I have an rfxcom and I’m trying configure a WRM-3500-2 dimmer from nexa but I can only get it to turn on and off. It just won’t dim.
I have found one topic on this but that one refers to a binding that doesn’t seem to exist anymore. I can’t find it at least.
Have anyone got this to work?
If so, could you point me in the right direction?
I’m probably not going to be much help but I do know that those who can will want to see your Item definitions. In particular ensuring that a Dimmer Item is linked to the dimminglevel Channel of the rfxcom Thing that represents the light.
I used the Paper ui to create a Lighting2 AC device and to link it to a a new dimmer item.
It turns off when I dim to 0 but doesn’t do anything else.
I also created a switch that I can use to switch it on and off.
