Platform information:
- Hardware: Intel Core i5-2320 CPU @ 3.0GHz, 8GB RAM
- OS: Windows 10 Pro
- Java Runtime Environment: Zulu8.27.0.7-jdk8.0.162
- openHAB version: 2.2.0
Issue of the topic: Using a Vision Zwave ZL 7431 as a momentary switch to operate as a set of contact to send a closed signal to a driveway gate control unit. (Same as a garage door opener.) The switch connection works perfectly but when I added the "expire=“2s,command=Off” it does not turn the switch off after the 2 seconds. This was done to effectively make the switch a momentary activating device.
Please post configurations (if applicable):
- Items configuration related to the issue:
Switch Switch_Side_Gate “Side Gate” { expire=“10s,command=Off”,channel=“zwave:device:1ff970ba:node3:switch_binary”,autoupdate=“false” }
I had found where a gentleman had used this exactly to control a gate and two garage doors.
I tried 1s, 2s and 10s entries. I am wondering it that expire statement was effective in a previous OpenHAB version and that I may now need to use a rule to accomplish the desire momentary switch function.
Any hints or recommendation would be greatly appreciated.
