Hello @vossivossi
Im using this script:
Running on Debian linux.
Best regards
Hi Nils,
I have now spent a week trying to get my Fibaro FGS-223 Switch to work with OpenHAB2 on my MacBook Air with UZB stick. I tried to add it through Paper UI on openHAB2 and when I do so, I see the UZB stick flashing blue. Clicking the B-button 3 times on the FGS-223 should usually start the inclusion process, but I only hear the relais click three times (and switch the light), but it does not do anything on openHAB. I have already excluded the security feature for the inclusion process in HABmin. I really donât know if this is a problem with the FGS 223 or with my openHAB configuration or with the UZB stick. In principle on the Mac with the UZB stick everything looks fine - except for that it does not receive any signal from the FGS-223. I have already reset the FGS 223 various times, but that did not change anything. The Fibaro support team seems tu have no idea. I wonder if you could help me understand the problem?
Please find below the log.
Best regards and many thanks in advance!
Andreas
ZWAVE Log
05:26:25.457 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/tty.usbmodemFA131â
05:26:25.503 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
05:26:25.507 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
05:26:25.518 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
05:26:25.519 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
05:26:28.669 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
05:26:28.670 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
05:26:28.670 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
05:26:28.670 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
05:26:28.670 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 1
05:26:28.671 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
23:52:16.180 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - Starting ZWave inclusion scan for zwave:serial_zstick:0ce9f183
23:52:16.181 [DEBUG] [ve.internal.protocol.ZWaveController] - ZWave controller start inclusion - mode 2
23:52:16.182 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Setting controller into INCLUSION mode, highPower:true networkWide:true.
23:52:16.182 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
23:52:16.182 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
23:52:16.186 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 4A C1 01 70
23:52:16.186 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A C1 01 70
23:52:16.189 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4A 01 01 00 00 B2
23:52:16.191 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
23:52:16.191 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 07 00 4A 01 01 00 00 B2
23:52:16.191 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 07 00 4A 01 01 00 00 B2
23:52:16.192 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 01 00 00
23:52:16.192 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Add Node: Learn ready.
23:52:16.192 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInclusionEvent
23:52:16.193 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=C1 01
23:52:16.193 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 01 00 00
23:52:16.194 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=AddNodeToNetwork, callback id=0, expected=AddNodeToNetwork, cancelled=false transaction complete!
23:52:16.194 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
23:52:16.195 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Response processed after 8ms/169ms.
23:52:46.184 [DEBUG] [ve.internal.protocol.ZWaveController] - Stopping inclusion timer.
23:52:46.185 [DEBUG] [ve.internal.protocol.ZWaveController] - Ending inclusion mode.
23:52:46.185 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Ending INCLUSION mode.
23:52:46.185 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
23:52:46.186 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
23:52:46.186 [DEBUG] [ve.internal.protocol.ZWaveController] - ZWave controller end inclusion
23:52:46.186 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 4A 05 01 B4
23:52:46.186 [DEBUG] [ve.internal.protocol.ZWaveController] - Stopping inclusion timer.
23:52:46.186 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A 05 01 B4
23:52:46.187 [ERROR] [ve.internal.protocol.ZWaveController] - Neither inclusion nor exclusion was active!
23:52:46.345 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4A 01 06 00 00 B5
23:52:46.346 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
23:52:46.347 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 07 00 4A 01 06 00 00 B5
23:52:46.347 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 07 00 4A 01 06 00 00 B5
23:52:46.348 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 06 00 00
23:52:46.348 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Add Node: Done.
23:52:46.348 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInclusionEvent
23:52:46.349 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=05 01
23:52:46.350 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 06 00 00
23:52:46.350 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=AddNodeToNetwork, callback id=0, expected=AddNodeToNetwork, cancelled=false transaction complete!
23:52:46.350 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
23:52:46.351 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Response processed after 164ms/169ms.
I bought one of those devices two weeks ago and I can confirm that it works fine with openHAB2 (RPi, Zwave.me USB stick)
You should not hear the relay clicking while pressing the B-Button three times! Either the device is faulty or maybe you did not reset the device correctly (I also had to reset the FGS223 before inclusion worked).
Reset: Apply power, hold the B-button until the yellow light turns on, while the yellow light is on (that is only the case for 2 or 3 seconds), release the button and click it again once. After successful reset the red light comes on for some seconds.
Then try the inclusion again âŠ
BTW, it is recommended to use HABmin for dealing with zwave devices, it is specifically designed for that.
I also spent several days to sort out the issues with these devices and OH2. It now works.
Make sure that you use the inclusion function from within OH2 (worked for me with both Paper UI and Habmin) when your Z-Wave stick is connected. I had trouble when I included the devices first decentrally with my Aeon Z-Stick5 and then started OH2, as in these cases the different endpoints were never usable.
Additionally I had to add the association group for lifeline to the OH controller (I did this with Habmin). Then it worked for me.
You can avoid that by setting âController is Masterâ in your âZ-Wave network settingsâ for your USB Stick. You need to switch to âToolsâ âShow advanced settingsâ though.
Thanks for the prompt support. Glad to hear that it should work with OpenHAB2, so it should be either an issue with the UZB stick on the Mac or a problem with this particular device.
I have reset the FGS 223 several times. It starts with a pale blue (white?) LED, then turns green, then purple and then yellow. When I then release the button, it does not do anything, so it does not turn red for a few seconds. Is that a malfunction of the device? Also: should it indicate that itâs in inclusion mode by any LED signal?
Best regards,
Andreas
I just activated the switch to âShow advanced settingsâ but the âController is Masterâ setting was already active. Nonetheless I had to set the lifeline association for all FGS-223 in Habmin to make it run (I spent the complete Sunday yesterday with these devices⊠) I am running OH2.0.0 Release Build with 2.0.0 Z-Wave binding on Windows with Aeon Z-Stick 5.
You forgot one step: as long as the led is yellow, release the button and click it again. Then the led should turn red.
Hmmm, actually the Lifeline association should have been set automatically because of âMastercontroller trueâ.
But as long as it is set, it doesnât matter ⊠itâs just for convenience.
Hi sihui,
thanks for that clarification. I just returned home and tried it out and have now been able to reset the FGS-232 with a red LED signal in response. It however did not change anything with regards to the inclusion. The log before and after the reset is identical. Is the UZB stick not working well or is the FGS-232 broken or do you have any other idea?
Best regards,
Andreas
Iâm using the same one and it is working fine.
I had to repeat the inclusion process two or three times until it worked. Keep going âŠ
I have now changed the UZB stick against a Z-Stick and have been able to include the device. It works well for Switch 1, however Switch 2 keeps me confused. When I switch it on, it does turn on the lights, but if I switch it off, then it ignores it completely. This was already the case before I included the device through Z-WAVE when I switched it with the manual switch, but I had hoped to be able to change the parameters of switch 2 so that it works appropriately. I however donât find a way to configure it right.
Initially I had it configured as toggle switch and then showed the following behaviour for switching through ZWAVE:
I then changed it to switch parameter to âtoggle stableâ and thereafter the behaviour for switching through ZWAVE is as desired, but the switching with the manual switch still remains broken:
Any idea, how I can fix this issue?
Thanks,
Andreas
Make sure you have the correct channels:
S1 = switch_binary1
S2 = switch_binary2
Where can I look this up?
If I look at HABmin under channels, it shows
"Switch the power on and off" behind every switch. Below in the last section it says
Z-Wave Plus Node TypeON_OFF_POWER_SWITCH
Basic ClassROUTING_SLAVE
StandardklasseBINARY_SWITCH
Specific ClassPOWER_SWITCH_BINARY
Also, I forgot to mention that when I switch S2 on the manual switch and it turns the light on, on BasicUI the linked switch item stays unchanged (off).
Andreas
I do my setup manually, so it looks like this in the items file:
Switch FibFGS223_1_Sw_1 "Living Room 1" (gRestore) { channel="zwave:device:158b44ebf65:node30:switch_binary1" }
Switch FibFGS223_1_Sw_2 "Living Room 2" (gRestore) { channel="zwave:device:158b44ebf65:node30:switch_binary2" }
If you have configured it through HABmin or PaperUI, you should see the channel under âConfigurationâ â âThingsâ
The first switch from the top is switch_binary, donât use it, the second is switch_binary1, link that to your S1 item switch, the third switch is binary_switch2, link that to your S2 item switch.
BTW, what version of the zwave binding (and openHAB runtime) are you using? You will definitely need one of the newer zwave snapshot 2.1.x bindings, it wonât work with the stable 2.0.0 zwave binding.
i know the last post is already a bit older but i was wandering if this problem also occur in the latest snapshot build #1099
in combination with the latest dev. Z-Wave binding (secure).
iâm asking cause i have exactly the same problem with my FGS-223. the channel for Switch 1 and/or 2 are not getting updated in OH2 if i use the physical switch.
my FGS-223 is on firmware 3.2
i also tried to set the Association Group for Lifeline to the openHAB controller, however the entry seems to get removed later, at least after saving and refreshing the screen its empty again?
Iâm using those switches now for a year, and that problem never occured
Again, make sure you:
i wish i had that luck.
checked everything and the config looks ok. however if i use the toggle switch (physical switch) only the Switch item in HABmin is changing. not the actual switch 1.
one more thing, if i use the physical switch which is connected to S1 the light on Q1 gets turned ON, however in the log only switch_binary gets triggered not switch_binary1
2017-12-01 23:33:18.402 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Application Command Request (ALIVE:DONE)
2017-12-01 23:33:18.405 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: resetResendCount initComplete=true isDead=false
2017-12-01 23:33:18.407 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Incoming command class COMMAND_CLASS_SWITCH_BINARY, endpoint 0
2017-12-01 23:33:18.410 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: SECURITY NOT required on COMMAND_CLASS_SWITCH_BINARY
2017-12-01 23:33:18.412 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 37: Received COMMAND_CLASS_SWITCH_BINARY V1 SWITCH_BINARY_REPORT
2017-12-01 23:33:18.415 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 37: Switch Binary report, value = 255
2017-12-01 23:33:18.420 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-12-01 23:33:18.423 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_SWITCH_BINARY, value = 255
2017-12-01 23:33:18.426 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Updating channel state zwave:device:15f1ee0619b:node37:switch_binary to ON [OnOffType]
2017-12-01 23:33:18.430 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Commands processed 1.
2017-12-01 23:33:18.433 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@a087f4.
2017-12-01 23:33:18.513 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Application Command Request (ALIVE:DONE)
2017-12-01 23:33:18.515 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: resetResendCount initComplete=true isDead=false
2017-12-01 23:33:18.518 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Incoming command class COMMAND_CLASS_BASIC, endpoint 0
2017-12-01 23:33:18.520 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: SECURITY NOT required on COMMAND_CLASS_BASIC
2017-12-01 23:33:18.522 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 37: Received COMMAND_CLASS_BASIC V1 BASIC_SET
2017-12-01 23:33:18.524 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 37: Basic report, value = 255
2017-12-01 23:33:18.529 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-12-01 23:33:18.532 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_BASIC, value = 255
2017-12-01 23:33:18.534 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Updating channel state zwave:device:15f1ee0619b:node37:switch_binary to ON [OnOffType]
2017-12-01 23:33:18.537 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Commands processed 1.
2017-12-01 23:33:18.539 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1d5588c.
2017-12-01 23:33:18.551 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Application Command Request (ALIVE:DONE)
2017-12-01 23:33:18.553 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: resetResendCount initComplete=true isDead=false
2017-12-01 23:33:18.555 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Incoming command class COMMAND_CLASS_BASIC, endpoint 0
2017-12-01 23:33:18.558 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: SECURITY NOT required on COMMAND_CLASS_BASIC
2017-12-01 23:33:18.560 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 37: Received COMMAND_CLASS_BASIC V1 BASIC_SET
2017-12-01 23:33:18.561 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 37: Basic report, value = 255
2017-12-01 23:33:18.565 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-12-01 23:33:18.568 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_BASIC, value = 255
2017-12-01 23:33:18.570 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Updating channel state zwave:device:15f1ee0619b:node37:switch_binary to ON [OnOffType]
2017-12-01 23:33:18.573 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Commands processed 1.
2017-12-01 23:33:18.575 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1fb824a.
2017-12-01 23:33:18.613 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Application Command Request (ALIVE:DONE)
2017-12-01 23:33:18.615 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: resetResendCount initComplete=true isDead=false
2017-12-01 23:33:18.616 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2017-12-01 23:33:18.618 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Command class COMMAND_CLASS_SWITCH_MULTILEVEL not found, trying to add it.
2017-12-01 23:33:18.619 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 37: Creating new instance of command class COMMAND_CLASS_SWITCH_MULTILEVEL
2017-12-01 23:33:18.621 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 37: Command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0 created
2017-12-01 23:33:18.623 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Adding command class COMMAND_CLASS_SWITCH_MULTILEVEL to endpoint 0
2017-12-01 23:33:18.625 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Adding command class COMMAND_CLASS_SWITCH_MULTILEVEL to the list of supported command classes.
2017-12-01 23:33:18.626 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
2017-12-01 23:33:18.628 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 37: Received COMMAND_CLASS_SWITCH_MULTILEVEL V0 SWITCH_MULTILEVEL_SET
2017-12-01 23:33:18.629 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 37: Switch Multi Level set, value = 255
2017-12-01 23:33:18.632 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-12-01 23:33:18.634 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 255
2017-12-01 23:33:18.636 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Commands processed 1.
2017-12-01 23:33:18.638 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@eba217.
2017-12-01 23:33:18.647 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Application Command Request (ALIVE:DONE)
2017-12-01 23:33:18.648 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: resetResendCount initComplete=true isDead=false
2017-12-01 23:33:18.650 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2017-12-01 23:33:18.652 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
2017-12-01 23:33:18.653 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 37: Received COMMAND_CLASS_SWITCH_MULTILEVEL V0 SWITCH_MULTILEVEL_SET
2017-12-01 23:33:18.655 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 37: Switch Multi Level set, value = 255
2017-12-01 23:33:18.658 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-12-01 23:33:18.660 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 255
2017-12-01 23:33:18.662 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Commands processed 1.
2017-12-01 23:33:18.663 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@c21cd9.
2017-12-01 23:33:21.116 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Application Command Request (ALIVE:DONE)
2017-12-01 23:33:21.119 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: resetResendCount initComplete=true isDead=false
2017-12-01 23:33:21.121 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Incoming command class COMMAND_CLASS_METER, endpoint 0
2017-12-01 23:33:21.124 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: SECURITY NOT required on COMMAND_CLASS_METER
2017-12-01 23:33:21.126 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 37: Received COMMAND_CLASS_METER V3 METER_REPORT
2017-12-01 23:33:21.129 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 37: Meter: Type=Electric(1), Scale=W(2), Value=11.3
2017-12-01 23:33:21.134 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got an event from Z-Wave network: ZWaveMeterValueEvent
2017-12-01 23:33:21.142 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_METER, value = 11.3
2017-12-01 23:33:21.146 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Updating channel state zwave:device:15f1ee0619b:node37:meter_watts to 11.3 [DecimalType]
2017-12-01 23:33:21.150 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Commands processed 1.
2017-12-01 23:33:21.152 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@11c25b5.
only after a manual refresh in HABmin switch_binary1 gets updated.
2017-12-01 23:40:53.120 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@10b4580.
2017-12-01 23:42:55.585 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Command received zwave:device:15f1ee0619b:node37:switch_binary1 --> REFRESH
2017-12-01 23:42:55.592 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Polling intialised at 1800 seconds - start in 50 milliseconds.
2017-12-01 23:42:55.611 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Command received zwave:device:15f1ee0619b:node37:meter_kwh1 --> REFRESH
2017-12-01 23:42:55.615 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Polling intialised at 1800 seconds - start in 50 milliseconds.
2017-12-01 23:42:55.625 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Command received zwave:device:15f1ee0619b:node37:meter_watts1 --> REFRESH
2017-12-01 23:42:55.629 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Polling intialised at 1800 seconds - start in 50 milliseconds.
2017-12-01 23:42:55.679 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Polling...
2017-12-01 23:42:55.681 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Polling zwave:device:15f1ee0619b:node37:switch_binary1
2017-12-01 23:42:55.682 [DEBUG] [converter.ZWaveBinarySwitchConverter] - NODE 37: Generating poll message for COMMAND_CLASS_SWITCH_BINARY, endpoint 1
2017-12-01 23:42:55.683 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 37: Creating new message for application command SWITCH_BINARY_GET
2017-12-01 23:42:55.686 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Encapsulating message, endpoint 1
2017-12-01 23:42:55.688 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Encapsulating message, instance / endpoint 1
2017-12-01 23:42:55.690 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 37: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 1
2017-12-01 23:42:55.691 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL
2017-12-01 23:42:55.693 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Command Class COMMAND_CLASS_MULTI_CHANNEL is NOT required to be secured
2017-12-01 23:42:55.694 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Polling zwave:device:15f1ee0619b:node37:switch_binary1
2017-12-01 23:42:55.696 [DEBUG] [ternal.converter.ZWaveBasicConverter] - NODE 37: Generating poll message for COMMAND_CLASS_BASIC endpoint 1
2017-12-01 23:42:55.698 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Encapsulating message, endpoint 1
2017-12-01 23:42:55.700 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Encapsulating message, instance / endpoint 1
2017-12-01 23:42:55.702 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 37: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 1
2017-12-01 23:42:55.703 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL
2017-12-01 23:42:55.705 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Command Class COMMAND_CLASS_MULTI_CHANNEL is NOT required to be secured
2017-12-01 23:42:55.706 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Polling zwave:device:15f1ee0619b:node37:meter_kwh1
2017-12-01 23:42:55.708 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 37: Generating poll message for COMMAND_CLASS_METER, endpoint 1
2017-12-01 23:42:55.709 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 37: Generating poll message for COMMAND_CLASS_METER, endpoint 1
2017-12-01 23:42:55.711 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 37: Creating new message for application command METER_GET
2017-12-01 23:42:55.714 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Encapsulating message, endpoint 1
2017-12-01 23:42:55.716 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Encapsulating message, instance / endpoint 1
2017-12-01 23:42:55.717 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 37: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 1
2017-12-01 23:42:55.719 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL
2017-12-01 23:42:55.721 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Command Class COMMAND_CLASS_MULTI_CHANNEL is NOT required to be secured
2017-12-01 23:42:55.722 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Polling zwave:device:15f1ee0619b:node37:meter_watts1
2017-12-01 23:42:55.723 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 37: Generating poll message for COMMAND_CLASS_METER, endpoint 1
2017-12-01 23:42:55.725 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 37: Generating poll message for COMMAND_CLASS_METER, endpoint 1
2017-12-01 23:42:55.726 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 37: Creating new message for application command METER_GET
2017-12-01 23:42:55.729 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Encapsulating message, endpoint 1
2017-12-01 23:42:55.731 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Encapsulating message, instance / endpoint 1
2017-12-01 23:42:55.732 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 37: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 1
2017-12-01 23:42:55.734 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL
2017-12-01 23:42:55.735 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Command Class COMMAND_CLASS_MULTI_CHANNEL is NOT required to be secured
2017-12-01 23:42:55.737 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Adding to device queue
2017-12-01 23:42:55.738 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Added to queue - size 0
2017-12-01 23:42:55.763 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: listening == true, frequentlyListening == false, awake == false
2017-12-01 23:42:55.772 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 37: Sending REQUEST Message = 01 0D 00 13 25 06 60 0D 01 01 25 02 25 EF 42
2017-12-01 23:42:55.810 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Adding to device queue
2017-12-01 23:42:55.819 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 37: sentData successfully placed on stack.
2017-12-01 23:42:55.821 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Added to queue - size 0
2017-12-01 23:42:55.831 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: TID 1127: Transaction not completed
2017-12-01 23:42:55.842 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Adding to device queue
2017-12-01 23:42:55.844 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Added to queue - size 0
2017-12-01 23:42:55.845 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 37: SendData Request. CallBack ID = 239, Status = Transmission complete and ACK received(0)
2017-12-01 23:42:55.846 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: resetResendCount initComplete=true isDead=false
2017-12-01 23:42:55.851 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Adding to device queue
2017-12-01 23:42:55.853 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Added to queue - size 0
2017-12-01 23:42:55.855 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Response processed after 79ms
2017-12-01 23:42:55.856 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: TID 1127: Transaction completed
2017-12-01 23:42:55.858 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: notifyTransactionResponse TID:1127 DONE
2017-12-01 23:42:55.861 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2017-12-01 23:42:55.866 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Application Command Request (ALIVE:DONE)
2017-12-01 23:42:55.867 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: resetResendCount initComplete=true isDead=false
2017-12-01 23:42:55.870 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2017-12-01 23:42:55.871 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Incoming command class COMMAND_CLASS_SWITCH_BINARY, endpoint 1
2017-12-01 23:42:55.872 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: SECURITY NOT required on COMMAND_CLASS_SWITCH_BINARY
2017-12-01 23:42:55.873 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 37: Received COMMAND_CLASS_SWITCH_BINARY V1 SWITCH_BINARY_REPORT
2017-12-01 23:42:55.875 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 37: Switch Binary report, value = 255
2017-12-01 23:42:55.877 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-12-01 23:42:55.879 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_BINARY, value = 255
2017-12-01 23:42:55.881 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: listening == true, frequentlyListening == false, awake == false
2017-12-01 23:42:55.881 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Updating channel state zwave:device:15f1ee0619b:node37:switch_binary1 to ON [OnOffType]
2017-12-01 23:42:55.884 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Commands processed 1.
2017-12-01 23:42:55.885 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@cb0832.
2017-12-01 23:42:55.890 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 37: Sending REQUEST Message = 01 0D 00 13 25 06 60 0D 01 01 20 02 25 F0 58
2017-12-01 23:42:55.913 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Checking transaction 1128 ApplicationCommandHandler.
2017-12-01 23:42:55.914 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Checking transaction : state >> WAIT_RESPONSE
2017-12-01 23:42:55.916 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Checking transaction : node >> 37
2017-12-01 23:42:55.917 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Checking transaction : class >> 37 == 32.
2017-12-01 23:42:55.918 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Checking transaction : commd >> 3 == 3.
2017-12-01 23:42:55.920 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Ignoring transaction since not waiting for data.
2017-12-01 23:42:55.936 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 37: sentData successfully placed on stack.
2017-12-01 23:42:55.944 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: TID 1128: Transaction not completed
2017-12-01 23:42:55.956 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 37: SendData Request. CallBack ID = 240, Status = Transmission complete and ACK received(0)
2017-12-01 23:42:55.957 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: resetResendCount initComplete=true isDead=false
2017-12-01 23:42:55.966 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Response processed after 73ms
2017-12-01 23:42:55.967 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: TID 1128: Transaction completed
2017-12-01 23:42:55.968 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: notifyTransactionResponse TID:1128 DONE
2017-12-01 23:42:55.971 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2017-12-01 23:42:55.975 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Application Command Request (ALIVE:DONE)
2017-12-01 23:42:55.977 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: resetResendCount initComplete=true isDead=false
2017-12-01 23:42:55.978 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2017-12-01 23:42:55.979 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Incoming command class COMMAND_CLASS_BASIC, endpoint 1
2017-12-01 23:42:55.980 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: SECURITY NOT required on COMMAND_CLASS_BASIC
2017-12-01 23:42:55.982 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 37: Received COMMAND_CLASS_BASIC V0 BASIC_REPORT
2017-12-01 23:42:55.983 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 37: Basic report, value = 255
2017-12-01 23:42:55.986 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-12-01 23:42:55.987 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_BASIC, value = 255
2017-12-01 23:42:55.989 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Updating channel state zwave:device:15f1ee0619b:node37:switch_binary1 to ON [OnOffType]
2017-12-01 23:42:55.992 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Commands processed 1.
2017-12-01 23:42:55.993 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@374f2.
2017-12-01 23:42:56.016 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: listening == true, frequentlyListening == false, awake == false
2017-12-01 23:42:56.023 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 37: Sending REQUEST Message = 01 0E 00 13 25 07 60 0D 01 01 32 01 10 25 F1 5A
2017-12-01 23:42:56.058 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 37: sentData successfully placed on stack.
2017-12-01 23:42:56.067 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: TID 1130: Transaction not completed
2017-12-01 23:42:56.086 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 37: SendData Request. CallBack ID = 241, Status = Transmission complete and ACK received(0)
2017-12-01 23:42:56.087 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: resetResendCount initComplete=true isDead=false
2017-12-01 23:42:56.097 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Response processed after 71ms
2017-12-01 23:42:56.099 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: TID 1130: Transaction completed
2017-12-01 23:42:56.100 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: notifyTransactionResponse TID:1130 DONE
2017-12-01 23:42:56.103 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2017-12-01 23:42:56.108 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Application Command Request (ALIVE:DONE)
2017-12-01 23:42:56.109 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: resetResendCount initComplete=true isDead=false
2017-12-01 23:42:56.110 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2017-12-01 23:42:56.112 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Incoming command class COMMAND_CLASS_METER, endpoint 1
2017-12-01 23:42:56.113 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: SECURITY NOT required on COMMAND_CLASS_METER
2017-12-01 23:42:56.114 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 37: Received COMMAND_CLASS_METER V3 METER_REPORT
2017-12-01 23:42:56.115 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 37: Meter: Type=Electric(1), Scale=W(2), Value=11.1
2017-12-01 23:42:56.118 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got an event from Z-Wave network: ZWaveMeterValueEvent
2017-12-01 23:42:56.120 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_METER, value = 11.1
2017-12-01 23:42:56.122 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Updating channel state zwave:device:15f1ee0619b:node37:meter_watts1 to 11.1 [DecimalType]
2017-12-01 23:42:56.124 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Commands processed 1.
2017-12-01 23:42:56.125 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@6ee52f.
2017-12-01 23:42:56.149 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: listening == true, frequentlyListening == false, awake == false
2017-12-01 23:42:56.155 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 37: Sending REQUEST Message = 01 0E 00 13 25 07 60 0D 01 01 32 01 00 25 F2 49
2017-12-01 23:42:56.180 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 37: sentData successfully placed on stack.
2017-12-01 23:42:56.187 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: TID 1129: Transaction not completed
2017-12-01 23:42:56.214 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 37: SendData Request. CallBack ID = 242, Status = Transmission complete and ACK received(0)
2017-12-01 23:42:56.215 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: resetResendCount initComplete=true isDead=false
2017-12-01 23:42:56.223 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Response processed after 66ms
2017-12-01 23:42:56.225 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: TID 1129: Transaction completed
2017-12-01 23:42:56.227 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: notifyTransactionResponse TID:1129 DONE
2017-12-01 23:42:56.231 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2017-12-01 23:42:56.237 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Application Command Request (ALIVE:DONE)
2017-12-01 23:42:56.239 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: resetResendCount initComplete=true isDead=false
2017-12-01 23:42:56.241 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2017-12-01 23:42:56.243 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Incoming command class COMMAND_CLASS_METER, endpoint 1
2017-12-01 23:42:56.245 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: SECURITY NOT required on COMMAND_CLASS_METER
2017-12-01 23:42:56.247 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 37: Received COMMAND_CLASS_METER V3 METER_REPORT
2017-12-01 23:42:56.249 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 37: Meter: Type=Electric(1), Scale=kWh(0), Value=0E+1
2017-12-01 23:42:56.252 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got an event from Z-Wave network: ZWaveMeterValueEvent
2017-12-01 23:42:56.254 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_METER, value = 0E+1
2017-12-01 23:42:56.256 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 37: Updating channel state zwave:device:15f1ee0619b:node37:meter_kwh1 to 0 [DecimalType]
2017-12-01 23:42:56.260 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Commands processed 1.
2017-12-01 23:42:56.261 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@15488a7.
yes, the actual once to be used are switch_binary1 and switch_binary2.
but if i use the physical switch connected to S1 only switch_binary gets triggered as showing in my attached logs.
only if i manually refresh in HABmin switch_binary1 gets changed as well.
exactly the same behavior if i connect the switch to S2 only switch_binary gets triggered by the physical switch on S2.
i read in a couple of different forum and it seems that everyone has/had this kind of problem with the fgs-223.
if i only use HABmin to switch switch 1 and 2 no problem but using the physical switch on S1 and/or S2 will not update the software switch.
