Hi all, im
a new user of openhab whit a problem
I purchased
the Nexa LMST-606 and got it working as a swith, but when I change it to a contact I cant sem to get it to work.
as switch whit roule changed to " Item yDoorBasement changed from OFF to ON it works, but then i have a on off switch in my sitemap and the icon “door” is not working, pleas help.
Here are my
item file :
// Dør sensorer
Contact yDoorBasement "Yttre kjeller dør " <door> (gDoor, gBasement,gSecurity)
{tellstick="yDoorBasement:Command"}
And my roules :
//---- Kjellerdør opne lukke ----------------------
rule "Kjellerdoor open"
Item yDoorBasement changed from CLOSED to OPEN
say("Basement door open")
//notifyMyAndroid("Openhab", "Noen har åpnet Kjeller døra")
rule "Kjellerdoor off"
Item yDoorBasement changed from OPEN to CLOSED
say("Basement door closed")
//notifyMyAndroid("Openhab","Noen har lukket Kjeller døra")
//END---- Kjellerdør opne lukke----------------------
And my
telldus.conf
device {
id = 12
name = "yDoorBasement"
controller = 0
protocol = "arctech"
model = "selflearning-switch:nexa"
parameters {
# devices = ""
house = "17134630"
unit = "10"
code = "0000000000"
system = "1"
# units = ""
fade = "false"
And my errorlog :
2015-11-22 10:09:15.443 [INFO ]
[.b.t.internal.TellstickBinding] - Could not find config for TellstickDevice
[deviceId=12, name=yDoorBasement, status=1, deviceType=1, data=null]
2015-11-22 10:09:16.164 [INFO ]
2015-11-22 10:09:17.058 [INFO ] [.b.t.internal.TellstickBinding]
- Could not find config for TellstickDevice [deviceId=12, name=yDoorBasement,
2015-11-22 10:09:18.133 [INFO ]
2015-11-22 10:09:37.659 [INFO ]
[deviceId=12, name=yDoorBasement, status=2, deviceType=1, data=null]
2015-11-22 10:09:38.144 [INFO ]
2015-11-22 10:09:39.119 [INFO ]
2015-11-22 10:09:40.153 [INFO ]
Regards Eivind
