New OH 2.0 installation - issue with zwave controller
Hi folks,
I’ve issues with my zwave controller.
I’ve installed OH 2.0 via apt-get.
The log is quite useless, I think:
2016-07-15 12:56:58.150 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Controller Configuration update received
2016-07-15 12:56:58.155 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Controller Configuration update port to /dev/zwavecontroller
2016-07-15 12:56:58.205 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
2016-07-15 12:56:58.211 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Initializing ZWave serial controller.
2016-07-15 12:56:58.211 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Initializing ZWave Controller.
2016-07-15 12:56:58.212 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port ‘/dev/zwavecontroller’
I’ve also tried to change the level to TRACE via Karaf, but same log.
I don’t know if also with OH 2.0 we need to add in the startup script:
-Dgnu.io.rxtx.SerialPorts=/dev/zwavecontroller \
as I did in the previous installation on my ‘openhab’ script.
Any suggestion?
openhab already in dialout group
crw-rw---- 1 root dialout 188, 0 Jul 15 11:36 ttyUSB0
lrwxrwxrwx 1 root root 7 Jul 15 11:36 zwavecontroller → ttyUSB0
a difference with the previous installation:
crw-rw—T 1 root dialout 188, 0 Jul 15 13:01 ttyUSB0
what that “T” means?
Andrea
You need to set this on:
/usr/share/openhab2/runtime/karaf/bin/setenv
That would do the trick.
Cheers
Andrea
