Raspberry pi4
Openhabian
In Openhabian what do I need to do to get samba up and running
Using a window 7 to remote access
So do.i just need to alter the workgroup to what I have set on Windows machine?
Then add the raspberry pi to this work group?
You can easily enable the network shares in openhabian-config and that’s it.
So ssh into your RPI and type
sudo openhabian-config
an navigate through the rest. See also the doc here:
Isn’t openhabian set samba up already ,so will I just have to alter confi file to change work group?
No need to change anything by default
Due to on Windows machine and my network ,workgroup is Home
So what? If you type
\\your_openhabian_ip
in your windows explorer you will get asked to username and password. and if you want to change that you can either
- store the credentials my adding the smb share as a network drive or
- use openhabian-config to change username/password
Getting this just did a new install of openhabian not changed anything
can you ping this IP?
end check if samba is running:
sudo systemctl status smbd
sparky70
(tony)
10
Yes I have openhabian webpage and can SSH it
Me neither. How am I supposed to read something:
check also this:
You are not using Workgroup credentials though. No need to change. just hit by ip address.
sparky70
(tony)
15
As above ,found easy way to update Windows 7 to windows 10 and see above to install SMB 1.0,now got file shares up.
