Ok, I think we just have to enhance the documentation.
How about adding a simple servlet to indicate that the token already exists.
Current servlet already indicates that the token exists with a green higlighting of the account. So it would just need to be activated whatever the configuration status is.
I updated to 3.3.M6 and get the following error on the account Thing:
Configuration incomplete, please grant the binding to Netatmo Connect.
In the documentation to 3.3 I can not see something about the new grant process. Someone can tell me what to do?
EDIT: Found itā¦ Itās like @stefan13 wrote above:
http://<OH3-IPAddress>:8192/netatmo/connect/<Client_ID>
After update to M6 I get this warn, so whats the problem?
2022-06-11 18:37:25.841 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler DeviceHandler of thing netatmo:weather-station:bd8688924a tried checking if channel temperature#heat-index is linked although the handler was already disposed.
2022-06-11 18:37:25.847 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler DeviceHandler of thing netatmo:weather-station:bd8688924a tried checking if channel temperature#dewpoint is linked although the handler was already disposed.
2022-06-11 18:37:25.860 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler DeviceHandler of thing netatmo:weather-station:bd8688924a tried checking if channel temperature#dewpoint-depression is linked although the handler was already disposed.
2022-06-11 18:37:25.870 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler DeviceHandler of thing netatmo:weather-station:bd8688924a tried checking if channel airquality#co2 is linked although the handler was already disposed.
2022-06-11 18:37:25.883 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler DeviceHandler of thing netatmo:weather-station:bd8688924a tried checking if channel location#value is linked although the handler was already disposed.
2022-06-11 18:37:25.888 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler DeviceHandler of thing netatmo:weather-station:bd8688924a tried checking if channel timestamp#measures is linked although the handler was already disposed.
2022-06-11 18:37:25.902 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler DeviceHandler of thing netatmo:weather-station:bd8688924a tried checking if channel timestamp#last-seen is linked although the handler was already disposed.
2022-06-11 18:37:25.909 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler DeviceHandler of thing netatmo:weather-station:bd8688924a tried checking if channel signal#value is linked although the handler was already disposed.
2022-06-11 18:37:25.921 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler DeviceHandler of thing netatmo:weather-station:bd8688924a tried checking if channel signal#strength is linked although the handler was already disposed.
2022-06-11 18:37:26.278 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler DeviceHandler tried updating the thing status although the handler was already disposed.
Looks like this (block with a light green background) when you are already authorized:
hi, just updated to 3.3M6 - having the same issues.
going ābasicā with;
UID: netatmo:account:<UID>
label: Bridge - Netatmo
thingTypeUID: netatmo:account
configuration:
reconnectInterval: 300
clientSecret: <client_secret>
clientId: <client_id>
ā¦leads to: āConfiguration incomplete, please grant the binding to Netatmo Connect.ā
adding the refreshtoken;
configuration:
refreshToken: <refresh_token>
ā¦leads to: āUnexpected error deserializing ā{āerrorā:āinvalid_grantā}āā
removing the refresh-token again (as mentioned above) and heading to
http://<openhab_ip>:8192/netatmo/connect/<client_id>
ā¦leads to āERR_CONNECTION_REFUSEDā for multiple browsers (Chrome, Firefox, Edge).
Iām using Securing Communication and Access | openHAB for nginx config.
EDIT #1:
Iām able now to auth via :8080 (:8192 doesnāt work) - http://<openhab_ip>:8080/netatmo/connect/<client_id>
The bridge is now āONLINEā, but the funny thing is - the refresh token, that is now added to the thing-config is exactly the same I added manually and lead to āUnexpected error deserializing '{āerrorā:āinvalid_grantā}ā.
Again, the binding works for me now, but maybe you could add those additional infos to the binding-docs.
Port was 8192 because the user defined a specific port for OH.
For most of users, the port will be 8080 and this is what is documented.
I have a doorbell and Iām using the actual binding from milestone OH3.3M6.
I configured the webhook part and partially it works.
But the following channels are not updated:
sub-event#type -> only value "Motion detected by Outdoor Camera" seen
sub-event#message -> remains empty
sub-event#snapshot -> remains UNDEF
sub-event#snapshot-url -> remains NULL
sub-event#vignette -> remains UNDEF
sub-event#vignette-url -> remains NULL
Here are the JSONās from the events which are written to openhab.log when loglevel is set to DEBUG.
incoming call:
"user_id": "xxxxxxxxxxxxxxxxxxxxxxxx",
"event_type": "incoming_call",
"device_id": "xx:xx:xx:xx:xx:xx",
"home_id": "xxxxxxxxxxxxxxxxxxxxxxxx",
"home_name": "Mein Haus",
"camera_id": "xx:xx:xx:xx:xx:xx",
"event_id": "xxxxxxxxxxxxxxxxxxxxxxxx",
"subevent_id": "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx",
"snapshot_url": "https://netatmocameraimage.blob.core.windows.net/production/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
"vignette_url": "https://netatmocameraimage.blob.core.windows.net/production/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
"session_id": "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx",
"push_type": "NDB-incoming_call"
motion detected:
"snapshot_id": "xxxxxxxxxxxxxxxxxxxxxxxx",
"snapshot_key": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
"vignette_id": "xxxxxxxxxxxxxxxxxxxxxxxx",
"vignette_key": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
"event_type": "human",
"message": "Person erfasst",
"push_type": "NDB-human"
I have also a direct webhook via the http binding installed, and there I get all the values from the webhook push notification.
Anyone else having this issue with the netatmo binding ?
This is probably an issue with webhook in the binding. As i understood, this part was not really tested by anyone.
Ideally an issue should be opened in GitHun.
Thanks, I opened a bugreport
Iām happy to help here with testing if needed.
I need to go through the grant process every time I reboot openhab (the token exists, but it needs to be reactivated every time)
@glhopital is this expected?
Andrea
For sure not. Are you file or UI based configured?
file based.
let me share my things
Bridge netatmo:account:home "Netatmo Account" [clientId="xxxxxxxxxxxxx", clientSecret="xxxxxxxxxxxxxxxx", username = "xxxxx@xxxxxxxxx", password = "xxxxxxxxxx"] {
Bridge weather-station station "Netatmo Weather Station" @ "Living Room" [id="70:ee:50:01:c2:66"] {
Thing outdoor outside "Netatmo Outdoor" @ "Outdoor" [id="02:00:00:01:f2:5c"]
Thing wind wind "Netatmo Wind Gauge" @ "Outdoor" [id="06:00:00:00:86:1e"]
Thing rain rain "Netatmo Rain Gauge" @ "Outdoor" [id="05:00:00:04:55:90"] {
// Channels:
// Type sum_rain-measurement: rainThisWeek "Rain This Week" [period="1week"]
// Type sum_rain-measurement: rainThisMonth "Rain This Month" [period="1month"]
Thing indoor kitchen "Netatmo Kitchen" @ "Kitchen" [id="03:00:00:01:1e:c8"]
Thing indoor library "Netatmo Library" @ "Library" [id="03:00:00:01:24:2e"]
Thing indoor hobbyroom "Netatmo Caty's Room" @ "Caty's Room" [id="03:00:00:03:4b:ea"]
Thing home-coach bedroom "Netatmo Bedroom" @ "Bedroom" [id="70:ee:50:26:51:36"]
Ok, this is clear, you are providing username and password settings and not the token as now expected.
Please check the documentation and the example
@glhopital : can you explain where in MainUI you can add new channels to the weather station thing, like for example a channel for the max temperature during the last month. I do not find that in UI. Is it available in MainUI even if my thing is defined in a config file ?
I am waiting for your answer, maybe it is obvious and I donāt see it. Maybe it should be documented in README.
Maybe is it because your thing is file based ?
