Issue How do I fix my wish (Gardena Binding + Alexa file based)
I’ve trying to get into the Openhab world, its uphill but i’m giving it a go. System is up and running, i have made my sitemap demo, and installed the Gardena binding, if i use auto all comes up - and i can control the Irritation syatem via the web interface. But Alexa can’t start it - as I cant set the [Switchable] tag in auto mode? So i’m trying to set it all up via config files - and this is the nightmare for me, but it is loaded and loged in - so the help i need is how to config the items file, things file and sitemap to also use it via the mobile (mobile is hooked up via the cloud and connected)
I think its very hard to read the Gardena Binding site, on how to config the ic24 “smart Irrigation Control” and end up with option to turn on Zone 1 and than in the end could do a Amazon Ecro statment “Alexa - start Zone1”. Link to the Add-on is here: Gardena - Bindings | openHAB
In my things file i have this:
Bridge gardena:account:home [ email="XX@XX.com", password="SECRET", refresh=30 ]
Thing ic24 myirrigation [ deviceId="Here is used the ID found on the config webpage for the ic24 device" ]
I can see it online, in the interface under automode/auto setup - here I can start and stop the irritation and set time, but i need it to be configered manualy in the config files to make it work with Alexa.
Can anyone help me out on what i need in the other config files… i can’t figure it out - and i’m so close.
I’m not a developer or used to coding, but have worked a little with linux, and everything else is working. Just need some help in understading how to do this.
Number Gardena_Timer "Timer [%d]" { channel="gardena:ic24:home:myirigation:watering#watering_timer_1" }
And you can send a command in a rule to that item like so:
rule "Gardena"
//sometrigger
Gardena_Timer.sendCommand(20)
Now, Alexa doesn’t really support sending commands to number items but it can do Dimmer items
You need to set a tag of [Lighting] in the item and say:
“Set Gardena Timer to 20”
