When using this setting in the sitemap file the selected set-point doesn’t update from zero. The + and - will change the set-point
Text item=Bedroom_Valves_HeatSPoint label="Bed room setpoint"
Switch item=Bedroom_Valves_Energy_Save label="Bed room 17 °C" icon="temperature"
Setpoint item=Bedroom_Valves_HeatSPoint label="Bed room" minValue=15 maxValue=30 step=1
sipvoip
(Nathan Stratton)
2
Seeing the same thing all my set points show 0
The-Elk
(Stefan)
3
+1 same thing at all set points
Chrishab
(Christian)
4
I have the same issue - the problem seems to be the „step“ parameter. If set to 1 or 1.0 the setpoint does not show in iOS.
When set to 1.5, 2.5, etc. it works again.
At least that’s a temporary workaround.
The-Elk
(Stefan)
5
THX for this workaround.
step=0.5 also works for me.
dan12345
(Dan)
8
And same here! Nice easy workaround.
pastyGRB
(Chris Pasternak)
10
I also tried step=3 and step=3.0, neither worked. It appears to dislike whole numbers
volfan6415
(Zachary Christiansen)
13
Same issue is there any update on this?
