
[WARN ] [al.protocolv5.UnknownResponseHandler] - Unknown response from logger sofar, length [... here are the part with length and base64 payload]
In the meantime I have scratched new github repo for the bidnding
Contribute to ptrbojko/openhab-lsw4inverter-binding development by creating an account on GitHub.
If the newest version is 3.1.0 then:
2023-01-16 16:13:11.602 [WARN ] [al.protocolv5.UnknownResponseHandler] - Unknown response from logger ca036944c7, length 32: A513001015002BA3DCAC8B0201349314006306000050D6B06301900204003015
2023-01-16 16:15:11.615 [WARN ] [al.protocolv5.UnknownResponseHandler] - Unknown response from logger ca036944c7, length 14: A501001047002CA3DCAC8B003A15
2023-01-16 16:17:11.626 [WARN ] [al.protocolv5.UnknownResponseHandler] - Unknown response from logger ca036944c7, length 32: A513001015002DA3DCAC8B0201AC931400DC06000050D6B06301900200032215
2023-01-17 09:45:52.918 [WARN ] [al.protocolv5.UnknownResponseHandler] - Unknown response from logger ca036944c7, length 46: A513001015003AA3DCAC8B020160B214005407000066ADB163019002FFFF6415A501001047003BA3DCAC8B004915
2023-01-17 10:01:53.002 [WARN ] [al.protocolv5.UnknownResponseHandler] - Unknown response from logger ca036944c7, length 46: A5130010150055A3DCAC8B02011EB61400120B000067ADB16301900200030915A5010010470056A3DCAC8B006415
I see double NULL before each A5 value:
I’m successfully using the following solution for my 23* logger (integration by mqtt):
Tool written in GO for reading metrics from Sofar LSW-3 inverters with SN 23XXXXXXX - GitHub - kubaceg/sofar_g3_lsw3_logger_reader: Tool written in GO for reading metrics from Sofar LSW-3 inverters...
The protocol (it could help you):
package sofar
type field struct {
register int
name string
valueType string
factor string
unit string
type registerRange struct {
start int
end int
replyFields []field
var rrSystemInfo = registerRange{
start: 0x400,
end: 0x43a,
replyFields: []field{
This file has been truncated. show original
Could you check if following version logs for your some other (possible longer) responses? I have manage to build new request for SN 23*** but nowhere to check the validity.
https://drive.google.com/file/d/181pqJkszf0WB_NXNRIhdz9AV5eSi15rB/view?usp=share_link
I cannot install it on openHAB 3.3.0. I tried to put the file in /addons and nothing happened, no binding, no logs.
Manual install in the Karaf console:
openhab> bundle:install http://localhost/org.openhab.binding.lswlogger-3.3.0.jar
Bundle IDs:
Error executing command: Error installing bundles:
Unable to install bundle http://localhost/org.openhab.binding.lswlogger-3.3.0.jar: org.osgi.framework.BundleException: OSGi R3 bundle not supported
Upsie…
I will deliver “more working” version in upcoming days.
Will we try again?
You will I promise.
Please track the progress here Handle loggers with SN 23xxxx · Issue #1 · ptrbojko/openhab-lsw4inverter-binding · GitHub .
I have published build artifact for the ticket Handle loggers with SN 23xxxx · Issue #1 · ptrbojko/openhab-lsw4inverter-binding · GitHub
You can download and check - there should be new thing type for loggers with SN 23xxxx.
For now - it only connects and tries to fetch data logging it, but not putting into any channels. However logged data is a value for me - to prepare tests for decoders as I don’t have any for such logger.
2023-02-28 15:41:01.303 [WARN ] [al.protocolv5.UnknownResponseHandler] - Unknown response, length 116: A5:67:00:10:15:00:4A:A3:DC:AC:8B:02:01:9D:DF:29:00:46:03:00:00:DF:32:D4:63:01:03:54:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:1C:00:00:9A:B4:00:00:B0:1C:03:27:00:17:00:02:E5:8B:9C:15:
2023-02-28 15:43:01.309 [WARN ] [al.protocolv5.UnknownResponseHandler] - Unknown response, length 822: A5:8D:00:10:15:00:4B:A3:DC:AC:8B:02:01:B8:DF:29:00:61:03:00:00:DF:32:D4:63:01:03:7A:00:00:82:18:43:08:61:7F:13:86:00:1F:FF:D5:00:39:00:00:00:00:00:00:00:00:00:00:09:23:00:50:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:08:F9:00:55:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:21:00:4F:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:4F:44:08:15:A5:27:00:10:15:00:4C:A3:DC:AC:8B:02:01:B8:DF:29:00:62:03:00:00:DF:32:D4:63:01:03:14:00:00:00:00:00:00:03:FF:0B:35:00:33:00:0E:0D:76:00:3A:00:14:B8:68:4A:15:A5:23:00:10:15:00:4D:A3:DC:AC:8B:02:01:B9:DF:29:00:62:03:00:00:DF:32:D4:63:01:03:10:00:00:00:00:00:00:00:FF:00:00:07:78:00:00:0D:CF:44:D4:42:15:A5:89:00:10:15:00:4E:A3:DC:AC:8B:02:01:BA:DF:29:00:64:03:00:00:DF:32:D4:63:01:03:76:00:03:FF:C0:05:81:FF:FF:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:1D:00:00:9A:B5:00:00:B0:1D:03:27:00:17:00:02:00:1C:00:0F:00:29:00:1C:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:A9:79:8A:15:A5:01:00:10:47:00:4F:A3:DC:AC:8B:00:5D:15:A5:8D:00:10:15:00:50:A3:DC:AC:8B:02:01:F4:DF:29:00:9D:03:00:00:DF:32:D4:63:01:03:7A:00:00:82:18:43:08:61:7F:13:87:00:1E:FF:D6:00:38:00:00:00:00:00:00:00:00:00:00:09:27:00:4F:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:0F:00:52:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:22:00:4E:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:0F:7C:94:15:A5:27:00:10:15:00:51:A3:DC:AC:8B:02:01:F4:DF:29:00:9E:03:00:00:DF:32:D4:63:01:03:14:00:00:00:00:00:00:03:FF:0B:D9:00:34:00:0F:0D:C5:00:37:00:13:33:D0:9B:15:A5:23:00:10:15:00:52:A3:DC:AC:8B:02:01:F4:DF:29:00:9E:03:00:00:DF:32:D4:63:01:03:10:00:00:00:00:00:00:00:FF:00:00:07:78:00:00:0D:CF:44:D4:BE:15:A5:89:00:10:15:00:53:A3:DC:AC:8B:02:01:F5:DF:29:00:9E:03:00:00:DF:32:D4:63:01:03:76:00:03:FF:C0:05:81:FF:FF:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:1E:00:00:9A:B6:00:00:B0:1E:03:27:00:17:00:02:00:1C:00:0F:00:2A:00:1B:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:B6:49:E4:15:
2023-02-28 15:45:01.315 [WARN ] [al.protocolv5.UnknownResponseHandler] - Unknown response, length 837: A5:10:00:10:15:00:54:A3:DC:AC:8B:02:01:17:E0:29:00:C1:03:00:00:DF:32:D4:63:05:00:73:15:A5:8D:00:10:15:00:55:A3:DC:AC:8B:02:01:43:E0:29:00:EC:03:00:00:DF:32:D4:63:01:03:7A:00:00:82:18:43:08:61:7F:13:87:00:1E:FF:D7:00:38:00:00:00:00:00:00:00:00:00:00:09:0C:00:51:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:27:00:51:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:12:00:4F:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:2A:2E:F5:15:A5:27:00:10:15:00:56:A3:DC:AC:8B:02:01:43:E0:29:00:ED:03:00:00:DF:32:D4:63:01:03:14:00:00:00:00:00:00:03:FF:0C:27:00:31:00:0F:0D:77:00:38:00:13:C6:B9:BA:15:A5:23:00:10:15:00:57:A3:DC:AC:8B:02:01:43:E0:29:00:ED:03:00:00:DF:32:D4:63:01:03:10:00:00:00:00:00:00:00:FF:00:00:07:79:00:00:0D:CF:79:14:D8:15:A5:89:00:10:15:00:58:A3:DC:AC:8B:02:01:44:E0:29:00:ED:03:00:00:DF:32:D4:63:01:03:76:00:03:FF:C0:05:81:FF:FF:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:1F:00:00:9A:B7:00:00:B0:1F:03:27:00:17:00:02:00:1C:00:0F:00:2B:00:2F:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:6E:41:50:15:A5:8D:00:10:15:00:5D:A3:DC:AC:8B:02:01:6C:E0:29:00:15:04:00:00:E0:32:D4:63:01:03:7A:00:00:82:18:43:08:61:7F:13:85:00:1E:FF:D3:00:3B:00:00:00:00:00:00:00:00:00:00:09:10:00:53:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:28:00:56:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:1B:00:54:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:FE:B5:C3:15:A5:27:00:10:15:00:5E:A3:DC:AC:8B:02:01:6C:E0:29:00:16:04:00:00:E0:32:D4:63:01:03:14:00:00:00:00:00:00:03:FF:0B:D6:00:31:00:0F:0D:76:00:38:00:13:09:4D:9A:15:A5:23:00:10:15:00:5F:A3:DC:AC:8B:02:01:6C:E0:29:00:16:04:00:00:E0:32:D4:63:01:03:10:00:00:00:00:00:00:00:FF:00:00:07:79:00:00:0D:CF:79:14:34:15:A5:89:00:10:15:00:60:A3:DC:AC:8B:02:01:6D:E0:29:00:16:04:00:00:E0:32:D4:63:01:03:76:00:03:FF:C0:05:81:FF:FF:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:20:00:00:9A:B8:00:00:B0:20:03:27:00:17:00:02:00:1C:00:0F:00:2C:00:1B:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:A6:D0:63:15:
2023-02-28 15:47:01.323 [WARN ] [al.protocolv5.UnknownResponseHandler] - Unknown response, length 938: A5:67:00:10:15:00:61:A3:DC:AC:8B:02:01:91:E0:29:00:3A:04:00:00:E0:32:D4:63:01:03:54:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:21:00:00:9A:B9:00:00:B0:21:03:27:00:17:00:02:CF:F5:01:15:A5:8D:00:10:15:00:62:A3:DC:AC:8B:02:01:A7:E0:29:00:51:04:00:00:E0:32:D4:63:01:03:7A:00:00:82:18:43:08:61:7F:13:87:00:1D:FF:D5:00:38:00:00:00:00:00:00:00:00:00:00:09:04:00:50:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:1E:00:53:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:0E:00:50:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:A0:75:74:15:A5:27:00:10:15:00:63:A3:DC:AC:8B:02:01:A8:E0:29:00:52:04:00:00:E0:32:D4:63:01:03:14:00:00:00:00:00:00:03:FF:0B:D7:00:30:00:0E:0D:77:00:39:00:13:7C:E1:1F:15:A5:23:00:10:15:00:64:A3:DC:AC:8B:02:01:A8:E0:29:00:52:04:00:00:E0:32:D4:63:01:03:10:00:00:00:00:00:00:00:FF:00:00:07:7A:00:00:0D:CF:3D:14:76:15:A5:89:00:10:15:00:65:A3:DC:AC:8B:02:01:A8:E0:29:00:52:04:00:00:E0:32:D4:63:01:03:76:00:03:FF:C0:05:81:FF:FF:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:21:00:00:9A:B9:00:00:B0:21:03:27:00:17:00:02:00:1C:00:0F:00:2D:00:1B:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:C0:EC:19:15:A5:01:00:10:47:00:66:A3:DC:AC:8B:00:74:15:A5:8D:00:10:15:00:67:A3:DC:AC:8B:02:01:E3:E0:29:00:8D:04:00:00:E0:32:D4:63:01:03:7A:00:00:82:18:43:08:61:7F:13:88:00:1D:FF:D7:00:37:00:00:00:00:00:00:00:00:00:00:09:31:00:4D:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:0C:00:50:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:14:00:4E:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:5C:49:9C:15:A5:27:00:10:15:00:68:A3:DC:AC:8B:02:01:E4:E0:29:00:8E:04:00:00:E0:32:D4:63:01:03:14:00:00:00:00:00:00:03:FF:0B:87:00:30:00:0E:0D:25:00:39:00:13:C4:2C:8D:15:A5:23:00:10:15:00:69:A3:DC:AC:8B:02:01:E4:E0:29:00:8E:04:00:00:E0:32:D4:63:01:03:10:00:00:00:00:00:00:00:FF:00:00:07:7A:00:00:0D:CF:3D:14:F3:15:A5:89:00:10:15:00:6A:A3:DC:AC:8B:02:01:E4:E0:29:00:8E:04:00:00:E0:32:D4:63:01:03:76:00:03:FF:C0:05:81:FF:FF:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:22:00:00:9A:BA:00:00:B0:22:03:27:00:17:00:02:00:1C:00:0F:00:2E:00:1A:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:57:54:98:15:
2023-02-28 15:49:01.329 [WARN ] [al.protocolv5.UnknownResponseHandler] - Unknown response, length 851: A5:10:00:10:15:00:6B:A3:DC:AC:8B:02:01:06:E1:29:00:B0:04:00:00:E0:32:D4:63:05:00:6B:15:A5:8D:00:10:15:00:6C:A3:DC:AC:8B:02:01:30:E1:29:00:D9:04:00:00:E0:32:D4:63:01:03:7A:00:00:82:18:43:08:61:7F:13:8A:00:1D:FF:D5:00:38:00:00:00:00:00:00:00:00:00:00:09:27:00:4F:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:05:00:53:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:14:00:50:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:41:3D:0B:15:A5:27:00:10:15:00:6D:A3:DC:AC:8B:02:01:30:E1:29:00:DA:04:00:00:E0:32:D4:63:01:03:14:00:00:00:00:00:00:03:FF:0C:26:00:31:00:0F:0D:26:00:39:00:13:6E:49:95:15:A5:23:00:10:15:00:6E:A3:DC:AC:8B:02:01:30:E1:29:00:DA:04:00:00:E0:32:D4:63:01:03:10:00:00:00:00:00:00:00:FF:00:00:07:7B:00:00:0D:CF:00:D4:15:15:A5:89:00:10:15:00:6F:A3:DC:AC:8B:02:01:31:E1:29:00:DA:04:00:00:E0:32:D4:63:01:03:76:00:03:FF:C0:05:81:FF:FF:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:23:00:00:9A:BB:00:00:B0:23:03:27:00:17:00:02:00:1C:00:0F:00:2F:00:2B:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:43:90:74:15:A5:01:00:10:47:00:70:A3:DC:AC:8B:00:7E:15:A5:8D:00:10:15:00:71:A3:DC:AC:8B:02:01:5B:E1:29:00:05:05:00:00:E0:32:D4:63:01:03:7A:00:00:82:18:43:08:61:7F:13:89:00:1D:FF:D3:00:3A:00:00:00:00:00:00:00:00:00:00:09:28:00:51:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:05:00:55:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:1B:00:52:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:23:39:53:15:A5:27:00:10:15:00:72:A3:DC:AC:8B:02:01:5C:E1:29:00:06:05:00:00:E0:32:D4:63:01:03:14:00:00:00:00:00:00:03:FF:0B:88:00:31:00:0E:0D:77:00:38:00:13:11:A4:A1:15:A5:23:00:10:15:00:73:A3:DC:AC:8B:02:01:5C:E1:29:00:06:05:00:00:E0:32:D4:63:01:03:10:00:00:00:00:00:00:00:FF:00:00:07:7B:00:00:0D:CF:00:D4:73:15:A5:89:00:10:15:00:74:A3:DC:AC:8B:02:01:5C:E1:29:00:06:05:00:00:E0:32:D4:63:01:03:76:00:03:FF:C0:05:81:FF:FF:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:24:00:00:9A:BC:00:00:B0:24:03:27:00:17:00:02:00:1C:00:0F:00:30:00:1A:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:98:04:8D:15:
2023-02-28 15:51:01.336 [WARN ] [al.protocolv5.UnknownResponseHandler] - Unknown response, length 938: A5:67:00:10:15:00:75:A3:DC:AC:8B:02:01:84:E1:29:00:2E:05:00:00:E0:32:D4:63:01:03:54:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:25:00:00:9A:BD:00:00:B0:25:03:27:00:17:00:02:9B:06:E7:15:A5:8D:00:10:15:00:7B:A3:DC:AC:8B:02:01:97:E1:29:00:41:05:00:00:E1:32:D4:63:01:03:7A:00:00:82:18:43:08:61:7F:13:89:00:1D:FF:D5:00:38:00:00:00:00:00:00:00:00:00:00:09:0A:00:50:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:0E:00:52:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:19:00:50:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:81:0B:E9:15:A5:27:00:10:15:00:7C:A3:DC:AC:8B:02:01:98:E1:29:00:42:05:00:00:E1:32:D4:63:01:03:14:00:00:00:00:00:00:03:FF:0C:26:00:2D:00:0E:0D:28:00:3A:00:13:7F:88:C4:15:A5:23:00:10:15:00:7D:A3:DC:AC:8B:02:01:98:E1:29:00:42:05:00:00:E1:32:D4:63:01:03:10:00:00:00:00:00:00:00:FF:00:00:07:7C:00:00:0D:D0:F4:DC:F4:15:A5:89:00:10:15:00:7E:A3:DC:AC:8B:02:01:98:E1:29:00:42:05:00:00:E1:32:D4:63:01:03:76:00:03:FF:C0:05:81:FF:FF:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:25:00:00:9A:BD:00:00:B0:25:03:27:00:17:00:02:00:1C:00:0F:00:31:00:1B:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:C3:C4:00:15:A5:01:00:10:47:00:7F:A3:DC:AC:8B:00:8D:15:A5:8D:00:10:15:00:80:A3:DC:AC:8B:02:01:D3:E1:29:00:7D:05:00:00:E1:32:D4:63:01:03:7A:00:00:82:18:43:08:61:7F:13:88:00:1C:FF:D7:00:36:00:00:00:00:00:00:00:00:00:00:09:16:00:4D:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:06:00:50:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:1F:00:4D:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:36:39:49:15:A5:27:00:10:15:00:81:A3:DC:AC:8B:02:01:D4:E1:29:00:7E:05:00:00:E1:32:D4:63:01:03:14:00:00:00:00:00:00:03:FF:0B:D9:00:2C:00:0D:0D:25:00:39:00:13:5A:05:45:15:A5:23:00:10:15:00:82:A3:DC:AC:8B:02:01:D4:E1:29:00:7E:05:00:00:E1:32:D4:63:01:03:10:00:00:00:00:00:00:00:FF:00:00:07:7C:00:00:0D:D0:F4:DC:71:15:A5:89:00:10:15:00:83:A3:DC:AC:8B:02:01:D4:E1:29:00:7E:05:00:00:E1:32:D4:63:01:03:76:00:03:FF:C0:05:81:FF:FF:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:26:00:00:9A:BE:00:00:B0:26:03:27:00:17:00:02:00:1C:00:0F:00:32:00:1C:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:DC:F4:CB:15:
2023-02-28 15:53:01.342 [WARN ] [al.protocolv5.UnknownResponseHandler] - Unknown response, length 851: A5:10:00:10:15:00:84:A3:DC:AC:8B:02:01:F6:E1:29:00:A0:05:00:00:E1:32:D4:63:05:00:66:15:A5:8D:00:10:15:00:85:A3:DC:AC:8B:02:01:25:E2:29:00:CF:05:00:00:E1:32:D4:63:01:03:7A:00:00:82:18:43:08:61:7F:13:85:00:1C:FF:D5:00:38:00:00:00:00:00:00:00:00:00:00:09:28:00:50:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:0D:00:52:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:10:00:50:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:40:5E:31:15:A5:27:00:10:15:00:86:A3:DC:AC:8B:02:01:25:E2:29:00:CF:05:00:00:E1:32:D4:63:01:03:14:00:00:00:00:00:00:03:FF:0C:77:00:28:00:0C:0D:76:00:35:00:12:3E:EB:9D:15:A5:23:00:10:15:00:87:A3:DC:AC:8B:02:01:25:E2:29:00:D0:05:00:00:E1:32:D4:63:01:03:10:00:00:00:00:00:00:00:FF:00:00:07:7D:00:00:0D:D0:C9:1C:30:15:A5:89:00:10:15:00:88:A3:DC:AC:8B:02:01:26:E2:29:00:D0:05:00:00:E1:32:D4:63:01:03:76:00:03:FF:C0:05:81:FF:FF:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:27:00:00:9A:BF:00:00:B0:27:03:27:00:17:00:02:00:1C:00:0F:00:33:00:32:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:5B:E6:00:15:A5:01:00:10:47:00:89:A3:DC:AC:8B:00:97:15:A5:8D:00:10:15:00:8A:A3:DC:AC:8B:02:01:5F:E2:29:00:09:06:00:00:E1:32:D4:63:01:03:7A:00:00:82:18:43:08:61:7F:13:86:00:1C:FF:D7:00:36:00:00:00:00:00:00:00:00:00:00:09:2A:00:4D:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:0F:00:50:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:06:00:4D:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:9A:A9:43:15:A5:27:00:10:15:00:8B:A3:DC:AC:8B:02:01:5F:E2:29:00:0A:06:00:00:E1:32:D4:63:01:03:14:00:00:00:00:00:00:03:FF:0B:D7:00:2B:00:0D:0D:77:00:36:00:12:00:D2:26:15:A5:23:00:10:15:00:8C:A3:DC:AC:8B:02:01:60:E2:29:00:0A:06:00:00:E1:32:D4:63:01:03:10:00:00:00:00:00:00:00:FF:00:00:07:7D:00:00:0D:D0:C9:1C:AB:15:A5:89:00:10:15:00:8D:A3:DC:AC:8B:02:01:60:E2:29:00:0A:06:00:00:E1:32:D4:63:01:03:76:00:03:FF:C0:05:81:FF:FF:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:28:00:00:9A:C0:00:00:B0:28:03:27:00:17:00:02:00:1C:00:0F:00:34:00:2F:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:2C:13:79:15:
2023-02-28 15:55:01.349 [WARN ] [al.protocolv5.UnknownResponseHandler] - Unknown response, length 924: A5:67:00:10:15:00:8E:A3:DC:AC:8B:02:01:73:E2:29:00:1E:06:00:00:E1:32:D4:63:01:03:54:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:29:00:00:9A:C1:00:00:B0:29:03:27:00:17:00:02:CE:92:AD:15:A5:8D:00:10:15:00:8F:A3:DC:AC:8B:02:01:9B:E2:29:00:45:06:00:00:E1:32:D4:63:01:03:7A:00:00:82:18:43:08:61:7F:13:85:00:1B:FF:D5:00:37:00:00:00:00:00:00:00:00:00:00:09:2E:00:4E:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:16:00:51:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:0E:00:4E:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:49:9A:73:15:A5:27:00:10:15:00:90:A3:DC:AC:8B:02:01:9B:E2:29:00:46:06:00:00:E1:32:D4:63:01:03:14:00:00:00:00:00:00:03:FF:0C:28:00:2B:00:0D:0C:D8:00:37:00:12:42:07:CD:15:A5:23:00:10:15:00:91:A3:DC:AC:8B:02:01:9C:E2:29:00:46:06:00:00:E1:32:D4:63:01:03:10:00:00:00:00:00:00:00:FF:00:00:07:7E:00:00:0D:D0:8D:1C:ED:15:A5:89:00:10:15:00:92:A3:DC:AC:8B:02:01:9C:E2:29:00:46:06:00:00:E1:32:D4:63:01:03:76:00:03:FF:C0:05:81:FF:FF:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:29:00:00:9A:C1:00:00:B0:29:03:27:00:17:00:02:00:1C:00:0F:00:35:00:30:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:D9:F9:8E:15:A5:8D:00:10:15:00:97:A3:DC:AC:8B:02:01:D8:E2:29:00:82:06:00:00:E1:32:D4:63:01:03:7A:00:00:82:18:43:08:61:7F:13:86:00:1C:FF:D3:00:39:00:00:00:00:00:00:00:00:00:00:09:32:00:4F:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:1A:00:54:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:08:FE:00:51:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:E2:54:48:15:A5:27:00:10:15:00:98:A3:DC:AC:8B:02:01:D8:E2:29:00:83:06:00:00:E1:32:D4:63:01:03:14:00:00:00:00:00:00:03:FF:0B:86:00:2E:00:0D:0D:76:00:33:00:11:57:BF:16:15:A5:23:00:10:15:00:99:A3:DC:AC:8B:02:01:D8:E2:29:00:83:06:00:00:E1:32:D4:63:01:03:10:00:00:00:00:00:00:00:FF:00:00:07:7E:00:00:0D:D0:8D:1C:6E:15:A5:89:00:10:15:00:9A:A3:DC:AC:8B:02:01:D9:E2:29:00:83:06:00:00:E1:32:D4:63:01:03:76:00:03:FF:C0:05:81:FF:FF:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:2A:00:00:9A:C2:00:00:B0:2A:03:27:00:17:00:02:00:1C:00:0F:00:36:00:31:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:4E:41:D2:15:
2023-02-28 15:57:01.356 [WARN ] [al.protocolv5.UnknownResponseHandler] - Unknown response, length 851: A5:10:00:10:15:00:9B:A3:DC:AC:8B:02:01:E6:E2:29:00:91:06:00:00:E1:32:D4:63:05:00:60:15:A5:8D:00:10:15:00:9C:A3:DC:AC:8B:02:01:1B:E3:29:00:C5:06:00:00:E1:32:D4:63:01:03:7A:00:00:82:18:43:08:61:7F:13:87:00:1B:FF:D7:00:36:00:00:00:00:00:00:00:00:00:00:09:2F:00:4C:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:0C:00:50:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:08:FE:00:4D:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:C6:FB:44:15:A5:27:00:10:15:00:9D:A3:DC:AC:8B:02:01:1B:E3:29:00:C6:06:00:00:E1:32:D4:63:01:03:14:00:00:00:00:00:00:03:FF:0B:D8:00:28:00:0C:0D:79:00:35:00:12:AD:37:C1:15:A5:23:00:10:15:00:9E:A3:DC:AC:8B:02:01:1B:E3:29:00:C6:06:00:00:E1:32:D4:63:01:03:10:00:00:00:00:00:00:00:FF:00:00:07:7F:00:00:0D:D0:B0:DC:DE:15:A5:89:00:10:15:00:9F:A3:DC:AC:8B:02:01:1C:E3:29:00:C6:06:00:00:E1:32:D4:63:01:03:76:00:03:FF:C0:05:81:FF:FF:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:2B:00:00:9A:C3:00:00:B0:2B:03:27:00:17:00:02:00:1C:00:0F:00:37:00:38:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:F7:E0:B1:15:A5:01:00:10:47:00:A0:A3:DC:AC:8B:00:AE:15:A5:8D:00:10:15:00:A1:A3:DC:AC:8B:02:01:50:E3:29:00:FA:06:00:00:E1:32:D4:63:01:03:7A:00:00:82:18:43:08:61:7F:13:86:00:1B:FF:D7:00:36:00:00:00:00:00:00:00:00:00:00:09:2E:00:4D:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:0A:00:4F:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:1A:00:4C:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:02:BB:C7:15:A5:27:00:10:15:00:A2:A3:DC:AC:8B:02:01:50:E3:29:00:FB:06:00:00:E1:32:D4:63:01:03:14:00:00:00:00:00:00:03:FF:0C:27:00:27:00:0C:0D:26:00:36:00:12:4E:16:AD:15:A5:23:00:10:15:00:A3:A3:DC:AC:8B:02:01:50:E3:29:00:FB:06:00:00:E1:32:D4:63:01:03:10:00:00:00:00:00:00:00:FF:00:00:07:7F:00:00:0D:D0:B0:DC:4D:15:A5:89:00:10:15:00:A4:A3:DC:AC:8B:02:01:51:E3:29:00:FB:06:00:00:E1:32:D4:63:01:03:76:00:03:FF:C0:05:81:FF:FF:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:2C:00:00:9A:C4:00:00:B0:2C:03:27:00:17:00:02:00:1C:00:0F:00:38:00:31:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:93:80:59:15:
2023-02-28 15:59:01.361 [WARN ] [al.protocolv5.UnknownResponseHandler] - Unknown response, length 938: A5:67:00:10:15:00:A5:A3:DC:AC:8B:02:01:71:E3:29:00:1C:07:00:00:E1:32:D4:63:01:03:54:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:2D:00:00:9A:C5:00:00:B0:2D:03:27:00:17:00:02:9A:61:69:15:A5:8D:00:10:15:00:A6:A3:DC:AC:8B:02:01:8A:E3:29:00:35:07:00:00:E1:32:D4:63:01:03:7A:00:00:82:18:43:08:61:7F:13:86:00:1B:FF:D6:00:36:00:00:00:00:00:00:00:00:00:00:09:32:00:4D:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:02:00:4F:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:0C:00:4D:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:EF:B6:18:15:A5:27:00:10:15:00:A7:A3:DC:AC:8B:02:01:8B:E3:29:00:36:07:00:00:E1:32:D4:63:01:03:14:00:00:00:00:00:00:03:FF:0B:D6:00:2A:00:0C:0D:76:00:32:00:11:25:7E:64:15:A5:23:00:10:15:00:A8:A3:DC:AC:8B:02:01:8B:E3:29:00:36:07:00:00:E1:32:D4:63:01:03:10:00:00:00:00:00:00:00:FF:00:00:07:7F:00:00:0D:D0:B0:DC:C9:15:A5:89:00:10:15:00:A9:A3:DC:AC:8B:02:01:8C:E3:29:00:36:07:00:00:E1:32:D4:63:01:03:76:00:03:FF:C0:05:81:FF:FF:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:2D:00:00:9A:C5:00:00:B0:2D:03:27:00:17:00:02:00:1C:00:0F:00:39:00:30:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:C8:40:CD:15:A5:01:00:10:47:00:AA:A3:DC:AC:8B:00:B8:15:A5:8D:00:10:15:00:AB:A3:DC:AC:8B:02:01:C8:E3:29:00:72:07:00:00:E1:32:D4:63:01:03:7A:00:00:82:18:43:08:61:7F:13:89:00:1A:FF:D5:00:37:00:00:00:00:00:00:00:00:00:00:09:2B:00:4E:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:1E:00:50:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:04:00:4E:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:2A:1C:4B:15:A5:27:00:10:15:00:AC:A3:DC:AC:8B:02:01:C8:E3:29:00:73:07:00:00:E1:32:D4:63:01:03:14:00:00:00:00:00:00:03:FF:0B:D9:00:27:00:0C:0D:77:00:33:00:11:21:FA:5D:15:A5:23:00:10:15:00:AD:A3:DC:AC:8B:02:01:C8:E3:29:00:73:07:00:00:E1:32:D4:63:01:03:10:00:00:00:00:00:00:00:FF:00:00:07:80:00:00:0D:D0:A4:C8:29:15:A5:89:00:10:15:00:AE:A3:DC:AC:8B:02:01:C9:E3:29:00:73:07:00:00:E1:32:D4:63:01:03:76:00:03:FF:C0:05:81:FF:FF:00:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:3C:00:23:00:00:00:1A:00:00:00:00:00:00:00:00:00:00:00:19:00:00:00:00:00:00:00:00:00:00:02:2E:00:00:9A:C6:00:00:B0:2E:03:27:00:17:00:02:00:1C:00:0F:00:3A:00:31:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:5F:F8:A0:15:
Thx, this is probably data I need exactly to move forward.
What is your peak power from inverter?
8.8kWp. Model is Sofar 8.8KTLX-G3.
Logs above were registered when there was a very low power from PV.
I have trying to decode temperature sensors. Is those temps possible?
ambient 35 celsius, radiator 26 celsius, module 25 celsius
gid frequency 49,98 hz, power 300W
