Indeed I also saw some updates.
I tried the complete install from scratch today again.
You can see the whole log below from login to the error during installation of influxdb and grafana.
login as: openhabian
openhabian@10.0.0.100's password:
Linux openhab 4.19.57-v7l+ #1244 SMP Thu Jul 4 18:48:07 BST 2019 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
############### openhab #####################################################
## Ip = 10.0.0.100
## Release = Raspbian GNU/Linux 10 (buster)
## Kernel = Linux 4.19.57-v7l+
## Platform = Raspberry Pi 4 Model B Rev 1.2
## Uptime = 0 day(s). 1:24:47
## CPU Usage = 0% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
## CPU Load = 1m: 0.38, 5m: 0.29, 15m: 0.60
## Memory = Free: 1.27GB (33%), Used: 2.54GB (67%), Total: 3.81GB
## Swap = Free: 0.09GB (100%), Used: 0.00GB (0%), Total: 0.09GB
## Root = Free: 24.43GB (90%), Used: 2.50GB (10%), Total: 28.11GB
## Updates = 0 apt updates available.
## Sessions = 1 session(s)
## Processes = 127 running processes of 32768 maximum processes
Welcome to __ _____ ____ _
____ ____ ___ ____ / / / / | / __ )(_)___ _____
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ / / __ `/ __ \
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ / / /_/ / / / /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/_/\__,_/_/ /_/
/_/
openHAB 2.5.5-1 (Release Build)
Looking for a place to get started? Check out 'sudo openhabian-config' and the
documentation at https://www.openhab.org/docs/installation/openhabian.html
The openHAB dashboard can be reached at http://openhab:8080
To interact with openHAB on the command line, execute: 'openhab-cli --help'
[10:50:07] openhabian@openhab:~$ sudo openhabian-config
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
[sudo] password for openhabian:
2020-05-26_10:50:19_CEST [openHABian] Checking for root privileges... OK
2020-05-26_10:50:19_CEST [openHABian] Updating Linux package information ... 2020-05-26_10:50:19_CEST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2020-05-26_10:50:19_CEST [openHABian] openHABian configuration tool version: [master]v1.5-607(71cb38d)
2020-05-26_10:50:19_CEST [openHABian] Checking for changes in origin... OK
2020-05-26_10:50:23_CEST [openHABian] Updating myself... OK - No remote changes detected. You are up to date!
2020-05-26_10:50:49_CEST [openHABian] Updating Linux package information ... 2020-05-26_10:50:49_CEST [openHABian] Updating repositories and upgrading installed packages...
$ apt-get --yes upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
rpi.gpio-common triggerhappy
Use 'sudo apt autoremove' to remove them.
The following packages have been kept back:
binutils binutils-arm-linux-gnueabihf binutils-common libbinutils
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
$ java_install_or_update
openjdk version "1.8.0_252"
OpenJDK Runtime Environment (Zulu 8.46.0.225-CA-linux_aarch32hf) (build 1.8.0_252-b225)
OpenJDK Client VM (Zulu 8.46.0.225-CA-linux_aarch32hf) (build 25.252-b225, mixed mode, Evaluation)
$ java -version
OK
2020-05-26_10:50:57_CEST [openHABian] Updating Linux package information ... 2020-05-26_10:50:57_CEST [openHABian] Installing or upgrading to latest openHAB release (stable)...
$ apt-key add /tmp/openhab-key.asc
OK
$ apt-get update
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Ign:3 https://dl.bintray.com/openhab/apt-repo2 stable InRelease
Get:4 https://dl.bintray.com/openhab/apt-repo2 stable Release [6,051 B]
Fetched 6,051 B in 1s (5,163 B/s)
$ apt-get -y --allow-downgrades install openhab2=2.5.5-1
openhab2 is already the newest version (2.5.5-1).
$ adduser openhab gpio
The user `openhab' is already a member of `gpio'.
$ systemctl daemon-reload
$ systemctl enable --now openhab2
OK
Optimizing Java to run on low memory single board computers...
2020-05-26_10:51:17_CEST [openHABian] Adding an openHAB dashboard tile for 'openhabiandocs'... Replacing... OK
2020-05-26_10:51:32_CEST [openHABian] Updating Linux package information ... 2020-05-26_10:51:32_CEST [openHABian] Installing basic can't-be-wrong packages (screen, vim, ...)...
$ apt-get -y install screen vim nano mc vfu bash-completion htop curl wget multitail git util-linux bzip2 zip unzip xz-utils software-properties-common man-db whiptail acl usbutils dirmngr arping
acl is already the newest version (2.2.53-4).
arping is already the newest version (2.19-6).
bash-completion is already the newest version (1:2.8-6).
bzip2 is already the newest version (1.0.6-9.2~deb10u1).
curl is already the newest version (7.64.0-4+deb10u1).
dirmngr is already the newest version (2.2.12-1+rpi1+deb10u1).
git is already the newest version (1:2.20.1-2+deb10u3).
htop is already the newest version (2.2.0-1).
man-db is already the newest version (2.8.5-2).
mc is already the newest version (3:4.8.22-1).
multitail is already the newest version (6.4.2-3).
nano is already the newest version (3.2-3).
screen is already the newest version (4.6.2-3).
software-properties-common is already the newest version (0.96.20.2-2).
unzip is already the newest version (6.0-23+deb10u1).
usbutils is already the newest version (1:010-3).
util-linux is already the newest version (2.33.1-0.1).
vfu is already the newest version (4.16+repack-1).
vim is already the newest version (2:8.1.0875-5).
wget is already the newest version (1.20.1-1.1).
whiptail is already the newest version (0.52.20-8).
xz-utils is already the newest version (5.2.4-1).
zip is already the newest version (3.0-11).
OK
2020-05-26_10:51:35_CEST [openHABian] Installing additional needed packages...
$ apt-get -y install apt-transport-https bc sysstat avahi-daemon python3 python3-pip avahi-autoipd fontconfig
apt-transport-https is already the newest version (1.8.2.1).
avahi-autoipd is already the newest version (0.7-4+b1).
avahi-daemon is already the newest version (0.7-4+b1).
bc is already the newest version (1.07.1-2).
fontconfig is already the newest version (2.13.1-2).
python3 is already the newest version (3.7.3-1).
sysstat is already the newest version (12.0.3-2).
python3-pip is already the newest version (18.1-5+rpt1).
OK
2020-05-26_10:51:36_CEST [openHABian] Installing additional bluetooth packages...
$ apt-get -y install bluez python3-dev libbluetooth-dev raspberrypi-sys-mods pi-bluetooth python3-bluez
python3-bluez is already the newest version (0.22+really0.22-1).
python3-dev is already the newest version (3.7.3-1).
bluez is already the newest version (5.50-1.2~deb10u1+rpt1).
libbluetooth-dev is already the newest version (5.50-1.2~deb10u1+rpt1).
pi-bluetooth is already the newest version (0.1.12).
raspberrypi-sys-mods is already the newest version (20191105).
OK
2020-05-26_10:51:42_CEST [openHABian] Updating Linux package information ... 2020-05-26_10:51:42_CEST [openHABian] Adding slightly tuned bash config files to system... OK
2020-05-26_10:51:42_CEST [openHABian] Adding slightly tuned vim config file to system... OK
2020-05-26_10:51:42_CEST [openHABian] Adding openHAB syntax to vim editor...
$ wget -O /home/openhabian/.vim/syntax/openhab.vim https://raw.githubusercontent.com/cyberkov/openhab-vim/master/syntax/openhab.vim
--2020-05-26 10:51:42-- https://raw.githubusercontent.com/cyberkov/openhab-vim/master/syntax/openhab.vim
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.0.133, 151.101.64.133, 151.101.128.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.0.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 6065 (5.9K) [text/plain]
Saving to: ‘/home/openhabian/.vim/syntax/openhab.vim’
/home/openhabian/.vim/syntax/openhab.vim 100%[=========================================================================================>] 5.92K --.-KB/s in 0.05s
2020-05-26 10:51:43 (114 KB/s) - ‘/home/openhabian/.vim/syntax/openhab.vim’ saved [6065/6065]
$ wget -O /home/openhabian/.vim/ftdetect/openhab.vim https://raw.githubusercontent.com/cyberkov/openhab-vim/master/ftdetect/openhab.vim
--2020-05-26 10:51:43-- https://raw.githubusercontent.com/cyberkov/openhab-vim/master/ftdetect/openhab.vim
Length: 661 [text/plain]
Saving to: ‘/home/openhabian/.vim/ftdetect/openhab.vim’
/home/openhabian/.vim/ftdetect/openhab.vim 100%[=========================================================================================>] 661 --.-KB/s in 0s
2020-05-26 10:51:43 (4.68 MB/s) - ‘/home/openhabian/.vim/ftdetect/openhab.vim’ saved [661/661]
OK
2020-05-26_10:51:43_CEST [openHABian] Adding openHAB syntax to nano editor...
$ wget -O /usr/share/nano/openhab.nanorc https://raw.githubusercontent.com/airix1/openhabnano/master/openhab.nanorc
--2020-05-26 10:51:43-- https://raw.githubusercontent.com/airix1/openhabnano/master/openhab.nanorc
Length: 2321 (2.3K) [text/plain]
Saving to: ‘/usr/share/nano/openhab.nanorc’
/usr/share/nano/openhab.nanorc 100%[=========================================================================================>] 2.27K --.-KB/s in 0s
2020-05-26 10:51:44 (11.0 MB/s) - ‘/usr/share/nano/openhab.nanorc’ saved [2321/2321]
OK
2020-05-26_10:51:44_CEST [openHABian] Adding openHAB scheme to multitail... OK
2020-05-26_10:51:52_CEST [openHABian] Updating Linux package information ... 2020-05-26_10:51:52_CEST [openHABian] Preparing openHAB folder mounts under /srv/...
$ cat /etc/fstab
proc /proc proc defaults 0 0
PARTUUID=741f5400-01 /boot vfat defaults 0 2
PARTUUID=741f5400-02 / ext4 defaults,noatime 0 1
# a swapfile is not a swap partition, no line here
# use dphys-swapfile swap[on|off] for that
/usr/share/openhab2 /srv/openhab2-sys none bind 0 0
/etc/openhab2 /srv/openhab2-conf none bind 0 0
/var/lib/openhab2 /srv/openhab2-userdata none bind 0 0
/var/log/openhab2 /srv/openhab2-logs none bind 0 0
/usr/share/openhab2/addons /srv/openhab2-addons none bind 0 0
$ mkdir -p /srv/openhab2-sys /srv/openhab2-conf /srv/openhab2-userdata /srv/openhab2-logs /srv/openhab2-addons
$ cp /opt/openhabian/includes/srv_readme.txt /srv/README.txt
$ chmod ugo+w /srv /srv/README.txt
$ mount --all --verbose
/proc : already mounted
/boot : already mounted
/ : ignored
/srv/openhab2-sys : already mounted
/srv/openhab2-conf : already mounted
/srv/openhab2-userdata : already mounted
/srv/openhab2-logs : already mounted
/srv/openhab2-addons : already mounted
OK
2020-05-26_10:51:58_CEST [openHABian] Applying miscellaneous system settings...
$ setcap cap_net_raw,cap_net_admin=+eip cap_net_bind_service=+ep /opt/jdk/zulu8.46.0.225-ca-jdk8.0.252-linux_aarch32hf/bin/java
$ setcap cap_net_raw,cap_net_admin=+eip cap_net_bind_service=+ep /usr/sbin/arping
$ echo Creating persistent systemd journal folder location: /var/log/journal
$ echo Keeping at most 30 days of systemd journal entries
OK
2020-05-26_10:52:04_CEST [openHABian] Updating Linux package information ... 2020-05-26_10:52:04_CEST [openHABian] Applying file permissions recommendations...
$ adduser openhab audio
The user `openhab' is already a member of `audio'.
$ adduser openhabian audio
The user `openhabian' is already a member of `audio'.
$ adduser openhab bluetooth
The user `openhab' is already a member of `bluetooth'.
$ adduser openhabian bluetooth
The user `openhabian' is already a member of `bluetooth'.
$ adduser openhab dialout
The user `openhab' is already a member of `dialout'.
$ adduser openhabian dialout
The user `openhabian' is already a member of `dialout'.
$ adduser openhabian gpio
The user `openhabian' is already a member of `gpio'.
$ adduser openhab tty
The user `openhab' is already a member of `tty'.
$ adduser openhabian tty
The user `openhabian' is already a member of `tty'.
$ adduser openhabian openhab
The user `openhabian' is already a member of `openhab'.
$ chown openhab:openhab /srv /srv/README.txt /opt
$ chown -R openhab:openhab /etc/openhab2 /var/lib/openhab2 /var/log/openhab2 /usr/share/openhab2
$ chmod -R ug+wX /opt /etc/openhab2 /var/lib/openhab2 /var/log/openhab2 /usr/share/openhab2
$ chown -R openhabian:openhabian /home/openhabian
$ setfacl -R --remove-all /etc/openhab2 /var/lib/openhab2 /var/log/openhab2 /usr/share/openhab2
$ setfacl -R -m g::rwX /etc/openhab2 /var/lib/openhab2 /var/log/openhab2 /usr/share/openhab2
$ setfacl -R -m d:g::rwX /etc/openhab2 /var/lib/openhab2 /var/log/openhab2 /usr/share/openhab2
OK
2020-05-26_10:52:10_CEST [openHABian] Updating Linux package information ... 2020-05-26_10:52:10_CEST [openHABian] Downloading and setting up FireMotD...
$ apt-get -y install bc sysstat jq moreutils
jq is already the newest version (1.5+dfsg-2+b1).
moreutils is already the newest version (0.62-1+b1).
$ curl -s https://raw.githubusercontent.com/OutsideIT/FireMotD/master/FireMotD -o /tmp/FireMotD
$ /tmp/FireMotD -I
2020-05-26 10:52:15,058: FireMotD: Info: Attempting FireMotD installation
mkdir: cannot create directory '/usr/share/firemotd': File exists
mkdir: cannot create directory '/usr/share/firemotd/themes': File exists
mkdir: cannot create directory '/usr/share/firemotd/templates': File exists
2020-05-26 10:52:19,984: FireMotD: Info: Generating information
2020-05-26 10:52:20,042: FireMotD: Info: Debug mode
2020-05-26 10:52:20,054: FireMotD: Info: FireMotD action save started
2020-05-26 10:52:20,065: FireMotD: Info: Action "save"
2020-05-26 10:52:20,077: FireMotD: Info: Exportfile /usr/share/firemotd/data/FireMotD.json found.
2020-05-26 10:52:20,088: FireMotD: Info: Template type set to all. Overwriting..
2020-05-26 10:52:20,121: FireMotD: Info: Exploring HostIp
2020-05-26 10:52:20,205: FireMotD: Info: Exploring Release
2020-05-26 10:52:20,305: FireMotD: Info: Exploring Kernel
2020-05-26 10:52:20,362: FireMotD: Info: Exploring Platform
2020-05-26 10:52:20,452: FireMotD: Info: Exploring InstallDate
2020-05-26 10:52:20,508: FireMotD: Info: Exploring Updates
2020-05-26 10:52:54,746: FireMotD: Info: Exploring Httpd
2020-05-26 10:52:54,861: FireMotD: Info: Exploring Nginx
2020-05-26 10:52:55,002: FireMotD: Info: Exploring Mysql
2020-05-26 10:52:55,087: FireMotD: Info: Exploring Postgres
2020-05-26 10:52:55,142: FireMotD: Info: Exploring Php
2020-05-26 10:52:55,217: FireMotD: Info: Exploring Elasticsearch
2020-05-26 10:52:56,550: FireMotD: Info: Exploring Logstash
2020-05-26 10:52:56,674: FireMotD: Info: Exploring Kibana
2020-05-26 10:52:56,796: FireMotD: Info: Export system data to "/usr/share/firemotd/data/FireMotD.json" finished.
2020-05-26 10:52:56,843: FireMotD: Info: ExportFile: -rwxrw-rw- 1 root root 3229 May 26 10:52 /usr/share/firemotd/data/FireMotD.json
2020-05-26 10:52:56,872: FireMotD: Info: FireMotD action save finished
2020-05-26 10:52:56,902: FireMotD: Info: Generating caches
2020-05-26 10:53:24,706: FireMotD: Info: Generating FireMotD
DDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDD
iiiiiiiiiiiiiii openhab iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
ggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggg
DD Ip -> 10.0.0.100
DD Release -> Raspbian GNU/Linux 10 (buster)
DD Kernel -> Linux 4.19.57-v7l+
DD Platform -> Raspberry Pi 4 Model B Rev 1.2
DD Uptime -> 0 day(s). 1:28:27
DD CPU Usage -> 0% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
DD CPU Load -> 1m: 2.37, 5m: 1.51, 15m: 1.03
DD Memory -> Free: 1.26GB (33%), Used: 2.55GB (67%), Total: 3.81GB
DD Swap -> Free: 0.09GB (100%), Used: 0.00GB (0%), Total: 0.09GB
DD Root -> Free: 24.43GB (90%), Used: 2.50GB (10%), Total: 28.11GB
DD Updates -> 0 apt updates available.
DD Sessions -> 0 session(s)
DD Processes -> 130 running processes of 32768 maximum processes
SSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
$ FireMotD -G Gray
$ FireMotD -S
OK
2020-05-26_11:10:39_CEST [openHABian] Updating Linux package information ... 2020-05-26_11:10:39_CEST [openHABian] Setting up the MQTT broker Eclipse Mosquitto...
$ apt-get -y install mosquitto mosquitto-clients
The following additional packages will be installed:
libev4 libmosquitto1 libuv1 libwebsockets8
Suggested packages:
apparmor
The following NEW packages will be installed:
libev4 libmosquitto1 libuv1 libwebsockets8 mosquitto mosquitto-clients
0 upgraded, 6 newly installed, 0 to remove and 4 not upgraded.
Need to get 484 kB of archives.
After this operation, 1,054 kB of additional disk space will be used.
Get:1 http://mirror.nl.leaseweb.net/raspbian/raspbian buster/main armhf libev4 armhf 1:4.25-1 [34.5 kB]
Get:2 http://mirror.nl.leaseweb.net/raspbian/raspbian buster/main armhf libmosquitto1 armhf 1.5.7-1+deb10u1 [57.6 kB]
Get:3 http://mirror.nl.leaseweb.net/raspbian/raspbian buster/main armhf libuv1 armhf 1.24.1-1 [96.7 kB]
Get:4 http://mirror.nl.leaseweb.net/raspbian/raspbian buster/main armhf libwebsockets8 armhf 2.0.3-3 [85.6 kB]
Get:5 http://mirror.nl.leaseweb.net/raspbian/raspbian buster/main armhf mosquitto armhf 1.5.7-1+deb10u1 [143 kB]
Get:6 http://mirror.nl.leaseweb.net/raspbian/raspbian buster/main armhf mosquitto-clients armhf 1.5.7-1+deb10u1 [66.8 kB]
Fetched 484 kB in 1s (461 kB/s)
Selecting previously unselected package libev4:armhf.
(Reading database ... 47909 files and directories currently installed.)
Preparing to unpack .../0-libev4_1%3a4.25-1_armhf.deb ...
Unpacking libev4:armhf (1:4.25-1) ...
Selecting previously unselected package libmosquitto1:armhf.
Preparing to unpack .../1-libmosquitto1_1.5.7-1+deb10u1_armhf.deb ...
Unpacking libmosquitto1:armhf (1.5.7-1+deb10u1) ...
Selecting previously unselected package libuv1:armhf.
Preparing to unpack .../2-libuv1_1.24.1-1_armhf.deb ...
Unpacking libuv1:armhf (1.24.1-1) ...
Selecting previously unselected package libwebsockets8:armhf.
Preparing to unpack .../3-libwebsockets8_2.0.3-3_armhf.deb ...
Unpacking libwebsockets8:armhf (2.0.3-3) ...
Selecting previously unselected package mosquitto.
Preparing to unpack .../4-mosquitto_1.5.7-1+deb10u1_armhf.deb ...
Unpacking mosquitto (1.5.7-1+deb10u1) ...
Selecting previously unselected package mosquitto-clients.
Preparing to unpack .../5-mosquitto-clients_1.5.7-1+deb10u1_armhf.deb ...
Unpacking mosquitto-clients (1.5.7-1+deb10u1) ...
Setting up libmosquitto1:armhf (1.5.7-1+deb10u1) ...
Setting up libev4:armhf (1:4.25-1) ...
Setting up mosquitto-clients (1.5.7-1+deb10u1) ...
Setting up libuv1:armhf (1.24.1-1) ...
Setting up libwebsockets8:armhf (2.0.3-3) ...
Setting up mosquitto (1.5.7-1+deb10u1) ...
Created symlink /etc/systemd/system/multi-user.target.wants/mosquitto.service → /lib/systemd/system/mosquitto.service.
Processing triggers for systemd (241-7~deb10u4+rpi1) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for libc-bin (2.28-10+rpi1) ...
Updating FireMotD available updates count ...
$ sed -i /password_file/d /etc/mosquitto/mosquitto.conf
$ sed -i /allow_anonymous/d /etc/mosquitto/mosquitto.conf
$ rm -f /etc/mosquitto/passwd
$ systemctl enable mosquitto.service
Synchronizing state of mosquitto.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable mosquitto
$ systemctl restart mosquitto.service
OK
2020-05-26_11:11:36_CEST [openHABian] Updating Linux package information ... 2020-05-26_11:11:36_CEST [openHABian] Setting up InfluxDB and Grafana...
Installing InfluxDB...
--2020-05-26 11:12:09-- https://repos.influxdata.com/influxdb.key
Resolving repos.influxdata.com (repos.influxdata.com)... 54.192.209.34, 54.192.209.6, 54.192.209.57, ...
Connecting to repos.influxdata.com (repos.influxdata.com)|54.192.209.34|:443... connected.
Length: 3108 (3.0K) [application/pgp-keys]
Saving to: ‘STDOUT’
- 100%[=========================================================================================>] 3.04K --.-KB/s in 0s
2020-05-26 11:12:09 (7.18 MB/s) - written to stdout [3108/3108]
OK
$ apt-get update
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Get:3 https://repos.influxdata.com/debian buster InRelease [4,731 B]
Ign:4 https://dl.bintray.com/openhab/apt-repo2 stable InRelease
Get:5 https://dl.bintray.com/openhab/apt-repo2 stable Release [6,051 B]
Get:6 https://repos.influxdata.com/debian buster/stable armhf Packages [929 B]
Fetched 11.7 kB in 3s (4,127 B/s)
$ apt-get -y install influxdb
influxdb
0 upgraded, 1 newly installed, 0 to remove and 4 not upgraded.
Need to get 59.1 MB of archives.
After this operation, 151 MB of additional disk space will be used.
Get:1 https://repos.influxdata.com/debian buster/stable armhf influxdb armhf 1.8.0-1 [59.1 MB]
Fetched 59.1 MB in 17s (3,492 kB/s)
Selecting previously unselected package influxdb.
(Reading database ... 47972 files and directories currently installed.)
Preparing to unpack .../influxdb_1.8.0-1_armhf.deb ...
Unpacking influxdb (1.8.0-1) ...
Setting up influxdb (1.8.0-1) ...
Created symlink /etc/systemd/system/influxd.service → /lib/systemd/system/influxdb.service.
Created symlink /etc/systemd/system/multi-user.target.wants/influxdb.service → /lib/systemd/system/influxdb.service.
$ sed -i s/auth-enabled = true/# auth-enabled = false/g /etc/influxdb/influxdb.conf
$ systemctl enable influxdb.service
$ systemctl restart influxdb.service
OK Configure InfluxDB admin account... {"results":[{"statement_id":0}]}
OK Configure listen on localhost only...
$ sed -i -e /# Determines whether HTTP endpoint is enabled./ { n ; s/# enabled = true/enabled = true/ } /etc/influxdb/influxdb.conf
$ sed -i s/# bind-address = ":8086"/bind-address = "localhost:8086"/g /etc/influxdb/influxdb.conf
$ sed -i s/# auth-enabled = false/auth-enabled = true/g /etc/influxdb/influxdb.conf
$ sed -i s/# store-enabled = true/store-enabled = false/g /etc/influxdb/influxdb.conf
OK Waiting for InfluxDB service... OK
Setup of inital influxdb database and InfluxDB users... {"results":[{"statement_id":0}]}
OK Installing Grafana... --2020-05-26 11:13:33-- https://packages.grafana.com/gpg.key
Resolving packages.grafana.com (packages.grafana.com)... 151.101.38.217, 2a04:4e42:9::729
Connecting to packages.grafana.com (packages.grafana.com)|151.101.38.217|:443... connected.
Length: 1694 (1.7K) [application/x-iwork-keynote-sffkey]
Saving to: ‘STDOUT’
- 100%[=========================================================================================>] 1.65K --.-KB/s in 0s
2020-05-26 11:13:33 (4.50 MB/s) - written to stdout [1694/1694]
OK
$ apt-get update
Get:3 https://packages.grafana.com/oss/deb stable InRelease [12.1 kB]
Hit:4 https://repos.influxdata.com/debian buster InRelease
Ign:5 https://dl.bintray.com/openhab/apt-repo2 stable InRelease
Get:6 https://dl.bintray.com/openhab/apt-repo2 stable Release [6,051 B]
Get:7 https://packages.grafana.com/oss/deb stable/main armhf Packages [16.6 kB]
Fetched 34.8 kB in 4s (9,357 B/s)
$ apt-get -y install grafana
grafana
Need to get 41.7 MB of archives.
After this operation, 121 MB of additional disk space will be used.
Get:1 https://packages.grafana.com/oss/deb stable/main armhf grafana armhf 7.0.1 [41.7 MB]
Fetched 41.7 MB in 14s (2,931 kB/s)
Selecting previously unselected package grafana.
(Reading database ... 47998 files and directories currently installed.)
Preparing to unpack .../grafana_7.0.1_armhf.deb ...
Unpacking grafana (7.0.1) ...
Setting up grafana (7.0.1) ...
Adding system user `grafana' (UID 112) ...
Adding new user `grafana' (UID 112) with group `grafana' ...
Not creating home directory `/usr/share/grafana'.
### NOT starting on installation, please execute the following statements to configure grafana to start automatically using systemd
sudo /bin/systemctl daemon-reload
sudo /bin/systemctl enable grafana-server
### You can start grafana-server by executing
sudo /bin/systemctl start grafana-server
$ systemctl enable grafana-server.service
Synchronizing state of grafana-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable grafana-server
Created symlink /etc/systemd/system/multi-user.target.wants/grafana-server.service → /usr/lib/systemd/system/grafana-server.service.
$ systemctl start grafana-server.service
OK
Resetting Grafana admin password...
$ grafana-cli admin reset-admin-password admin
INFO[05-26|11:15:15] Connecting to DB logger=sqlstore dbtype=sqlite3
INFO[05-26|11:15:15] Starting DB migration logger=migrator
INFO[05-26|11:15:16] Executing migration logger=migrator id="create index UQE_user_login - v2"
EROR[05-26|11:15:16] Executing migration failed logger=migrator id="create index UQE_user_login - v2" error="database is locked"
EROR[05-26|11:15:16] Exec failed logger=migrator error="database is locked" sql="CREATE UNIQUE INDEX `UQE_user_login` ON `user` (`login`);"
Error: ✗ failed to initialize SQL engine: Migration failed err: Failed to roll back transaction due to error: %!s(<nil>): database is locked
FAILED Connection Grafana to InfluxDB...curl: (7) Failed to connect to localhost port 3000: Connection refused
Adding openHAB dashboard tile for Grafana... 2020-05-26_11:15:16_CEST [openHABian] Adding an openHAB dashboard tile for 'grafana'... OK
Adding install InfluxDB with database configuration to openHAB
$ touch /etc/openhab2/services/influxdb.cfg
2020-05-26_11:15:23_CEST [openHABian] Checking for default openHABian username:password combination... FAILED
2020-05-26_11:15:25_CEST [openHABian] We hope you got what you came for! See you again soon ;)
[11:15:25] openhabian@openhab:~$
