Morning all,
I’ve moved over to Openhab2 on my Pi and I’m struggling to find the openhab_default.cfg file.
I’ve combed through the forums and seen a variety of different proposed locations, and I’ve done a recursive search through the following to no avail :
/etc/openhab2/
/var/lib/openhab2
/var/log/openhab2
/usr/share/openhab2
The directory /var/lib/openhab2 has a folder called ‘config’ but its not there. I followed the installation steps for the offline distribution, but I’ve done nothing else other than add a few items to the Paper UI to check everything was working with my Yamaha receiver. Do I just need to download a default config file from somewhere and get cracking? Should it just go in the above config folder?
I tried looking at some of the other docs but they seem to be work in progress - I might contribute some words if i get remote access working!
Thanks,
Rich.
