This all looks the same - nearly the last thing in the log shows that the port opened ok. I think we need more log information to see what is happening.
H102:
/dev/ttyUSB0
chris:
I think I set the logs as you suggested; and this is output:
020-01-02 09:47:20.078 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:21.683 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:23.286 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:24.891 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:26.495 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:28.099 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:29.704 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:31.308 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:32.912 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:34.517 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:36.121 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:37.725 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:39.330 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:40.933 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:42.537 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:44.140 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:45.745 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:47.348 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:48.952 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:50.555 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:52.166 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:53.769 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:55.372 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:56.975 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:47:58.579 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:00.182 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:01.786 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:03.390 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:04.993 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:06.597 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:08.199 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:09.802 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:11.411 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:13.014 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:14.617 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:16.221 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:17.824 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:19.427 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:21.030 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:22.633 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:24.236 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:25.840 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:27.443 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:29.046 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:30.650 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:32.253 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:33.856 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:35.459 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:37.063 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 09:48:38.666 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
Try setting up a UDEV rule on your Pi and see if that helps. Something like in this post Linear HUSBZB-1
Thanks, a UDEV rule is another new thing for me to research/learn so it may take a while till I post a report.
Yep - looks “better”…
What this tells me is that the port is opening, but the dongle is not communicating. The binding is sending the reset command repeatedly.
Are you sure you have the right port? The HUSBZB should provide both ZWave and ZigBee, so there should be two ports showing up in your system. I’m not sure which way around the ports arbitrate, but I seem to recall someone saying they always appear is a specific order (@Bruce_Osborne you might know the answer to this?). I’m just wondering if you’re connected to the ZWave side of the dongle?
I have that dongle on my test system but I do not have any Zigbee devices.
I can set up the Zigbee coordinator on it this evening to check, if that would help.
I think Zigbee is the second, if I remember correctly.
the HUSBZB presents itself as 2 serial interfaces in the OS. (1 for Z-Wave & 1 for Zigbee)
H102
I added the two lines of code you pointed me to in a file /etc/udev/rules.d/999-HUSBZB.rules.
Interesting thing now in addition to the ttyUSB0 and ttyUSB1 port options that I had in the PaperUI setup for the stick I also have a new ttyUSB-5. I have tried all three with same results.
Do you have anything else plugged into the USB ports? My stick shows up as ttyUSB0 and ttyUSB1 but I have no other devices attached.
No, nothing else. I did have just ttyUSB0 and ttyUSB1 before I did the UDEV rule H102 and chris suggested (if I did that correctly)
I will try and look further this evening. I am in the eastern US.
@Dave55 Try using the USB-5 and see what happens you may be able to try USB-55 as well.
Here is an old article but you may find it useful https://github.com/openhab/openhab1-addons/wiki/symlinks
@H102 Too impatient or just do not need my testing?
Like I stated I have that stick currently connected to a Raspberry Pi 3B+.
Getting ready to leave for home now.
Yes, and I got to work around 7 AM this morning.
The correct port should be /dev/ttyUSB1
and EXTRA_JAVA_OPTS
needs to be set but the example above in this thread is incorrect. Without the correct options, the binding cannot find the serial port.
Give me a couple of minutes to update this posting. I had this working well a while ago.
Looks like I get same result with all ports:
15.683 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:17.286 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:18.888 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:20.490 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:22.093 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:23.696 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:25.298 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:26.901 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:28.504 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:30.107 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:31.710 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:33.313 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:33.358 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration received (Coordinator).
2020-01-02 17:09:33.361 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Processing zigbee_port -> /dev/ttyUSB-55
2020-01-02 17:09:33.364 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_initialise as no change
2020-01-02 17:09:33.366 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_channel as no change
2020-01-02 17:09:33.369 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_concentrator as no change
2020-01-02 17:09:33.371 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_trustcentremode as no change
2020-01-02 17:09:33.374 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_extendedpanid as no change
2020-01-02 17:09:33.377 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_flowcontrol as no change
2020-01-02 17:09:33.379 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_baud as no change
2020-01-02 17:09:33.381 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_panid as no change
2020-01-02 17:09:33.384 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_powermode as no change
2020-01-02 17:09:33.388 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_txpower as no change
2020-01-02 17:09:33.390 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_installcode as no change
2020-01-02 17:09:33.392 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_networksize as no change
2020-01-02 17:09:33.396 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_linkkey as no change
2020-01-02 17:09:33.400 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_childtimeout as no change
2020-01-02 17:09:33.402 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_networkkey as no change
2020-01-02 17:09:33.404 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_meshupdateperiod as no change
2020-01-02 17:09:34.917 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:36.519 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:38.122 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:39.725 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:41.328 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:42.931 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:44.534 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:46.137 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:47.740 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:49.343 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:50.945 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:52.548 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:54.151 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:55.754 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:57.357 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:09:58.960 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:00.563 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:02.166 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:03.769 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:05.372 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:06.975 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:08.578 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:10.180 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:11.783 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:13.386 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:14.989 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:16.592 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:18.195 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:19.797 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:21.400 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:23.003 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:24.606 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:26.209 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:27.812 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:29.415 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:31.018 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:32.621 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:34.224 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:35.826 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:37.429 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:37.473 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration received (Coordinator).
2020-01-02 17:10:37.477 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Processing zigbee_port -> /dev/ttyUSB-5
2020-01-02 17:10:37.481 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_initialise as no change
2020-01-02 17:10:37.485 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_channel as no change
2020-01-02 17:10:37.489 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_concentrator as no change
2020-01-02 17:10:37.494 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_trustcentremode as no change
2020-01-02 17:10:37.498 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_extendedpanid as no change
2020-01-02 17:10:37.502 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_flowcontrol as no change
2020-01-02 17:10:37.506 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_baud as no change
2020-01-02 17:10:37.510 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_panid as no change
2020-01-02 17:10:37.514 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_powermode as no change
2020-01-02 17:10:37.516 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_txpower as no change
2020-01-02 17:10:37.518 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_installcode as no change
2020-01-02 17:10:37.520 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_networksize as no change
2020-01-02 17:10:37.523 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_linkkey as no change
2020-01-02 17:10:37.525 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_childtimeout as no change
2020-01-02 17:10:37.527 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_networkkey as no change
2020-01-02 17:10:37.530 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_meshupdateperiod as no change
2020-01-02 17:10:39.035 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:40.640 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:42.245 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:43.850 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:45.456 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:47.061 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:48.666 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:50.271 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:51.876 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:53.481 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:55.087 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:56.692 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:58.297 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:10:59.902 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:01.507 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:03.112 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:04.717 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:04.952 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration received (Coordinator).
2020-01-02 17:11:04.958 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Processing zigbee_port -> /dev/ttyUSB0
2020-01-02 17:11:04.960 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_initialise as no change
2020-01-02 17:11:04.962 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_channel as no change
2020-01-02 17:11:04.964 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_concentrator as no change
2020-01-02 17:11:04.967 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_trustcentremode as no change
2020-01-02 17:11:04.969 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_extendedpanid as no change
2020-01-02 17:11:04.972 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_flowcontrol as no change
2020-01-02 17:11:04.974 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_baud as no change
2020-01-02 17:11:04.976 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_panid as no change
2020-01-02 17:11:04.979 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_powermode as no change
2020-01-02 17:11:04.981 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_txpower as no change
2020-01-02 17:11:04.984 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_installcode as no change
2020-01-02 17:11:04.986 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_networksize as no change
2020-01-02 17:11:04.988 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_linkkey as no change
2020-01-02 17:11:04.990 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_childtimeout as no change
2020-01-02 17:11:04.992 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_networkkey as no change
2020-01-02 17:11:04.995 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_meshupdateperiod as no change
2020-01-02 17:11:06.320 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:07.923 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:09.527 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:11.130 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:12.733 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:14.336 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:15.939 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:17.543 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:19.146 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:20.749 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:22.353 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:23.956 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:25.559 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:27.161 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:28.764 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:30.367 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:31.971 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:33.574 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:34.344 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration received (Coordinator).
2020-01-02 17:11:34.348 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Processing zigbee_port -> /dev/ttyUSB1
2020-01-02 17:11:34.352 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_initialise as no change
2020-01-02 17:11:34.356 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_channel as no change
2020-01-02 17:11:34.361 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_concentrator as no change
2020-01-02 17:11:34.364 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_trustcentremode as no change
2020-01-02 17:11:34.369 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_extendedpanid as no change
2020-01-02 17:11:34.373 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_flowcontrol as no change
2020-01-02 17:11:34.377 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_baud as no change
2020-01-02 17:11:34.381 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_panid as no change
2020-01-02 17:11:34.385 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_powermode as no change
2020-01-02 17:11:34.390 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_txpower as no change
2020-01-02 17:11:34.394 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_installcode as no change
2020-01-02 17:11:34.398 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_networksize as no change
2020-01-02 17:11:34.402 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_linkkey as no change
2020-01-02 17:11:34.407 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_childtimeout as no change
2020-01-02 17:11:34.410 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_networkkey as no change
2020-01-02 17:11:34.415 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_meshupdateperiod as no change
2020-01-02 17:11:35.178 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:36.781 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:38.384 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:39.988 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:41.591 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:43.194 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2020-01-02 17:11:44.797 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
