Hi everyone, I recently purchased a MCO Home A8-9 Multisensor and wanted to use it with OpenHAB, but the Z-Wave Binding did not support this device at the time of purchase, so I requested access to the Z-Wave Database to add an entry myself; I successfully created and updated the entry, reinstalled the Z-Wave Binding via the zzManualInstaller.sh script and now the Binding acknowledges the device and all its Channels and properties.
HOWEVER, no matter what Channel I decide to link, no state updates are sent to OpenHAB Items. I checked for DEBUG logs of the Z-Wave Binding and there’s this line that caught my attention (Node 14 is the MCO Home sensor):
2020-02-03 12:07:36.200 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: No data from device, but it was ACK’d. Possibly not supported? (Try 2)
I’m not sure if I can do anything else about this. Could there be something wrong in how I added the entry into the Z-Wave Database? (I had to force recognition of two Channels, one being a sensor_loudness and the other sensor_voc, by masquerading them as other types or Channels, since their correspectives were not listed in the Channel Types section of the Z-Wave Database Device List; beyond that, I should have inserted all other data correctly) Or could it be an issue internal to the Z-Wave Binding?
Any help is appreciated.
The device entry in quesiton:
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/1198
An extended version of Binding logs:
2020-02-03 12:07:31.166 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=125, payload=7D 00 00 03 00 CF 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2020-02-03 12:07:31.169 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=125, payload=7D 00 00 03 00 CF 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2020-02-03 12:07:31.171 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 147: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 125
2020-02-03 12:07:31.172 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2020-02-03 12:07:31.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 147: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 125
2020-02-03 12:07:31.176 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 147: (Callback 125)
2020-02-03 12:07:31.177 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2020-02-03 12:07:31.179 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 147: callback 125
2020-02-03 12:07:31.181 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=125, payload=7D 00 00 03 00 CF 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2020-02-03 12:07:31.183 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 14: SendData Request. CallBack ID = 125, Status = Transmission complete and ACK received(0)
2020-02-03 12:07:31.185 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 147: Advanced to WAIT_DATA
2020-02-03 12:07:31.187 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: TID 147: Transaction not completed
2020-02-03 12:07:31.189 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-02-03 12:07:31.190 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-02-03 12:07:36.187 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 14: TID 147: Timeout at state WAIT_DATA. 3 retries remaining.
2020-02-03 12:07:36.189 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 147: Transaction CANCELLED
2020-02-03 12:07:36.191 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-02-03 12:07:36.193 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: notifyTransactionResponse TID:147 CANCELLED
2020-02-03 12:07:36.196 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-02-03 12:07:36.196 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 147: Transaction event listener: DONE: CANCELLED →
2020-02-03 12:07:36.198 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node Init response (2) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@3029db
2020-02-03 12:07:41.104 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: ZWaveCommandClassTransactionPayload - send to node
2020-02-03 12:07:41.107 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: SECURITY not supported
2020-02-03 12:07:41.109 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: Command Class COMMAND_CLASS_VERSION is NOT required to be secured
2020-02-03 12:07:41.110 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@1d47dc5
2020-02-03 12:07:41.112 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: Adding to device queue
2020-02-03 12:07:41.114 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: Added 148 to queue - size 6
2020-02-03 12:07:41.115 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-02-03 12:07:41.118 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 0E 03 86 13 59 25 7E 7C
2020-02-03 12:07:41.120 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 14: Sending REQUEST Message = 01 0A 00 13 0E 03 86 13 59 25 7E 7C
2020-02-03 12:07:41.122 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2020-02-03 12:07:41.124 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 148: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 126
2020-02-03 12:07:41.124 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2020-02-03 12:07:41.126 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-02-03 12:07:41.128 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-02-03 12:07:41.131 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 148: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 126
2020-02-03 12:07:41.131 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2020-02-03 12:07:41.133 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2020-02-03 12:07:41.135 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-02-03 12:07:41.135 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-02-03 12:07:41.137 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-02-03 12:07:41.141 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-02-03 12:07:41.143 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 148: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 126
2020-02-03 12:07:41.145 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2020-02-03 12:07:41.149 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 148: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 126
2020-02-03 12:07:41.151 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-02-03 12:07:41.153 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 14: sentData successfully placed on stack.
2020-02-03 12:07:41.155 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 7E 00 00 02 00 D0 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 59
2020-02-03 12:07:41.156 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 148: Advanced to WAIT_REQUEST
2020-02-03 12:07:41.158 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: TID 148: Transaction not completed
2020-02-03 12:07:41.160 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-02-03 12:07:41.161 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-02-03 12:07:41.166 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=126, payload=7E 00 00 02 00 D0 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2020-02-03 12:07:41.167 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=126, payload=7E 00 00 02 00 D0 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2020-02-03 12:07:41.168 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 148: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 126
2020-02-03 12:07:41.169 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2020-02-03 12:07:41.170 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 148: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 126
2020-02-03 12:07:41.170 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 148: (Callback 126)
2020-02-03 12:07:41.171 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2020-02-03 12:07:41.172 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 148: callback 126
2020-02-03 12:07:41.173 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=126, payload=7E 00 00 02 00 D0 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2020-02-03 12:07:41.174 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 14: SendData Request. CallBack ID = 126, Status = Transmission complete and ACK received(0)
2020-02-03 12:07:41.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 148: Advanced to WAIT_DATA
2020-02-03 12:07:41.176 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: TID 148: Transaction not completed
2020-02-03 12:07:41.177 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-02-03 12:07:41.177 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
