Not really working
When I switch the light with my physical switch, the value of brightness, or even the z switch on/off wonât recognize the lamp status
Was someone successfull with pairing dimm actuators or roller shutters from Eltako? I am using the âTipp-Funkâ devices tf61d and TF61J.
Did you set your dimmer to an âEltako dimmerâ on the Dimmer channel properties?
Whats the BA of your FAM14?
I am using both, dimm and rollershutters actuators with this binding in HomeKit. But I use the series 14 devices from Eltako. (This shouldnât make any difference)
Noy not really. Or I donât know how to? Let me have a look.
Do you see anything in the log (set the addon-log-level to debug) if you switch the FUD ?
I use (textual) the âautoupdate=falseâ setting in the item-definition because I only want to have the ack-messages from my FUD61 to move the slider/dimmer-value in OH. Perhaps this is your issue ?
Have to correct myself. Yes I did.
I will check that. Do you have an example for me?
Thing centralCommand 0504E550 "Deckenlampe Wohnzimmer" @ "Wohnzimmer" [ enoceanId="0504E550", senderIdOffset=5, sendingEEPId="A5_38_08_02",receivingEEPId="A5_38_08_02" ] {
Channels:
Type teachInCMD : teachInCMD [ teachInMSG="E0400D80" ]
Type dimmer : dimmer [ rampingTime=0 ]
And item (also for Alexa as she doesnât like the âautoupdate=falseâ:
Dimmer eg_wz_l_deckenlampe "Wohnzimmer" <light> (gLicht,gEG,gWohnzimmer,gLichterWohnzimmer)
{channel="enocean:centralCommand:gtwy:0504E550:dimmer", autoupdate = "false"}
Dimmer eg_wz_l_deckenlampe_alexa "Wohnzimmer"
{alexa="PowerController.powerState,BrightnessController.brightness" [category="LIGHT"],
channel="enocean:centralCommand:gtwy:0504E550:dimmer"}
Let me try this
Well⊠The autoupdate idea is not working. It only seems that my dimmer in the sitemap is always switching to offâŠ
Any further ideas?
I donât have a fam14 yet. I am only testing the enocean stuff on OH.
That would only indicate that OH doesnât receive the status messages properly
Youâd need to check if the status telegrams are really sent, properly received and mapped to the correct OH item âŠ
I will check that tomorrow
Too late for today. Are u available tomorrow maybe?
Best wishes, thank you very much and have a nice evening
Okay. I already set the log-level to DEBUG, as you can see here:
I will upload the log infos today evening.
Best wishes.
guys I just downloaded the openhabian image and putted in on the sd card and put this into the pi and started it. I think I have an connection problem with my ethernet. I donât see an IP. It says âUnable to parse ip. Please debug.â I do not plan to use the pi with wifi. Could someone assist please?
Please read here :
it is saying âNetwork is unreachableâ
and giving some lines ->
W: Failed to fetch âŠ
Youâd better open a new thread, as this is not related to the EnOcean binding.
