Are there any error messages in /var/log/openhab/openhab.log ?
How to check the log ?
did you try to connect using the IP local address ?
hmm not sure what you mean by that … In browser im typing “openhab ip:8080”
sorry for the poor skills in linux / command lines… Im new in windows used apple since 1991 so used to graphic interface …
Btw same issue if i try running openhab on my synology… !no web interface …therefor i suspect the issue is java…
Already the answer of the command “netstat -tulpn | grep java” showed that the java process is not running. Thus the service is not listening on port 8080.
What does
[12:33:58] openhabian@openHABianDevice:~$ less /var/log/openhab/openhab.log
/var/log/openhab/openhab.log: No such file or directory
[12:34:18] openhabian@openHABianDevice:~$ less /var/log/syslog
Jan 6 00:00:14 openHABianDevice rsyslogd: [origin software=“rsyslogd” swVersion=“8.1901.0” x-pid=“550” x-info=“https://www.rsyslog.com”] rsyslogd was HUPed
Jan 6 00:00:14 openHABianDevice systemd[1]: logrotate.service: Succeeded.
Jan 6 00:00:14 openHABianDevice systemd[1]: Started Rotate log files.
Jan 6 00:00:15 openHABianDevice systemd[1]: man-db.service: Succeeded.
Jan 6 00:00:15 openHABianDevice systemd[1]: Started Daily man-db regeneration.
Jan 6 00:04:26 openHABianDevice systemd[1]: Created slice User Slice of UID 1000.
Jan 6 00:04:26 openHABianDevice systemd[1]: Starting User Runtime Directory /run/user/1000…
Jan 6 00:04:26 openHABianDevice systemd[1]: Started User Runtime Directory /run/user/1000.
Jan 6 00:04:26 openHABianDevice systemd[1]: Starting User Manager for UID 1000…
Jan 6 00:04:27 openHABianDevice systemd[991]: Reached target Paths.
Jan 6 00:04:27 openHABianDevice systemd[991]: Listening on GnuPG cryptographic agent and passphrase cache.
Jan 6 00:04:27 openHABianDevice systemd[991]: Reached target Timers.
Jan 6 00:04:27 openHABianDevice systemd[991]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Jan 6 00:04:27 openHABianDevice systemd[991]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Jan 6 00:04:27 openHABianDevice systemd[991]: Listening on GnuPG cryptographic /var/log/syslog
[12:40:31] openhabian@openHABianDevice:~$ sudo systemctl status openhab
[sudo] password for openhabian:
● openhab.service - openHAB - empowering the smart home
Loaded: loaded (/lib/systemd/system/openhab.service; disabled; vendor preset:
Active: inactive (dead)
Docs: Introduction | openHAB https://community.openhab.org
[12:42:02] openhabian@openHABianDevice:~$ sudo journalctl -u openhab
– Logs begin at Mon 2021-01-04 17:18:07 CET, end at Wed 2021-01-06 12:42:50 CET
– No entries –
lines 1-2/2 (END)
I was going to say that this should have all been in the installation guide but looking at the Download page, when doing the Linux package route, it does look like it does miss these steps which are well known to Linux guys, but less so to newcomers. Maybe some of the admins could add these steps…
this step ‘normally’ is being executed during the installation of openhab service.
The commands are included in the openhabian-config installation steps and executed automatically.
So the question would be have there been any error messages shown during the installation?
