Reviving one of the many
“Why does eufy not provide an API”
topics. There is an interesting development on the … dare I say the H word …
This is definitely beyond my developers pay grade, but can the openhab community consider getting this sorted for our platform, too?
Share your Projects!
Custom Integrations
Hi everyone, I’ve been working on Eufy Mega Security, an open-source Home Assistant app and custom integration for Eufy cameras, especially the battery-powered models that do not provide a permanent RTSP stream. The project started with a simple...
Reading time: 3 mins 🕑
Likes: 16 ❤
Darkem
(Kim)
October 2, 2026, 12:53pm
2
Wow, super nice!
I tried it quick with “doorbell pressed” as example.
Here is what I did:
Maybe you have to look into your mails, copy the verification code, paste it into the options.json and restart the container.
Now have a look in the data directory for the api_token
Than I created a HTTP-Thing:
Base-URL: http://localhost:3218/api/cameras
Refresh Time: 1s
Advanced Options the Authentication to Token/Bearer and paste the Token into the password field.
Create a new channel, type Switch for “doorbell pressed”
Status-Transformation:
JSONPATH:$.cameras[?(@.serial==‘MY_DOORBELL_SERIAL_NO’)].doorbellPressed
On-Value: true
Off-Value: false
That’s it, working like a charm. Can’t wait to test more things with this Gateway.
To get all status items and the correct serial number you can use this curl command to request it from the API:
curl -H "Authorization: Bearer YOUR_API_TOKEN" -s http://localhost:3218/api/cameras | jq
cheers !!! that also worked for me, mostly.
Any idea, on how we get a livefeed?
or - as an addition - replay the the event video recordings from teh camera ?
