Available in the folder, labelled 3.4.0. Worth a try.
Hi, Gaël.
I’m successfully added my 2 sliding gates to openhab (Both was auto discovered, but when I added first gate second disappear from Inbox, but I added it manually). I’m just tested commands and all working like a charm
Hi, Gaël.
As I said before I have 2 sliding gates. Sometimes IT4wifi from one gate stops responding until I restart power of gate. While device is not responding binding starts high CPU consumption:
Maybe you can fix it? If you need additional information please write to me, I’m try to help.
I did observe the same from time to time on my side and power cycling the IT4Wifi seems the only way to resume as you said.
I’ll see how I can enhance the binding to take that in account
I do not loose the point. Currently testing a way to detect it and also circumvent some connection resets.
Hi how to use “13 “MDBk”, “Open + Block”” in MyNice binding (beta) OH3
@SZA : please uninstall and reinstall the binding from the marketplace. T4 Commands are now available.
