Hi Dominik (@dominikkv),
thanks a lot for your words and analysing the cpu load on your system. However I am not a linux expert so you have to help me to interpret these values. Between August 7th and August 9th the usage was around 0.5. After updating the binding the usage is around 0.75. So my assumption that the cpu usage is somehow higher is correct. However is this more usage really significant? What does 0.75 usage mean? On my Pi 3 I can still use openhab, shell etc without any problems.
So I integrated 4 NodOn STPH-2-1-05 temperature- & humidity sensors. This works. [β¦] The switch in openHAB reflects the state of the βrealβ switch and changes its state when I press the physical button.
I love good news
But the measurements for current power and total usage do not show up
From your images I can see that you use the βsimple item linking modeβ (configuration => system => Item linking). I currently do not know why but in this case openhab ignores some metainfo I set on the totalusage and instantpower channel. These channels combine a number with a unit which cannot be cannot be interpreted as a simple number. So could you do me favor and deactivate the simple mode and link these channels to new items again. This time you choose βNumberβ as item type and βEnergyβ as dimension for totalusage and βPowerβ as dimension for instantpower.
Also, the other way does not work: if I change the state in OpenHAB, the physical switch does not switch.
There seems to be a bigger problem with this EEP. @sepp99 has the same problems with his PCS234 (uses the same EEP). Teach in seems to be ok (green light flashes) but switching from openhab does not work. I currenty do not know why this does not work, I have to analyse it further. However I can tell you that the PCS234 works flawlessly here at my home, I am using it to monitor my washing machine.
I saw from your other posts that you used or tried to use the Homegear/HomeMatic binding solution in the past. Could you switch your PSC132 with this solution? Did you do a factory reset of your PSC132 to reset former teached in devices?
Best regards
Daniel
