@David_Graeff
Hi Dave
I started using the rules part of Paper UI yesterday and I have created several rules. Still being new to OH, I found it easy to create rules with just a few clicks of the mouse. Thank you!
John Frankforther
@David_Graeff
Hi Dave
John Frankforther
The development branch is even more ahead.
I’m at a point where I need core bundles to support all the advanced features of this interface.
Unfortunately the entire openHAB core distribution is basically frozen until the migration to the new buildsystem is finished, so I can’t contribute my developed bundles.
That’s why I got involved in that process. And while I migrated the hue emulation service I thought it would be awesome to have Hue scene, rule, schedule support. And that’s what I’m doing at the moment.
So this project is definitely not forgotten, I just can’t distribute it without those missing core bundles.
Cheers,
Davod
That’s great as I just bought some HUE bulbs. Thank you!!
Really starting to get a handle on this.
John Frankforther
Is it included in the docker “2.5.0-snapshot” images ?
The docker images are kept up to date with the daily snapshots.
Could not find it in the snapshot build. ![]()
Should the PaperUI NG be listed as a UserInterface to be installed from within the current PaperUI ?
Would like to try it and play with it ![]()
It is not installable via paperui unfortunately.
Fortunately it also doesn’t need to be for being used. I’ll add a description later today.
Sounds great. Hoping to have some sparetime then to test it!
Old Textual modes with a UI front-end should be the way to go. I you remove the old textual mode then you are removing many OH users. Personally, I spent a few days clicking around to get the new MQTT 2.4 working, however I went back.
Think about Windows and Linux. In Linux you still can use the command and many scripts.
UI driven programming is good for newcomers without coding experience, but not if you have already ~100 items.
I do not want to stop upgrading, however if old textual configuration vanish, I will.
Wrong thread. And I don’t care about your opinion regarding textual config ![]()
ok, I will move from DavidHAB to OpenHAB thread.
is there UI request " page " so we can see requested items/things that are good ideas or not pratcical etc
You mean like a wish list and Todo list? Sure. Just use GitHub.
Dear @David_Graeff, is there any progress on that topic? I was really enjoying the discussions, hoping to see that stuff in one of the next releases.
Could just quickly comment on the future of your initiative?
Thanks a lot ![]()
Yannick is developing the unified UI for openHAB.
My proposal here is a lot more sophisticated. I have identified problems in the backend http interface, proposed new API endpoints, modernized and simplified OH core code. But OH core development is slow as hell. (The core maintainers are busy fighting Java. I can understand that. They do not have time to develop new features or replace grandpa-aged subsystems.)
I’m no longer participating in core development and I’m developing my own smarthome system for my personal uses. My UI has been moved to my repository and is no longer OH compatible.
Cheers, David
These are bad news. I was already looking forward to your new interface.
does this also mean that you will no longer participate in the development of the mqtt binding?
I do reviews for MQTT PRs. If it comes to code I’m currently only contributing small patches, no feature PRs.
@miwok: That does not mean that there is no development in MQTT.
Absolutely. Jan and Jochen (HomeAssistant MQTT) are doing all the important bits and pieces right now. MQTT v2.5 will be a very good release as far as I can tell.
