New OH3 Binding - Midea Air Conditioning (LAN)
Hi All,
please find new Openhab 3 binding for Midea Air Conditioning working in LAN:
Testing and contribution appreciated.
Release notes (202102092117):
  • Channel name convention change (i.e. operational-mode → operationalMode)
  • Added description: Turbo mode works only for HEAT and COOL mode.
  • Discovery changes.
  • Connection keep alive fix.
  • Swing mode: check first if works using IR Remote Controller, tested and it is working
Release notes (202102101202):
  • Discovery fix for v.3.
  • Discovery for manually added things.
Release notes (202102111608):
Release notes (202103031355):
  • Error handling.
Release notes (202106211204):
  • Migration from org.apache.commons.lang,org.apache.commons.lang to org.apache.commons.lang,org.apache.commons.lang3.
Release notes (202107181935):
  • Unresolved requirement: Import-Package: javax.measure fix.
Release notes (202107201301):
  • Unresolved requirement: Import-Package: javax.measure fix 2.
    Tested on 3.1.0 - Release Build
Release notes (202107201938):
  • Celcius/Farenheits in API request fix.
Release notes (202204111742):
  • Unit provider fix
    Tested on openHAB 3.2.0 - Release Build
Release notes (202204280938):
  • Connecting timeout parameter (where there are some issues with continuous disconnecting and connecting)
  • New parameter “Token” - for use with v3, implementation is starting together with community members
Release notes (202205221059):
  • Version 3 support!
  • For version 3 Token and Key must be provided. It can be automatically obtained from Cloud by entering email and password for MSmartHome, not Midea Air!. Not need to add devices in MSmartHome, only creating account and logging in is required.
  • Swing mode is not supported for v3 (neither cloud nor LAN protocol)
  • Many thanks for @justaoldman for contribution: protocol verification, device via VPN sharing, tests and many more
Release notes (202205312143):
  • Added “Midea Air” and “NetHome Plus” Cloud Providers for key and token retrieval
Thanks for this binding, really happy with it.
Unfortunately, I do have some issues getting it working. Could you take a look to the logs?
Used both auto discovery and a manual creating Thing.
When I use my manual created Thing, the following logs are shown:
2021-02-09 22:37:19.783 [DEBUG] [eaac.internal.handler.MideaACHandler] - MideaACHandler config for mideaac:ac:2af1d3ba53 is org.openhab.binding.mideaac.internal.MideaACConfiguration@a68dc6
2021-02-09 22:37:19.789 [DEBUG] [eaac.internal.handler.MideaACHandler] - IPAddress: 192.168.0.134
2021-02-09 22:37:19.790 [DEBUG] [eaac.internal.handler.MideaACHandler] - IPPort: 6444
2021-02-09 22:37:19.793 [TRACE] [ler.MideaACHandler$ConnectionManager] - Connecting to mideaac:ac:2af1d3ba53 at 192.168.0.134:6444
2021-02-09 22:37:19.799 [INFO ] [ler.MideaACHandler$ConnectionManager] - Connected to mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-09 22:37:19.800 [DEBUG] [eaac.internal.handler.MideaACHandler] - Changing status of mideaac:ac:2af1d3ba53 from UNKNOWN(NONE) to ONLINE
2021-02-09 22:37:19.812 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Writing to mideaac:ac:2af1d3ba53 at 192.168.0.134 bytes.length: 104, bytes: 5A5A0111680020000000000001150109162513008F7A0000001200000000000000000000000000006B000A76E27EED2C3647E57D8602DF8BC34434DCF8B3D50C422CC227583DA33AFCA5CF91D6D609EF6FBF6E4BFE2E934021D528ABA84EADA753AF458B2B8264BD
2021-02-09 22:37:19.767 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mideaac:ac:2af1d3ba53' changed from UNINITIALIZED (DISABLED) to INITIALIZING
2021-02-09 22:37:19.792 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mideaac:ac:2af1d3ba53' changed from INITIALIZING to UNKNOWN
2021-02-09 22:37:19.807 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mideaac:ac:2af1d3ba53' changed from UNKNOWN to ONLINE
2021-02-09 22:37:23.814 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Disconnecting from mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-09 22:37:23.815 [DEBUG] [eaac.internal.handler.MideaACHandler] - Changing status of mideaac:ac:2af1d3ba53 from ONLINE(NONE) to OFFLINE
2021-02-09 22:37:23.817 [DEBUG] [eaac.internal.handler.MideaACHandler] - Changing status of mideaac:ac:2af1d3ba53 from OFFLINE(NONE) to OFFLINE(COMMUNICATION_ERROR)
2021-02-09 22:37:24.070 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Starting connection monitor job in 10 seconds for mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-09 22:37:23.818 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mideaac:ac:2af1d3ba53' changed from ONLINE to OFFLINE
2021-02-09 22:37:23.820 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mideaac:ac:2af1d3ba53' changed from OFFLINE to UNKNOWN
2021-02-09 22:37:24.072 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mideaac:ac:2af1d3ba53' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Read timed out
2021-02-09 22:37:34.072 [TRACE] [ler.MideaACHandler$ConnectionManager] - Performing connection check for mideaac:ac:2af1d3ba53 at IP 192.168.0.134
2021-02-09 22:37:34.084 [TRACE] [ler.MideaACHandler$ConnectionManager] - Checking status of connection for mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-09 22:37:34.085 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Connection check FAILED for mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-09 22:37:34.088 [TRACE] [ler.MideaACHandler$ConnectionManager] - Connecting to mideaac:ac:2af1d3ba53 at 192.168.0.134:6444
2021-02-09 22:37:34.091 [INFO ] [ler.MideaACHandler$ConnectionManager] - Connected to mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-09 22:37:34.092 [DEBUG] [eaac.internal.handler.MideaACHandler] - Changing status of mideaac:ac:2af1d3ba53 from OFFLINE(COMMUNICATION_ERROR) to ONLINE
2021-02-09 22:37:34.093 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Cancelling connection monitor job for mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-09 22:37:34.096 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Writing to mideaac:ac:2af1d3ba53 at 192.168.0.134 bytes.length: 104, bytes: 5A5A0111680020000000000001150109162522008F7A0000001200000000000000000000000000006B000A76E27EED2C3647E57D8602DF8BB8FD313676651C24F6A79E1ED661AE4751A1911793778FEBE1BFC0B33F600E14FA797D3595E90CF8371F46988AC56BDA
2021-02-09 22:37:34.097 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mideaac:ac:2af1d3ba53' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to ONLINE
When I do use auto-discovery now the following errors are shown:
2021-02-09 22:38:49.405 [DEBUG] [al.discovery.MideaACDiscoveryService] - Stop scan for Midea AC devices.
2021-02-09 22:38:49.455 [DEBUG] [al.discovery.MideaACDiscoveryService] - Start scan for Midea AC devices.
2021-02-09 22:38:49.457 [TRACE] [al.discovery.MideaACDiscoveryService] - Broadcast discovery package sent to port: 6445
2021-02-09 22:38:49.459 [TRACE] [al.discovery.MideaACDiscoveryService] - Broadcast discovery package sent to port: 20086
2021-02-09 22:38:49.460 [DEBUG] [al.discovery.MideaACDiscoveryService] - Midea AC device discovery returned package with length 192
2021-02-09 22:38:49.462 [DEBUG] [al.discovery.MideaACDiscoveryService] - Midea AC discover data (192) from 192.168.0.134: '837000B8200F04165A5A0111A8007A800000000000000000000000008F7A00000012000000000000000000000000000047932C79C0D562B61613413CE63185AA7C5179B1DE29DA3850D76D9BEB6696C47334F12E1B1BBE130E804BF44E734F15387CE42D8219955D5CDD4D1D89EA7042D95A234C982BBD7E2E4FD984AACE85051FCA94541303884C52E880DDEFC03190F31443D17C3AAC03A7656614AE1DCA4492D862B4969D333100415C58A4FC2A259ED437779EFC49135EB2D2E1D8AB492D'
2021-02-09 22:38:49.463 [TRACE] [al.discovery.MideaACDiscoveryService] - Device supported
2021-02-09 22:38:49.467 [TRACE] [al.discovery.MideaACDiscoveryService] - Version: 3
2021-02-09 22:38:49.468 [TRACE] [al.discovery.MideaACDiscoveryService] - Id Bytes: 000000000000
2021-02-09 22:38:49.470 [DEBUG] [al.discovery.MideaACDiscoveryService] - Id: '0'
2021-02-09 22:38:49.471 [DEBUG] [al.discovery.MideaACDiscoveryService] - Encrypt data: '000000000000000047932C79C0D562B61613413CE63185AA7C5179B1DE29DA3850D76D9BEB6696C47334F12E1B1BBE130E804BF44E734F15387CE42D8219955D5CDD4D1D89EA7042D95A234C982BBD7E2E4FD984AACE85051FCA94541303884C52E880DDEFC03190F31443D17C3AAC03A7656614AE1DCA4492D862B4969D333100415C58A4FC2A25'
2021-02-09 22:38:49.487 [ERROR] [nternal.DiscoveryServiceRegistryImpl] - Cannot trigger scan for thing types '[mideaac:ac]' on 'MideaACDiscoveryService'!
	at org.openhab.binding.mideaac.internal.discovery.MideaACDiscoveryService.thingDiscovered(MideaACDiscoveryService.java:196) ~[?:?]
	at org.openhab.binding.mideaac.internal.discovery.MideaACDiscoveryService.discoverThings(MideaACDiscoveryService.java:103) ~[?:?]
	at org.openhab.binding.mideaac.internal.discovery.MideaACDiscoveryService.startScan(MideaACDiscoveryService.java:73) ~[?:?]
2021-02-09 22:38:58.276 [TRACE] [ler.MideaACHandler$ConnectionManager] - Performing connection check for mideaac:ac:2af1d3ba53 at IP 192.168.0.134
2021-02-09 22:38:58.277 [TRACE] [ler.MideaACHandler$ConnectionManager] - Checking status of connection for mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-09 22:38:58.278 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Connection check FAILED for mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-09 22:38:58.279 [TRACE] [ler.MideaACHandler$ConnectionManager] - Connecting to mideaac:ac:2af1d3ba53 at 192.168.0.134:6444
2021-02-09 22:38:58.281 [INFO ] [ler.MideaACHandler$ConnectionManager] - Connected to mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-09 22:38:58.282 [DEBUG] [eaac.internal.handler.MideaACHandler] - Changing status of mideaac:ac:2af1d3ba53 from UNINITIALIZED(DISABLED) to ONLINE
2021-02-09 22:38:58.283 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MideaACHandler tried updating the thing status although the handler was already disposed.
2021-02-09 22:38:58.284 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Cancelling connection monitor job for mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-09 22:38:58.286 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Writing to mideaac:ac:2af1d3ba53 at 192.168.0.134 bytes.length: 104, bytes: 5A5A011168002000000000000115010916263A008F7A0000001200000000000000000000000000006B000A76E27EED2C3647E57D8602DF8BDE4F2B588DC2921FDDF07250DB6C06B34D05A824584A61AFE6A47C30DB38097929A336B3995162575D469785AEF532CB
2021-02-09 22:39:02.290 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Disconnecting from mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-09 22:39:02.300 [DEBUG] [eaac.internal.handler.MideaACHandler] - Changing status of mideaac:ac:2af1d3ba53 from UNINITIALIZED(DISABLED) to OFFLINE(COMMUNICATION_ERROR)
Check new release.
Thanks! Did try the new version, the reported logs are changed. The DeviceID is now reported back (removed this from the log).
When using auto-discovery the logs tell:
2021-02-10 21:10:46.982 [DEBUG] [al.discovery.MideaACDiscoveryService] - Stop scan for Midea AC devices.
2021-02-10 21:10:46.988 [DEBUG] [al.discovery.MideaACDiscoveryService] - Start scan for Midea AC devices.
2021-02-10 21:10:46.990 [TRACE] [al.discovery.MideaACDiscoveryService] - Discovering: 255.255.255.255
2021-02-10 21:10:46.993 [TRACE] [al.discovery.MideaACDiscoveryService] - Broadcast discovery package sent to port: 6445
2021-02-10 21:10:46.995 [TRACE] [al.discovery.MideaACDiscoveryService] - Broadcast discovery package sent to port: 20086
2021-02-10 21:10:46.999 [DEBUG] [al.discovery.MideaACDiscoveryService] - Midea AC device discovery returned package with length 192
2021-02-10 21:10:47.002 [DEBUG] [al.discovery.MideaACDiscoveryService] - Midea AC discover data (192) from 192.168.0.134: '837000B8200F04365A5A0111A8007A800000000000000000000000008F7A00000012000000000000000000000000000047932C79C0D562B61613413CE63185AA7C5179B1DE29DA3850D76D9BEB6696C47334F12E1B1BBE130E804BF44E734F15387CE42D8219955D5CDD4D1D89EA7042D95A234C982BBD7E2E4FD984AACE85051FCA94541303884C52E880DDEFC03190F31443D17C3AAC03A7656614AE1DCA4492D862B4969D333100415C58A4FC2A259ED437779EFC49135EB2D2E1D8AB492D'
2021-02-10 21:10:47.003 [TRACE] [al.discovery.MideaACDiscoveryService] - Device supported
2021-02-10 21:10:47.005 [TRACE] [al.discovery.MideaACDiscoveryService] - Version: 3
2021-02-10 21:10:47.006 [TRACE] [al.discovery.MideaACDiscoveryService] - Id Bytes: xxxxxxx
2021-02-10 21:10:47.023 [DEBUG] [al.discovery.MideaACDiscoveryService] - Id: 'xxxxxxx'
2021-02-10 21:10:47.025 [DEBUG] [al.discovery.MideaACDiscoveryService] - Encrypt data: '47932C79C0D562B61613413CE63185AA7C5179B1DE29DA3850D76D9BEB6696C47334F12E1B1BBE130E804BF44E734F15387CE42D8219955D5CDD4D1D89EA7042D95A234C982BBD7E2E4FD984AACE85051FCA94541303884C52E880DDEFC03190F31443D17C3AAC03A7656614AE1DCA4492D862B4969D3331'
2021-02-10 21:10:47.036 [ERROR] [nternal.DiscoveryServiceRegistryImpl] - Cannot trigger scan for thing types '[mideaac:ac]' on 'MideaACDiscoveryService'!
	at org.openhab.binding.mideaac.internal.discovery.MideaACDiscoveryService.discoveryPacketReceived(MideaACDiscoveryService.java:252) ~[?:?]
	at org.openhab.binding.mideaac.internal.discovery.MideaACDiscoveryService.thingDiscovered(MideaACDiscoveryService.java:207) ~[?:?]
	at org.openhab.binding.mideaac.internal.discovery.MideaACDiscoveryService.discoverThings(MideaACDiscoveryService.java:107) ~[?:?]
	at org.openhab.binding.mideaac.internal.discovery.MideaACDiscoveryService.startScan(MideaACDiscoveryService.java:77) ~[?:?]
	at org.openhab.core.config.discovery.AbstractDiscoveryService.startScan(AbstractDiscoveryService.java:194) ~[bundleFile:?]
	at org.openhab.core.config.discovery.internal.DiscoveryServiceRegistryImpl.startScan(DiscoveryServiceRegistryImpl.java:377) [bundleFile:?]
	at org.openhab.core.config.discovery.internal.DiscoveryServiceRegistryImpl.startScans(DiscoveryServiceRegistryImpl.java:362) [bundleFile:?]
	at org.openhab.core.config.discovery.internal.DiscoveryServiceRegistryImpl.startScan(DiscoveryServiceRegistryImpl.java:211) [bundleFile:?]
	at org.openhab.core.io.rest.core.internal.discovery.DiscoveryResource.scan(DiscoveryResource.java:105) [bundleFile:?]
	at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
	at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
	at org.apache.cxf.service.invoker.AbstractInvoker.performInvocation(AbstractInvoker.java:179) [bundleFile:1.0.9]
	at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:96) [bundleFile:1.0.9]
	at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:201) [bundleFile:1.0.9]
	at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:104) [bundleFile:1.0.9]
	at org.apache.cxf.interceptor.ServiceInvokerInterceptor$1.run(ServiceInvokerInterceptor.java:59) [bundleFile:1.0.9]
	at org.apache.cxf.interceptor.ServiceInvokerInterceptor.handleMessage(ServiceInvokerInterceptor.java:96) [bundleFile:1.0.9]
	at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) [bundleFile:1.0.9]
	at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121) [bundleFile:1.0.9]
	at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:267) [bundleFile:1.0.9]
	at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234) [bundleFile:1.0.9]
	at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208) [bundleFile:1.0.9]
	at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160) [bundleFile:1.0.9]
	at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:216) [bundleFile:1.0.9]
	at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:301) [bundleFile:1.0.9]
	at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doPost(AbstractHTTPServlet.java:220) [bundleFile:1.0.9]
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) [bundleFile:3.1.0]
	at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:276) [bundleFile:1.0.9]
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544) [bundleFile:9.4.20.v20190813]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [bundleFile:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307) [bundleFile:9.4.20.v20190813]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [bundleFile:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [bundleFile:9.4.20.v20190813]
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [bundleFile:?]
	at org.eclipse.jetty.server.Server.handle(Server.java:494) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
When using manual created Thing:
2021-02-10 21:14:06.201 [DEBUG] [eaac.internal.handler.MideaACHandler] - MideaACHandler config for mideaac:ac:2af1d3ba53 is org.openhab.binding.mideaac.internal.MideaACConfiguration@26564f
2021-02-10 21:14:06.203 [DEBUG] [eaac.internal.handler.MideaACHandler] - Configuration valid for mideaac:ac:2af1d3ba53
2021-02-10 21:14:06.204 [DEBUG] [eaac.internal.handler.MideaACHandler] - IPAddress: 192.168.0.134
2021-02-10 21:14:06.205 [DEBUG] [eaac.internal.handler.MideaACHandler] - IPPort: 6444
2021-02-10 21:14:06.205 [DEBUG] [eaac.internal.handler.MideaACHandler] - ID: xxxxx
2021-02-10 21:14:06.207 [TRACE] [ler.MideaACHandler$ConnectionManager] - Connecting to mideaac:ac:2af1d3ba53 at 192.168.0.134:6444
2021-02-10 21:14:06.213 [INFO ] [ler.MideaACHandler$ConnectionManager] - Connected to mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-10 21:14:06.215 [DEBUG] [eaac.internal.handler.MideaACHandler] - Changing status of mideaac:ac:2af1d3ba53 from UNKNOWN(NONE) to ONLINE
2021-02-10 21:14:06.226 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Writing to mideaac:ac:2af1d3ba53 at 192.168.0.134 bytes.length: 104, bytes: 5A5A011168002000000000000115010A150E06008F7A0000001200000000000000000000000000006B000A76E27EED2C3647E57D8602DF8BF295FCC1F4B9CE80E506AB2A879FE3C5A8A539F3DED2B04298069292E4AD666EB3BACF7400B7FBD6DB91C744D19F0C61
2021-02-10 21:14:06.183 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mideaac:ac:2af1d3ba53' changed from UNINITIALIZED (DISABLED) to INITIALIZING
2021-02-10 21:14:06.208 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mideaac:ac:2af1d3ba53' changed from INITIALIZING to UNKNOWN
2021-02-10 21:14:06.218 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mideaac:ac:2af1d3ba53' changed from UNKNOWN to ONLINE
2021-02-10 21:14:10.232 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Disconnecting from mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-10 21:14:10.233 [DEBUG] [eaac.internal.handler.MideaACHandler] - Changing status of mideaac:ac:2af1d3ba53 from ONLINE(NONE) to OFFLINE
2021-02-10 21:14:10.235 [DEBUG] [eaac.internal.handler.MideaACHandler] - Changing status of mideaac:ac:2af1d3ba53 from OFFLINE(NONE) to OFFLINE(COMMUNICATION_ERROR)
2021-02-10 21:14:10.488 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Starting connection monitor job in 10 seconds for mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-10 21:14:10.236 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mideaac:ac:2af1d3ba53' changed from ONLINE to OFFLINE
2021-02-10 21:14:10.238 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mideaac:ac:2af1d3ba53' changed from OFFLINE to UNKNOWN
2021-02-10 21:14:10.489 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mideaac:ac:2af1d3ba53' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Read timed out
2021-02-10 21:14:20.490 [TRACE] [ler.MideaACHandler$ConnectionManager] - Performing connection check for mideaac:ac:2af1d3ba53 at IP 192.168.0.134
2021-02-10 21:14:20.492 [TRACE] [ler.MideaACHandler$ConnectionManager] - Checking status of connection for mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-10 21:14:20.492 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Connection check FAILED for mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-10 21:14:20.495 [TRACE] [ler.MideaACHandler$ConnectionManager] - Connecting to mideaac:ac:2af1d3ba53 at 192.168.0.134:6444
2021-02-10 21:14:20.498 [INFO ] [ler.MideaACHandler$ConnectionManager] - Connected to mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-10 21:14:20.499 [DEBUG] [eaac.internal.handler.MideaACHandler] - Changing status of mideaac:ac:2af1d3ba53 from OFFLINE(COMMUNICATION_ERROR) to ONLINE
2021-02-10 21:14:20.501 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Cancelling connection monitor job for mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-10 21:14:20.504 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Writing to mideaac:ac:2af1d3ba53 at 192.168.0.134 bytes.length: 104, bytes: 5A5A011168002000000000000115010A150E14008F7A0000001200000000000000000000000000006B000A76E27EED2C3647E57D8602DF8B243C759FEA50480FE9BA4C8F48883C98FF174AA9E74463E03EEDF2F22B80DA1EF5FA2CB5F9DD3EFDF18F3BA3D3AC3E50
2021-02-10 21:14:20.503 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mideaac:ac:2af1d3ba53' changed from OFFLINE (COMMUNICATION_ERROR): Read timed out to ONLINE
Please check new release.
Now the device seems to be discovered correct, only there are some errors. Channels are created but don’t work. Here the logs:
2021-02-11 17:50:29.548 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MideaACHandler tried updating the thing status although the handler was already disposed.
2021-02-11 17:50:29.549 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Starting connection monitor job in 10 seconds for mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-11 17:50:33.447 [DEBUG] [al.discovery.MideaACDiscoveryService] - Stop scan for Midea AC devices.
2021-02-11 17:50:33.464 [DEBUG] [al.discovery.MideaACDiscoveryService] - Start scan for Midea AC devices.
2021-02-11 17:50:33.465 [TRACE] [al.discovery.MideaACDiscoveryService] - Discovering: 255.255.255.255
2021-02-11 17:50:33.471 [TRACE] [al.discovery.MideaACDiscoveryService] - Broadcast discovery package sent to port: 6445
2021-02-11 17:50:33.472 [TRACE] [al.discovery.MideaACDiscoveryService] - Broadcast discovery package sent to port: 20086
2021-02-11 17:50:33.572 [DEBUG] [al.discovery.MideaACDiscoveryService] - Midea AC device discovery returned package with length 192
2021-02-11 17:50:33.575 [DEBUG] [al.discovery.MideaACDiscoveryService] - Midea AC discover data (192) from 192.168.0.134: '837000B8200F04025A5A0111A8007A80000000000000000000000000xxxx000000000000000000000000000047932C79C0D562B61613413CE63185AA7C5179B1DE29DA3850D76D9BEB6696C47334F12E1B1BBE130E804BF44E734F15387CE42D8219955D5CDD4D1D89EA7042D95A234C982BBD7E2E4FD984AACE85051FCA94541303884C52E880DDEFC03190F31443D17C3AAC03A7656614AE1DCA4492D862B4969D333100415C58A4FC2A259ED437779EFC49135EB2D2E1D8AB492D'
2021-02-11 17:50:33.576 [TRACE] [al.discovery.MideaACDiscoveryService] - Device supported
2021-02-11 17:50:33.578 [TRACE] [al.discovery.MideaACDiscoveryService] - Version: 3
2021-02-11 17:50:33.579 [TRACE] [al.discovery.MideaACDiscoveryService] - Id Bytes: xxxx
2021-02-11 17:50:33.580 [DEBUG] [al.discovery.MideaACDiscoveryService] - Id: 'xxxx'
2021-02-11 17:50:33.582 [DEBUG] [al.discovery.MideaACDiscoveryService] - Encrypt data: '47932C79C0D562B61613413CE63185AA7C5179B1DE29DA3850D76D9BEB6696C47334F12E1B1BBE130E804BF44E734F15387CE42D8219955D5CDD4D1D89EA7042D95A234C982BBD7E2E4FD984AACE85051FCA94541303884C52E880DDEFC03190F31443D17C3AAC03A7656614AE1DCA44'
2021-02-11 17:50:33.588 [DEBUG] [al.discovery.MideaACDiscoveryService] - Length: 109, Reply: '8600A8C02C19000030303030303050303030303030305131353032444242353938414536303030300B6E65745F61635F384145360000000001000000040000000000AC00000000000000502DBB598AE6069FCD0300080103000000000000000000000000000000000000000000'
2021-02-11 17:50:33.589 [DEBUG] [al.discovery.MideaACDiscoveryService] - Reply: '���, xxxx
2021-02-11 17:50:33.591 [DEBUG] [al.discovery.MideaACDiscoveryService] - IP: '192.168.0.134'
2021-02-11 17:50:33.592 [DEBUG] [al.discovery.MideaACDiscoveryService] - Port: '6444'
2021-02-11 17:50:33.594 [DEBUG] [al.discovery.MideaACDiscoveryService] - SN: 'xxxx'
2021-02-11 17:50:33.595 [TRACE] [al.discovery.MideaACDiscoveryService] - SSID length: '11'
2021-02-11 17:50:33.596 [DEBUG] [al.discovery.MideaACDiscoveryService] - SSID: 'net_ac_XXX'
2021-02-11 17:50:33.597 [DEBUG] [al.discovery.MideaACDiscoveryService] - Type: 'ac'
2021-02-11 17:50:38.463 [DEBUG] [al.discovery.MideaACDiscoveryService] - Stop scan for Midea AC devices.
2021-02-11 17:50:39.551 [TRACE] [ler.MideaACHandler$ConnectionManager] - Performing connection check for mideaac:ac:2af1d3ba53 at IP 192.168.0.134
2021-02-11 17:50:39.552 [TRACE] [ler.MideaACHandler$ConnectionManager] - Checking status of connection for mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-11 17:50:39.552 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Connection check FAILED for mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-11 17:50:39.553 [TRACE] [ler.MideaACHandler$ConnectionManager] - Connecting to mideaac:ac:2af1d3ba53 at 192.168.0.134:6444
2021-02-11 17:50:39.556 [INFO ] [ler.MideaACHandler$ConnectionManager] - Connected to mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-11 17:50:39.558 [DEBUG] [eaac.internal.handler.MideaACHandler] - Changing status of mideaac:ac:2af1d3ba53 from UNINITIALIZED(HANDLER_MISSING_ERROR) to ONLINE
2021-02-11 17:50:39.559 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MideaACHandler tried updating the thing status although the handler was already disposed.
2021-02-11 17:50:39.560 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Cancelling connection monitor job for mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-11 17:50:39.561 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Writing to mideaac:ac:2af1d3ba53 at 192.168.0.134 bytes.length: 104, bytes: 5A5A011168002000000000000115010B11322700xxxx00000000000000000000000000006B000A76E27EED2C3647E57D8602DF8BA4CB06C3487AE47C7644A8DFD9233E2BDD915CEEC7BD6BB31E4330477192B2131D3BA64A8068682AFD2A8F027B802B12
2021-02-11 17:50:43.567 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Disconnecting from mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-11 17:50:43.568 [DEBUG] [eaac.internal.handler.MideaACHandler] - Changing status of mideaac:ac:2af1d3ba53 from UNINITIALIZED(HANDLER_MISSING_ERROR) to OFFLINE(COMMUNICATION_ERROR)
2021-02-11 17:50:43.569 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MideaACHandler tried updating the thing status although the handler was already disposed.
2021-02-11 17:50:43.570 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Starting connection monitor job in 10 seconds for mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-11 17:50:53.571 [TRACE] [ler.MideaACHandler$ConnectionManager] - Performing connection check for mideaac:ac:2af1d3ba53 at IP 192.168.0.134
2021-02-11 17:50:53.576 [TRACE] [ler.MideaACHandler$ConnectionManager] - Checking status of connection for mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-11 17:50:53.578 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Connection check FAILED for mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-11 17:50:53.579 [TRACE] [ler.MideaACHandler$ConnectionManager] - Connecting to mideaac:ac:2af1d3ba53 at 192.168.0.134:6444
2021-02-11 17:50:53.589 [INFO ] [ler.MideaACHandler$ConnectionManager] - Connected to mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-11 17:50:53.590 [DEBUG] [eaac.internal.handler.MideaACHandler] - Changing status of mideaac:ac:2af1d3ba53 from UNINITIALIZED(HANDLER_MISSING_ERROR) to ONLINE
2021-02-11 17:50:53.592 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MideaACHandler tried updating the thing status although the handler was already disposed.
2021-02-11 17:50:53.597 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Cancelling connection monitor job for mideaac:ac:2af1d3ba53 at 192.168.0.134
2021-02-11 17:50:53.600 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Writing to mideaac:ac:2af1d3ba53 at 192.168.0.134 bytes.length: 104, bytes: 5A5A011168002000000000000115010B11323500xxxx00000000000000000000000000006B000A76E27EED2C3647E57D8602DF8BF1CA5B02D25A8CDB0C30BE971FDB12777A6D2FD0AA2DBAC5227E569B8730A9F5A0778A9DA1B3A6A854498C9BC281F830
2021-02-11 17:50:57.245 [DEBUG] [eaac.internal.handler.MideaACHandler] - MideaACHandler config for mideaac:ac:mideaac__192_168_0_134__xxxx__net_ac_8ae6 is org.openhab.binding.mideaac.internal.MideaACConfiguration@1685412
Now the channels are created, when sending the power ON command the following error was shown:
2021-02-11 17:52:17.086 [DEBUG] [eaac.internal.handler.MideaACHandler] - Handling channelUID power with command ON
2021-02-11 17:52:17.092 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.mideaac.internal.handler.MideaACHandler@16fd235': null
	at org.openhab.binding.mideaac.internal.handler.CommandSet.fromResponse(CommandSet.java:25) ~[?:?]
	at org.openhab.binding.mideaac.internal.handler.MideaACHandler.handlePower(MideaACHandler.java:144) ~[?:?]
	at org.openhab.binding.mideaac.internal.handler.MideaACHandler.handleCommand(MideaACHandler.java:123) ~[?:?]```
Manual creation of Thing shows same connection error.
@JacekDob
https://community.openhab.org/t/re-new-oh3-binding-midea-air-conditioning-lan/116802
You created a different topic, guess this was not the intention? Perhaps due to replying per mail.
On topic, the shown logs are the fulls logs, from start of scanning until firing a command. Only the deviceID I changed to xxxx, since this code can be used to take over the unit via internet. The discovered deviceID is correct.
The unit works fine via the NetHome Cloud and Midea app, never tried the HomeAssistant integration. I do not have an HA setup running. I might be able to put something into docker, but do not have any experience with HA.
I think somewhere in the check of the device is something going wrong. The device is shown ONLINE for about 10 seconds, then a communication error is shown.
Set-up also a separate docker based setup, which shows the following logs:
2021-02-11 20:19:20.253 [DEBUG] [al.discovery.MideaACDiscoveryService] - Stop scan for Midea AC devices.
2021-02-11 20:19:20.254 [DEBUG] [al.discovery.MideaACDiscoveryService] - Start scan for Midea AC devices.
2021-02-11 20:19:20.254 [TRACE] [al.discovery.MideaACDiscoveryService] - Discovering: 255.255.255.255
2021-02-11 20:19:20.254 [TRACE] [al.discovery.MideaACDiscoveryService] - Broadcast discovery package sent to port: 6445
2021-02-11 20:19:20.255 [TRACE] [al.discovery.MideaACDiscoveryService] - Broadcast discovery package sent to port: 20086
2021-02-11 20:19:25.254 [DEBUG] [al.discovery.MideaACDiscoveryService] - Stop scan for Midea AC devices.
2021-02-11 20:21:04.017 [DEBUG] [eaac.internal.handler.MideaACHandler] - MideaACHandler config for mideaac:ac:e2424fcf5e is org.openhab.binding.mideaac.internal.MideaACConfiguration@5385fb36
2021-02-11 20:21:04.017 [DEBUG] [eaac.internal.handler.MideaACHandler] - Configuration valid for mideaac:ac:e2424fcf5e
2021-02-11 20:21:04.022 [DEBUG] [eaac.internal.handler.MideaACHandler] - IPAddress: 192.168.0.134
2021-02-11 20:21:04.022 [DEBUG] [eaac.internal.handler.MideaACHandler] - IPPort: 6444
2021-02-11 20:21:04.022 [DEBUG] [eaac.internal.handler.MideaACHandler] - ID: *xxxxxxxxxxx*
2021-02-11 20:21:04.023 [TRACE] [ler.MideaACHandler$ConnectionManager] - Connecting to mideaac:ac:e2424fcf5e at 192.168.0.134:6444
2021-02-11 20:21:04.028 [INFO ] [ler.MideaACHandler$ConnectionManager] - Connected to mideaac:ac:e2424fcf5e at 192.168.0.134
2021-02-11 20:21:04.029 [DEBUG] [eaac.internal.handler.MideaACHandler] - Changing status of mideaac:ac:e2424fcf5e from UNKNOWN(NONE) to ONLINE
2021-02-11 20:21:04.030 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Writing to mideaac:ac:e2424fcf5e at 192.168.0.134 bytes.length: 104, bytes: 5A5A011168002000000000000115010B141504008F7A0000001200000000000000000000000000006B000A76E27EED2C3647E57D8602DF8B0A8B7738ED91D6762986FAB07EDBD00EC26C0BFB0278A35978BC4BE27A65AA398739E6924BC3AFC87D7C1FEFB9429D26
2021-02-11 20:21:08.036 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Disconnecting from mideaac:ac:e2424fcf5e at 192.168.0.134
2021-02-11 20:21:08.037 [DEBUG] [eaac.internal.handler.MideaACHandler] - Changing status of mideaac:ac:e2424fcf5e from ONLINE(NONE) to OFFLINE
2021-02-11 20:21:08.037 [DEBUG] [eaac.internal.handler.MideaACHandler] - Changing status of mideaac:ac:e2424fcf5e from OFFLINE(NONE) to OFFLINE(COMMUNICATION_ERROR)
2021-02-11 20:21:08.289 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Starting connection monitor job in 10 seconds for mideaac:ac:e2424fcf5e at 192.168.0.134
2021-02-11 20:21:18.290 [TRACE] [ler.MideaACHandler$ConnectionManager] - Performing connection check for mideaac:ac:e2424fcf5e at IP 192.168.0.134
2021-02-11 20:21:18.291 [TRACE] [ler.MideaACHandler$ConnectionManager] - Checking status of connection for mideaac:ac:e2424fcf5e at 192.168.0.134
2021-02-11 20:21:18.291 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Connection check FAILED for mideaac:ac:e2424fcf5e at 192.168.0.134
2021-02-11 20:21:18.292 [TRACE] [ler.MideaACHandler$ConnectionManager] - Connecting to mideaac:ac:e2424fcf5e at 192.168.0.134:6444
2021-02-11 20:21:18.294 [INFO ] [ler.MideaACHandler$ConnectionManager] - Connected to mideaac:ac:e2424fcf5e at 192.168.0.134
2021-02-11 20:21:18.295 [DEBUG] [eaac.internal.handler.MideaACHandler] - Changing status of mideaac:ac:e2424fcf5e from OFFLINE(COMMUNICATION_ERROR) to ONLINE
2021-02-11 20:21:18.295 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Cancelling connection monitor job for mideaac:ac:e2424fcf5e at 192.168.0.134
2021-02-11 20:21:18.299 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Writing to mideaac:ac:e2424fcf5e at 192.168.0.134 bytes.length: 104, bytes: 5A5A011168002000000000000115010B141512008F7A0000001200000000000000000000000000006B000A76E27EED2C3647E57D8602DF8B5E41B98D2C559357BF4D969E4E51128683EFFAE6AB2599D19AEB1AF38245FCA77D1F74F9A088FECCF4399A313D340D0A```
Here you also see the check if the device is online fails.
I can test things if you like, but are not a developer unfortunately. Will try to set up the HA integration.
Well if your DeviceId is properly obtained then ok.
Looking on the log it seems that IP and port is correct, as it is connecting to device (TCP connection) properly.
After connecting status request message is sent, but there is no answer and then device goes to OFFLINE.
Every Polling Time interval (default 10s.) connection is checked again.
So my conclusion is there is something different in protocol to device with your version 3, so currently created either request status message or any other message (like changin power) there is no response from device.
As wrote before: my binding is based on python script which is supported in HomeAssistant: if you can check it and it is working there, then I can fix it. If not further more complicated investigation would be needed.
Jacek
Hello Jacek!
I insttaled latest jar. It found my unit. I added it as a thing and added all the channels. After disabeling an enabeling it starts but then goes to uninitialized.
2021-02-21 17:03:22.271 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2021-02-21 17:03:35.006 [DEBUG] [eaac.internal.handler.MideaACHandler] - MideaACHandler config for mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b is org.openhab.binding.mideaac.internal.MideaACConfiguration@1b52a51
2021-02-21 17:03:35.013 [DEBUG] [eaac.internal.handler.MideaACHandler] - Configuration valid for mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b
2021-02-21 17:03:35.015 [DEBUG] [eaac.internal.handler.MideaACHandler] - IPAddress: 192.168.1.130
2021-02-21 17:03:35.016 [DEBUG] [eaac.internal.handler.MideaACHandler] - IPPort: 6444
2021-02-21 17:03:35.018 [DEBUG] [eaac.internal.handler.MideaACHandler] - ID: xxxxxxxxx
2021-02-21 17:03:35.021 [TRACE] [ler.MideaACHandler$ConnectionManager] - Connecting to mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b at 192.168.1.130:6444
2021-02-21 17:03:35.470 [INFO ] [ler.MideaACHandler$ConnectionManager] - Connected to mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b at 192.168.1.130
2021-02-21 17:03:35.472 [DEBUG] [eaac.internal.handler.MideaACHandler] - Changing status of mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b from UNKNOWN(NONE) to ONLINE
2021-02-21 17:03:35.477 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Writing to mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b at 192.168.1.130 bytes.length: 104, bytes: 5A5A011168002000000000000115011511032300DA370000000B00000000000000000000000000006B000A76E27EED2C3647E57D8602DF8B0F7FAFA7EC1FCCCEEAC76BBDD53E49D9D4280338B1AC9710C10EB8C5A0DBF3A42E7684B2A37BEE55D5474AA62C3E4294
2021-02-21 17:03:34.978 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b' changed from UNINITIALIZED (DISABLED) to INITIALIZING
2021-02-21 17:03:35.021 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b' changed from INITIALIZING to UNKNOWN
2021-02-21 17:03:35.475 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b' changed from UNKNOWN to ONLINE
2021-02-21 17:03:37.636 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Response received length: 104
2021-02-21 17:03:37.638 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Response bytes: 5A5A011168002080000000000000000000000000DA370000000B00000000000000000000010000004AD42F5B67DE9DFE7C6A138DE56E6E8BB83406D9BE22FACD2DDD750081674CF8A6968007E820FBFDECDFD566EBBA747BD765B4B200FA786158AC4A3A50F6273C
2021-02-21 17:03:37.641 [TRACE] [ng.mideaac.internal.handler.Response] - Bytes decoded and stripped without header: C0012A657F7F0033000000684C0E00610000001E000000238C
2021-02-21 17:03:37.643 [TRACE] [ng.mideaac.internal.handler.Response] - PowerState: true
2021-02-21 17:03:37.645 [TRACE] [ng.mideaac.internal.handler.Response] - ImodeResume: false
2021-02-21 17:03:37.647 [TRACE] [ng.mideaac.internal.handler.Response] - TimerMode: false
2021-02-21 17:03:37.649 [TRACE] [ng.mideaac.internal.handler.Response] - ApplianceError: false
2021-02-21 17:03:37.651 [TRACE] [ng.mideaac.internal.handler.Response] - TargetTemperature: 26.0
2021-02-21 17:03:37.652 [TRACE] [ng.mideaac.internal.handler.Response] - OperationalMode: AUTO
2021-02-21 17:03:37.654 [TRACE] [ng.mideaac.internal.handler.Response] - FanSpeed: null
2021-02-21 17:03:37.656 [TRACE] [ng.mideaac.internal.handler.Response] - OnTimer: enabled: false
2021-02-21 17:03:37.658 [TRACE] [ng.mideaac.internal.handler.Response] - OffTimer: enabled: false
2021-02-21 17:03:37.660 [TRACE] [ng.mideaac.internal.handler.Response] - SwingMode: HORIZONTAL
2021-02-21 17:03:37.662 [TRACE] [ng.mideaac.internal.handler.Response] - CozySleep: 0
2021-02-21 17:03:37.664 [TRACE] [ng.mideaac.internal.handler.Response] - Save: false
2021-02-21 17:03:37.665 [TRACE] [ng.mideaac.internal.handler.Response] - LowFrequencyFan: false
2021-02-21 17:03:37.667 [TRACE] [ng.mideaac.internal.handler.Response] - SuperFan: false
2021-02-21 17:03:37.669 [TRACE] [ng.mideaac.internal.handler.Response] - FeelOwn: false
2021-02-21 17:03:37.671 [TRACE] [ng.mideaac.internal.handler.Response] - ChildSleepMode: false
2021-02-21 17:03:37.673 [TRACE] [ng.mideaac.internal.handler.Response] - ExchangeAir: false
2021-02-21 17:03:37.675 [TRACE] [ng.mideaac.internal.handler.Response] - DryClean: false
2021-02-21 17:03:37.677 [TRACE] [ng.mideaac.internal.handler.Response] - AuxHeat: false
2021-02-21 17:03:37.679 [TRACE] [ng.mideaac.internal.handler.Response] - EcoMode: false
2021-02-21 17:03:37.680 [TRACE] [ng.mideaac.internal.handler.Response] - CleanUp: false
2021-02-21 17:03:37.682 [TRACE] [ng.mideaac.internal.handler.Response] - TempUnit: false
2021-02-21 17:03:37.684 [TRACE] [ng.mideaac.internal.handler.Response] - SleepFunction: false
2021-02-21 17:03:37.686 [TRACE] [ng.mideaac.internal.handler.Response] - TurboMode: false
2021-02-21 17:03:37.688 [TRACE] [ng.mideaac.internal.handler.Response] - CatchCold: false
2021-02-21 17:03:37.689 [TRACE] [ng.mideaac.internal.handler.Response] - NightLight: false
2021-02-21 17:03:37.692 [TRACE] [ng.mideaac.internal.handler.Response] - PeakElec: false
2021-02-21 17:03:37.694 [TRACE] [ng.mideaac.internal.handler.Response] - NaturalFan: false
2021-02-21 17:03:37.696 [TRACE] [ng.mideaac.internal.handler.Response] - IndoorTemperature: 27.1
2021-02-21 17:03:37.698 [TRACE] [ng.mideaac.internal.handler.Response] - OutdoorTemperature: 13.0
2021-02-21 17:03:37.700 [TRACE] [ng.mideaac.internal.handler.Response] - Humidity: 14
2021-02-21 17:03:37.705 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.openhab.binding.mideaac.internal.handler.MideaACHandler@10b13d3': null
	at org.openhab.binding.mideaac.internal.handler.MideaACHandler$ConnectionManager.processMessage(MideaACHandler.java:621) ~[?:?]
	at org.openhab.binding.mideaac.internal.handler.MideaACHandler$ConnectionManager.sendCommand(MideaACHandler.java:563) ~[?:?]
	at org.openhab.binding.mideaac.internal.handler.MideaACHandler$ConnectionManager.sendCommandAndMonitor(MideaACHandler.java:531) ~[?:?]
	at org.openhab.binding.mideaac.internal.handler.MideaACHandler$ConnectionManager.requestStatus(MideaACHandler.java:523) ~[?:?]
	at org.openhab.binding.mideaac.internal.handler.MideaACHandler$ConnectionManager.connect(MideaACHandler.java:517) ~[?:?]
	at org.openhab.binding.mideaac.internal.handler.MideaACHandler.initialize(MideaACHandler.java:365) ~[?:?]
2021-02-21 17:03:37.724 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing 'mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b': null
2021-02-21 17:03:37.724 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b' changed from ONLINE to UNINITIALIZED (HANDLER_INITIALIZING_ERROR)
First of all, @JacekDob (and who else might have helped) thank you so much for this binding.
I was about to try some scripts I’ve found for some basic iteration, when I realized you released this binding 2 days before.
Since I’m not a skilled developer, not going to promise I can help with development, but I’m happy to help with any required Q&A.
Let me start with my experience.
Initially I had some issues finding my AC machines. I had to set up on manually. It worked.
After that, I forced another scan and all devices have shown up. Since then everything seems to be working nicely.
FYI, I’m using 5x duct machines, model MTIU-12FNXD0. External splitter model M5O-42FN8-Q.
Then for connectivity I use the LCAC KIT WI-FI.
Best,
@smvsousa if you can share some logs in trace mode, I can improve scanning mechanizm.
@Osmii please check latest version.
Hello Jacek and thank you for your time!
I reinstalled the binding. It starts ok and updating status.
2021-03-07 16:36:35.311 [TRACE] [ler.MideaACHandler$ConnectionManager] - Performing connection check for mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b at IP 192.168.1.130
2021-03-07 16:36:35.313 [TRACE] [ler.MideaACHandler$ConnectionManager] - Checking status of connection for mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b at 192.168.1.130
2021-03-07 16:36:35.319 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Connection check OK for mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b at 192.168.1.130
2021-03-07 16:36:35.321 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Requesting status update from mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b at 192.168.1.130
2021-03-07 16:36:35.325 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Writing to mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b at 192.168.1.130 bytes.length: 104, bytes: 5A5A011168002000000000000115020710242300DA370000000B00000000000000000000000000006B000A76E27EED2C3647E57D8602DF8B0F7FAFA7EC1FCCCEEAC76BBDD53E49D9D4280338B1AC9710C10EB8C5A0DBF3A4BA1814C2FEB281386E00D96227E200A8
2021-03-07 16:36:35.686 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Response received length: 104
2021-03-07 16:36:35.688 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Response bytes: 5A5A011168002080000000000000000000000000DA370000000B00000000000000000000010000000044708595C876105223FAC62D99FAF1EA260959B1BA7FA96C608C44489A3BD75DBCE2B330E31FA9E2CE62D076D307F5FEDF52CD33F0E25629C1DC8235C172ED
2021-03-07 16:36:35.691 [TRACE] [ng.mideaac.internal.handler.Response] - Bytes decoded and stripped without header: C00129657F7F003300000064440D00290000001E000000234D
2021-03-07 16:36:35.692 [TRACE] [ng.mideaac.internal.handler.Response] - PowerState: true
2021-03-07 16:36:35.694 [TRACE] [ng.mideaac.internal.handler.Response] - ImodeResume: false
2021-03-07 16:36:35.696 [TRACE] [ng.mideaac.internal.handler.Response] - TimerMode: false
2021-03-07 16:36:35.698 [TRACE] [ng.mideaac.internal.handler.Response] - ApplianceError: false
2021-03-07 16:36:35.699 [TRACE] [ng.mideaac.internal.handler.Response] - TargetTemperature: 25.0
2021-03-07 16:36:35.702 [TRACE] [ng.mideaac.internal.handler.Response] - OperationalMode: AUTO
2021-03-07 16:36:35.703 [TRACE] [ng.mideaac.internal.handler.Response] - FanSpeed: UNKNOWN
2021-03-07 16:36:35.705 [TRACE] [ng.mideaac.internal.handler.Response] - OnTimer: enabled: false
2021-03-07 16:36:35.707 [TRACE] [ng.mideaac.internal.handler.Response] - OffTimer: enabled: false
2021-03-07 16:36:35.709 [TRACE] [ng.mideaac.internal.handler.Response] - SwingMode: HORIZONTAL
2021-03-07 16:36:35.711 [TRACE] [ng.mideaac.internal.handler.Response] - CozySleep: 0
2021-03-07 16:36:35.713 [TRACE] [ng.mideaac.internal.handler.Response] - Save: false
2021-03-07 16:36:35.715 [TRACE] [ng.mideaac.internal.handler.Response] - LowFrequencyFan: false
2021-03-07 16:36:35.717 [TRACE] [ng.mideaac.internal.handler.Response] - SuperFan: false
2021-03-07 16:36:35.718 [TRACE] [ng.mideaac.internal.handler.Response] - FeelOwn: false
2021-03-07 16:36:35.720 [TRACE] [ng.mideaac.internal.handler.Response] - ChildSleepMode: false
2021-03-07 16:36:35.722 [TRACE] [ng.mideaac.internal.handler.Response] - ExchangeAir: false
2021-03-07 16:36:35.724 [TRACE] [ng.mideaac.internal.handler.Response] - DryClean: false
2021-03-07 16:36:35.725 [TRACE] [ng.mideaac.internal.handler.Response] - AuxHeat: false
2021-03-07 16:36:35.727 [TRACE] [ng.mideaac.internal.handler.Response] - EcoMode: false
2021-03-07 16:36:35.729 [TRACE] [ng.mideaac.internal.handler.Response] - CleanUp: false
2021-03-07 16:36:35.730 [TRACE] [ng.mideaac.internal.handler.Response] - TempUnit: false
2021-03-07 16:36:35.732 [TRACE] [ng.mideaac.internal.handler.Response] - SleepFunction: false
2021-03-07 16:36:35.734 [TRACE] [ng.mideaac.internal.handler.Response] - TurboMode: false
2021-03-07 16:36:35.736 [TRACE] [ng.mideaac.internal.handler.Response] - CatchCold: false
2021-03-07 16:36:35.737 [TRACE] [ng.mideaac.internal.handler.Response] - NightLight: false
2021-03-07 16:36:35.739 [TRACE] [ng.mideaac.internal.handler.Response] - PeakElec: false
2021-03-07 16:36:35.741 [TRACE] [ng.mideaac.internal.handler.Response] - NaturalFan: false
2021-03-07 16:36:35.743 [TRACE] [ng.mideaac.internal.handler.Response] - IndoorTemperature: 25.9
2021-03-07 16:36:35.745 [TRACE] [ng.mideaac.internal.handler.Response] - OutdoorTemperature: 9.0
2021-03-07 16:36:35.747 [TRACE] [ng.mideaac.internal.handler.Response] - Humidity: 13
But then, after few minutes warning shows and stops reporting.
2021-03-07 16:36:45.752 [TRACE] [ler.MideaACHandler$ConnectionManager] - Performing connection check for mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b at IP 192.168.1.130
2021-03-07 16:36:45.755 [TRACE] [ler.MideaACHandler$ConnectionManager] - Checking status of connection for mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b at 192.168.1.130
2021-03-07 16:36:45.757 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Connection check OK for mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b at 192.168.1.130
2021-03-07 16:36:45.759 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Requesting status update from mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b at 192.168.1.130
2021-03-07 16:36:45.762 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Writing to mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b at 192.168.1.130 bytes.length: 104, bytes: 5A5A011168002000000000000115020710242D00DA370000000B00000000000000000000000000006B000A76E27EED2C3647E57D8602DF8B0D913A99AC66BBC2C031875985FEA665A6BD5E96EA81A1E4D966D532E6557AEE06B0AF055C9D1214C27F82B5E7C202BF
2021-03-07 16:36:45.765 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Response received length: 176
2021-03-07 16:36:45.767 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Response bytes: 5A5A011158004400DE4901000000000000000000DA370000000B000000000000000000000300000033EA990CBC3A488F0BC352DD7544A352D841DE54A76FF90C8AEEF193574829990C0D4BC13B22C0D48E8FF1807D7312735A5A011158004400E04901000000000000000000DA370000000B000000000000000000000300000033EA990CBC3A488F0BC352DD7544A352D841DE54A76FF90C8AEEF193574829996AABDDC31AEC2777B319A86300ECAD00
2021-03-07 16:36:45.772 [WARN ] [g.mideaac.internal.security.Security] - AES decryption error: IllegalBlockSizeException: Input length must be multiple of 16 when decrypting with padded cipher
	at org.openhab.binding.mideaac.internal.handler.Response.<init>(Response.java:26) ~[?:?]
	at org.openhab.binding.mideaac.internal.handler.MideaACHandler$ConnectionManager.sendCommand(MideaACHandler.java:567) ~[?:?]
	at org.openhab.binding.mideaac.internal.handler.MideaACHandler$ConnectionManager.requestStatus(MideaACHandler.java:530) ~[?:?]
	at org.openhab.binding.mideaac.internal.handler.MideaACHandler$ConnectionManager.checkConnection(MideaACHandler.java:716) ~[?:?]
	at org.openhab.binding.mideaac.internal.handler.MideaACHandler$ConnectionManager.lambda$0(MideaACHandler.java:476) ~[?:?]
And if I change an item or command AC with remote , then binding also stops working, until restart…
2021-03-07 16:42:15.418 [TRACE] [ler.MideaACHandler$ConnectionManager] - Performing connection check for mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b at IP 192.168.1.130
2021-03-07 16:42:15.421 [TRACE] [ler.MideaACHandler$ConnectionManager] - Checking status of connection for mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b at 192.168.1.130
2021-03-07 16:42:15.423 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Connection check OK for mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b at 192.168.1.130
2021-03-07 16:42:15.426 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Requesting status update from mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b at 192.168.1.130
2021-03-07 16:42:15.430 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Writing to mideaac:ac:mideaac__192_168_1_130__12094627919834__net_ac_5c3b at 192.168.1.130 bytes.length: 104, bytes: 5A5A0111680020000000000001150207102A0F00DA370000000B00000000000000000000000000006B000A76E27EED2C3647E57D8602DF8BD8843C397DEAD052D9DAE3B48BF3B3B56CA53BB8C5A00C97CBBFA3FE254FFE833BCDD218D1653C31D695A0802ED8BD39
2021-03-07 16:42:15.433 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Response received length: 104
2021-03-07 16:42:15.435 [DEBUG] [ler.MideaACHandler$ConnectionManager] - Response bytes: 5A5A0111680044001A4A01000000000000000000DA370000000B0000000000000000000003000000C011F4DA888AB00E6E1D77ECBCBFAA022075387CC7B1151A7718B440E8B27B9A6E2A1E3EE1B0F21AAC9ACA31D68C46EE5ADF440028B1A0C03BA7B448174FA803
2021-03-07 16:42:15.438 [TRACE] [ng.mideaac.internal.handler.Response] - Bytes decoded and stripped without header: A05B20657F7F003300000000001E00000000000004B3
2021-03-07 16:42:15.439 [TRACE] [ng.mideaac.internal.handler.Response] - PowerState: true
2021-03-07 16:42:15.441 [TRACE] [ng.mideaac.internal.handler.Response] - ImodeResume: false
2021-03-07 16:42:15.443 [TRACE] [ng.mideaac.internal.handler.Response] - TimerMode: true
2021-03-07 16:42:15.445 [TRACE] [ng.mideaac.internal.handler.Response] - ApplianceError: false
2021-03-07 16:42:15.447 [TRACE] [ng.mideaac.internal.handler.Response] - TargetTemperature: 16.0
2021-03-07 16:42:15.448 [TRACE] [ng.mideaac.internal.handler.Response] - OperationalMode: AUTO
2021-03-07 16:42:15.450 [TRACE] [ng.mideaac.internal.handler.Response] - FanSpeed: UNKNOWN
2021-03-07 16:42:15.452 [TRACE] [ng.mideaac.internal.handler.Response] - OnTimer: enabled: false
2021-03-07 16:42:15.454 [TRACE] [ng.mideaac.internal.handler.Response] - OffTimer: enabled: false
2021-03-07 16:42:15.470 [TRACE] [ng.mideaac.internal.handler.Response] - SwingMode: HORIZONTAL
2021-03-07 16:42:15.474 [TRACE] [ng.mideaac.internal.handler.Response] - CozySleep: 0
2021-03-07 16:42:15.477 [TRACE] [ng.mideaac.internal.handler.Response] - Save: false
2021-03-07 16:42:15.481 [TRACE] [ng.mideaac.internal.handler.Response] - LowFrequencyFan: false
2021-03-07 16:42:15.483 [TRACE] [ng.mideaac.internal.handler.Response] - SuperFan: false
2021-03-07 16:42:15.485 [TRACE] [ng.mideaac.internal.handler.Response] - FeelOwn: false
2021-03-07 16:42:15.487 [TRACE] [ng.mideaac.internal.handler.Response] - ChildSleepMode: false
2021-03-07 16:42:15.489 [TRACE] [ng.mideaac.internal.handler.Response] - ExchangeAir: false
2021-03-07 16:42:15.491 [TRACE] [ng.mideaac.internal.handler.Response] - DryClean: false
2021-03-07 16:42:15.493 [TRACE] [ng.mideaac.internal.handler.Response] - AuxHeat: false
2021-03-07 16:42:15.495 [TRACE] [ng.mideaac.internal.handler.Response] - EcoMode: false
2021-03-07 16:42:15.496 [TRACE] [ng.mideaac.internal.handler.Response] - CleanUp: false
2021-03-07 16:42:15.498 [TRACE] [ng.mideaac.internal.handler.Response] - TempUnit: false
2021-03-07 16:42:15.500 [TRACE] [ng.mideaac.internal.handler.Response] - SleepFunction: false
2021-03-07 16:42:15.502 [TRACE] [ng.mideaac.internal.handler.Response] - TurboMode: false
2021-03-07 16:42:15.503 [TRACE] [ng.mideaac.internal.handler.Response] - CatchCold: false
2021-03-07 16:42:15.505 [TRACE] [ng.mideaac.internal.handler.Response] - NightLight: false
2021-03-07 16:42:15.507 [TRACE] [ng.mideaac.internal.handler.Response] - PeakElec: false
2021-03-07 16:42:15.509 [TRACE] [ng.mideaac.internal.handler.Response] - NaturalFan: false
2021-03-07 16:42:15.510 [TRACE] [ng.mideaac.internal.handler.Response] - IndoorTemperature: null
2021-03-07 16:42:15.512 [TRACE] [ng.mideaac.internal.handler.Response] - OutdoorTemperature: -25.0
2021-03-07 16:42:15.514 [TRACE] [ng.mideaac.internal.handler.Response] - Humidity: 30
	at org.openhab.binding.mideaac.internal.handler.MideaACHandler$ConnectionManager.processMessage(MideaACHandler.java:653) ~[?:?]
	at org.openhab.binding.mideaac.internal.handler.MideaACHandler$ConnectionManager.sendCommand(MideaACHandler.java:568) ~[?:?]
@Osmii,
Can you provide which version of device you have (“version” in Thing properties).
It is version 2!
@Osmii,
does any of return values corresponds to device state?
FanSpeed: UNKNOWN
Response length from device seems to be correct, but data seems to be wrong (either decryption problem or different format).
Jacek
Maybe swing mode, other values not.
I have Version 3 of Midea.
I can only discovery my devices, when I add them, these devices show online/offline every few seconds. They don’t show any values, all are Null.
What is the problem?
It seems that my binding is not working properly with device Version 3, see my comment Feb 12.
Just did some updates on my server, and seems that this binding is failing since?
bundle:restart 350
Error executing command: Error restarting bundles:
Unable to start bundle 350: Could not resolve module: org.openhab.binding.mideaac [350]
Unresolved requirement: Import-Package: org.apache.commons.lang; version=“[2.6.0,3.0.0)”
Hope a solution can be found, summer is coming. :wink:
