New Binding - OpenGarage Controller
Hi All,
I’m currently working on a binding for the OpenGarage (https://opensprinkler.com/product/opengarage/) controller.
An initial build is at: http://smedley.id.au/tmp/org.openhab.binding.opengarage-2.5.0-SNAPSHOT.jar
Source is currently at https://github.com/psmedley/openhab2-addons/tree/opengarage
Feedback appreciated.
Cheers,
Paul
NB: if run under Openhab 2.4, a newer version of gson is needed.
From karaf:
bundle:install http://central.maven.org/maven2/com/google/code/gson/gson/2.8.5/gson-2.8.5.jar
Or download the gson jar and drop it in the addons folder.
I cant get the binding to work - it stays at “UNINITIALIZED - HANDLER_CONFIGURATION_PENDING”
I did as written in the Docs - even tried to give all options.
Any pointers would be highly appreciated.
TIA
nevermind - looking at the source at openhab-addons/bundles/org.openhab.binding.opengarage/src/main/java/org/openhab/binding/opengarage/internal/OpenGarageConfiguration.java at 2.5.x · openhab/openhab-addons · GitHub i found the key is “hostname” not “host” as in the dok. i will submit a MR for it. → [opengarage] Fixes README.md with correct config value by rufinus · Pull Request #6931 · openhab/openhab-addons · GitHub
Hi All,
I added a ‘Contact’ and ‘RollerShutter’ item for help with google assistance and rules.
PR for the change is at [opengarage] Add Contact & Rollershutter handling by psmedley · Pull Request #7480 · openhab/openhab-addons · GitHub
Testing jar is at http://smedley.id.au/tmp/org.openhab.binding.opengarage-2.5.5-SNAPSHOT.jar
Cheers,
Paul
Corrected PR is https://github.com/openhab/openhab-addons/pull/7486
