i have a little Scriptrow, how to fill a Heartbeat item, with using openhab Helper Library.
First, i have some items connect to mqtt, the send no “lastupdate”, only on diffrent times a status.
To fill this status to some item i use this solution.
Every item, with send a status become a group. I use gSendHeartbeat
String EG_Hallway_Smoke_State "Rauchmelder Flur" <fire> (gSmoke, EG_Hallway, gSendHeartbeat){channel="mqtt:topic:bhome:zigbee_Rauchmelder_Flur:smoke"}
Number EG_Hallway_Smoke_Batterie "Rauchmelder Flur Batterie [%.1f %%]" <batterylevel> (gBatterylevel, EG_Hallway, GZigbee, gSendHeartbeat) {channel="mqtt:topic:bhome:zigbee_Rauchmelder_Flur:battery"}
Number EG_Hallway_Smoke_LinkQuality "Rauchmelder Flur Link Quality [%d]" <qualityofservice> (EG_Hallway, gLinkQuality, GZigbee, gSendHeartbeat) {channel="mqtt:topic:bhome:zigbee_Rauchmelder_Flur:linkquality"}
Then we need the Heartbeat Item. In context the name is important, because all items for one thing have the same begin (e.g. EG_Hallway_Smoke_). The group gHeartbeat i use for the Sitemap.
DateTime EG_Hallway_Smoke_Heartbeat "Rauchmelder Flur letzte Meldung [%1$td.%1$tm.%1$ty %1$tH:%1$tM]" <time> (EG_Hallway, gZigbee, gHeartbeat)
OK, then we need the python code:
from core.rules import rule
from core.triggers import when
from core.date import ZonedDateTime, format_date
@rule("Process Heartbeat", description="Setzt eine Heartbeatzeit auf nicht zyklische Zigbeegeräte", tags=["admin"])
@when("Member of gSendHeartbeat received update")
def SendHeartbeat(event):
events.sendCommand((str(event.itemName)[0:event.itemName.rfind("_")])+"_Heartbeat", format(format_date(ZonedDateTime.now())))
I think, very small solution for all the Things.
The same code for State Items, with no LastUpdated (in my Homeautomation Homemation, HUE have a LastUpdate Item). The different is the trigger (change status, not received update) and a differen group.
ITEM:
Contact FF_Bedroom_Door_State "Balkontür Schlafzimmer [MAP(de.map):%s]" <door> (FF_Bedroom, gContact, gUpdated, gSendHeartbeat) ["Türkontakt"] {channel="homematic:HM-Sec-SCo:xxxx:MEQxxxxxxxxx:1#STATE"}
DateTime FF_Bedroom_Door_Heartbeat "Tür Schlafzimmer Letzte Meldung [%1$td.%1$tm.%1$ty %1$tH:%1$tM]" <time> (EG_Bedroom, gHeartbeat)
DateTime FF_Bedroom_Door_LastUpdated "Tür Schlafzimmer Letzte Aktualisierung [%1$td.%1$tm.%1$ty %1$tH:%1$tM]" <time> (EG_Bedroom, gLastUpdated)
Python Code:
@rule("Process Contact Update", description="Aenderung bei Kontaktschaltern", tags=["admin"])
@when("Member of gUpdated changed")
def LastUpdate(event):
events.sendCommand(str(event.itemName)[0:event.itemName.rfind("_")])+"_LastUpdated", format(format_date(ZonedDateTime.now()))
Thats all
