@Anquietas86 what do you mean with the 2.0 version? - The binding I was working on - which should autodetect and work for theoretically all Resol devices never had a 2.0 version, as I started the development in the 2.3 codebase.
And yes, there is no proper versioning so far, only the name of the jar file which contains a date as I provide them, sorry for that. Do you remember which file was still working?
Ah, sorry for the confusion. That is actually a completely different implementation done by @Laurens, but as that was not easy to maintain and my resol device was not supported I just redid a new implementation using the resol-vbus-java library.
Thanks for these valuable informations!
Still my vbus bridge is offlineā¦used the internal private ip address + port 7053 (remote port / live data port) and noted down the serial number from the cgi scriptā¦still not online. Is there a reboot-requirement to make it work properly?
Normally no reboot is required, Iād say. But after exchaning the .jar I normally do a restart of openhab (but donāt know whether it would be needed). And between some versions I posted here, it was necessary to remove all things related to the binding and readd them (sorry for that inconvenience - it is work in progress).
Can you try to enable TRACE logging for the binding? For me it worked by adding the follwing to file /var/lib/openhab2/etc/org.ops4j.pax.logging.cfg
# Resol logger
log4j2.logger.resol.name = org.openhab.binding.resol
log4j2.logger.resol.level = TRACE # set back to INFO or WARN after you made it work
log4j2.logger.resol.appenderRefs = stdout
log4j2.logger.resol.appenderRef.stdout.ref = STDOUT
@ramack ā¦ i found out what was the problem right now. despite to what i have seen in DL2 config (port 7053) i now tried the default value of 3000 + vbus as pwdā¦and it works. sorry for the ādramaā - hope this feedback may save some otherās time. Cheers
I installed your latest version today and tested with both BX an FK.
For me it is running fine now. OpenHAB is receiving regualar state changes for all sensor values. No more Java exceptions.
Good work! Thanks for this quick solution.
@ramack thanks for the information about the market source. Iāve seen it when i read your great intro doc online. As iām not familiar with the IOT market,ā¦i guess first i have to remove the JAR file and readd it via paperuiā¦
But will - due to the market - the JAR be updated in background automatically whenever you add something new? or how does it work in the market case if i want to update to the latest version?
Or is this the greatest advantage + maybe not necessarily remove and add things after each updateā¦
Honestly I donāt yet know how it will behave with updates, but I do not expect, that they are just magically pulled into your installation. The need to remove and readd the things is only due to changes in the channel types. I hope this is not needen in future. The marketplace will not help here. That just simplifies the setup, as you donāt nees to handle the jar files manually.
@ramack
Once again a big thank you for the openhab 2 update, it works perfectly in my OH 2.2 with a Resol Vbus Lan adapter connected to a Cosmo Multi 2 heating controller. This was the last missing binding to run a successfully working openhab 2 instance for me!! Great
Do you know if the RESOL VBUS binding is working with the RESOL KM2?
If itās working for you, could you explain me your configuration? Whatās your vbus bridge config? I canāt connect the binding and KM2
Thank you
I myself have only a VBUS-LAN interface (as I understand the predecessor of the KM2), but I would expect, that it should work also with KM2. Normally I would hope, that after adding the binding a new thing - the VBUS-LAN bridge should be automatically found.
Was that the case?
If you have it, the only thing that you normally need to adjust is the password. - And the binding intentionally even doesnāt try the default password, because I strongly recommend to change that.
Do you know the IP address of your KM2? - Did you a assign a static IP (either in the KM2 web interface your your router/DHCP server)?
Can you do a nmap scan of that IP and at least the port 7053?
nmap -p 7053
Can you telnet this port if it is open and see whether it responds with something like
Trying <KM2-IP-ADDRESS>...
Connected to <KM2-IP-ADDRESS>.
Escape character is '^]'.
+HELLO
You might want to add and configure the bridge thing manually, normally the IP address should be sufficient (beside the password).
Last but not least, what do you really see and what do you expect?
Hi @ramack,
Thank you for your quick reply. Here are some more details:
two things are created:
The RESOL device, named āResol KM2ā
The āBridge VLANBus Adapterā
In the Resol device, Iāve manually configure it to use the āBridge VLANBus Adapterā.
The IP address of the device is FIXED : 192.168.0.200
The 2 things are OFFLINE. The Device says itās due to the adapter ā¦ Logic :') but on the āBridge VLANBus Adapterā, there is communication error: āServer returned HTTP response code: 502 for URL: http://192.168.0.200:80/cgi-bin/get_resol_device_informationā
Iāve manually tested this URL, and, indeed, not a valid one. The response is :
Bad Gateway
The process did not produce any response
A full nmap command on the device:
Initiating ARP Ping Scan at 10:49
Scanning 192.168.0.200 [1 port]
Completed ARP Ping Scan at 10:49, 0.31s elapsed (1 total hosts)
Initiating Parallel DNS resolution of 1 host. at 10:49
Completed Parallel DNS resolution of 1 host. at 10:49, 0.01s elapsed
Initiating SYN Stealth Scan at 10:49
Scanning 192.168.0.200 [65535 ports]
Discovered open port 8080/tcp on 192.168.0.200
Discovered open port 443/tcp on 192.168.0.200
Discovered open port 53/tcp on 192.168.0.200
Discovered open port 80/tcp on 192.168.0.200
Discovered open port 22/tcp on 192.168.0.200
Discovered open port 1883/tcp on 192.168.0.200
Discovered open port 7053/tcp on 192.168.0.200
Discovered open port 57053/tcp on 192.168.0.200
Completed SYN Stealth Scan at 10:49, 8.97s elapsed (65535 total ports)
Initiating Service scan at 10:49
Result of the NMAP -p 7053 command:
PORT STATE SERVICE
7053/tcp open unknown
MAC Address: A8:40:41:18:FB:27 (Dragino Technology, Limited)
And indeed, the TELNET command is working.
So, my guess is that the requested URL is not working on the KM2 device and that the VBUSLan Adapter is bloquing on it
Thank you for your help. Do you need additional information?
yann
Wow, that was a good set of data you provided here. I think I know whatās going on, an created a ticket for the used library. Please give us a few days to check and fix itā¦
