Hey @ZzetT,
for whatever reason I’m getting the following error when trying to execute a rule:
An error occurred during the script execution: index=2, size=2
This is my script:
val telegramAction = getActions("telegram","telegram:telegramBot:102b929e")
telegramAction.sendTelegram("Test")
If I remove the sendTelegram line, the error goes away. The bot seems to be configured correctly. Do I have to uninstall the old Telegram Action or what am I doing wrong here?
UPDATE:
If I’m trying to send a message with response options, I get the following exception:
telegramAction.sendTelegram("It is evening, and the garage door is still open. Do you want me to close it?", "Reply_Garage", "Yes", "No")
2019-07-13 19:24:42.777 [WARN ] [binding.telegram.bot.TelegramActions] - Failed to send telegram:
org.telegram.telegrambots.meta.exceptions.TelegramApiRequestException: Error sending message
at org.telegram.telegrambots.meta.api.methods.send.SendMessage.deserializeResponse(SendMessage.java:169) ~[?:?]
at org.telegram.telegrambots.meta.api.methods.send.SendMessage.deserializeResponse(SendMessage.java:23) ~[?:?]
at org.telegram.telegrambots.bots.DefaultAbsSender.sendApiMethod(DefaultAbsSender.java:748) ~[?:?]
at org.telegram.telegrambots.meta.bots.AbsSender.execute(AbsSender.java:47) ~[?:?]
at org.openhab.binding.telegram.bot.TelegramActions.sendTelegram(TelegramActions.java:156) ~[?:?]
at org.openhab.binding.telegram.bot.TelegramActions.sendTelegram(TelegramActions.java:250) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1086) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1061) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1047) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:992) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:772) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:220) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:204) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:447) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:228) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:190) ~[?:?]
at org.eclipse.smarthome.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:82) ~[?:?]
at org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl.lambda$2(RuleEngineImpl.java:341) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
Yes because I think it was copied from the original Telegram Action README page.
However the version posted here is really old and has some problems (at least on my side, but confirmed by @ZzetT), hope he can provide a new version soon, as the migration to the new build server is almost complete.
I’m complete new with openHAB but already have a full system of Fibaro working.
openHAB installed to play with because i’m looking for other systems.
First test for me is Solaredge and sending day data to telegram.
Got solaredge in my system and 2 things linked that give a value in control. (day consumption)
Now I want to send this value to telegram on specific time
telegram default message on specific time got it working.
I thought something like this but that isn’t give the value of solaredge.
rule "Send telegram with Fixed Message"
Time cron "0 43 09 ? * *"
sendTelegram("bot1", "things solaredge:generic:bc922031:aggregate_day#consumption")
got it workoing now and get the picture of system better.
Time cron "0 45 21 ? * *"
sendTelegram("bot1", "SolarEdge dagverbruik is %.4s", SolarEdge_Aggregate_day_Consumption.state.toString)
Hey @ZzetT,
Since a couple of weeks, from time to time, a Telegram binding fail to send message.
Let’s say: 1 of 5 message fails.
Similar error than Florian.
It seems random failure, not the same message and not always the same rule…
Have you a similar issue?
Any binding update to fix it?
11:37:20.877 [WARN ] [.binding.telegram.bot.TelegramActions] - Failed to send telegram photo:
org.telegram.telegrambots.meta.exceptions.TelegramApiRequestException: Error sending photo
at org.telegram.telegrambots.meta.api.methods.send.SendPhoto.deserializeResponse(SendPhoto.java:146) ~[?:?]
at org.telegram.telegrambots.bots.DefaultAbsSender.execute(DefaultAbsSender.java:205) ~[?:?]
at org.openhab.binding.telegram.bot.TelegramActions.sendTelegramPhoto(TelegramActions.java:195) ~[?:?]
at org.openhab.binding.telegram.bot.TelegramActions.sendTelegramPhoto(TelegramActions.java:259) ~[?:?]
Hi, I had similar problem and as workaround I first download a jpg file with a curl command and later send the file with Telegram as per example below:
org.telegram.telegrambots.meta.exceptions.TelegramApiException: Unable to send photo
at org.telegram.telegrambots.bots.DefaultAbsSender.execute(DefaultAbsSender.java:207) ~[?:?]
at org.openhab.binding.telegram.bot.TelegramActions.sendTelegramPhoto(TelegramActions.java:207) ~[?:?]
at sun.reflect.GeneratedMethodAccessor103.invoke(Unknown Source) ~[?:?]
at org.telegram.telegrambots.bots.DefaultAbsSender.sendHttpPostRequest(DefaultAbsSender.java:806) ~[?:?]
... 28 more
