I’m having some odd behaviour with the live power usage from NHC binding.
I’m currently using Openhab 3.1.0.M3 milestone build on a raspberry pi 4 with openhabian.
The issue I’m having is that when I create the item
Number CurrentPower "Current Electricity Usage [%.0f W]" {channel="nikohomecontrol:energyMeter:443b00ee3af6:6dcef020-2911-424d-b1f5-40f252aec28a:power"}
Item CurrentPower always remains as UNDEF
However, when I connect directly to NHC using the app MQTT Explorer I can see that the ElectricalPower property is being returned correctly and that the ReportInstantUsage flag is getting set to ‘true’ (This is not the case unless the above item is created).
As a work around I’m still creating the item as above to toggle NHC to report live electricity data, and then I’m also creating an MQTT broker which connects to NHC and then another item with a JSONPath profile of $.Params…Properties…ElectricalPower to retrieve the value.
I’m unsure if this is a known issue with the binding, or whether it’s an issue with the milestone build, or indeed I’m doing something wrong somewhere along the way.
I do have a lot of other NHC items (thermostats, lights, dimmers, virtual flags) which are working as expected.
This sounds like a bug. I can’t say what’s going wrong, but it would be helpful to get a trace log. I may be able to see what is happening to the messages.
Here’s the trace (I think this is what you are after, apologies if not). As you can see, we use quite a lot of electricity here!!
2021-04-18 16:00:09.404 [TRACE] [l.nhc2.NikoHomeControlCommunication2] - received topic hobby/control/devices/evt, payload {“Method”:“devices.status”,“Params”:[{“Devices”:[{“Properties”:[{“ElectricalPower”:“4623.000”}],“Uuid”:“6dcef020-2911-424d-b1f5-40f252aec28a”}]}]}
2021-04-18 16:00:09.406 [DEBUG] [rol.internal.protocol.NhcEnergyMeter] - update power channel for 6dcef020-2911-424d-b1f5-40f252aec28a with null
2021-04-18 16:00:09.407 [TRACE] [l.nhc2.NikoHomeControlCommunication2] - received empty energy meter 6dcef020-2911-424d-b1f5-40f252aec28a power reading
2021-05-03 11:08:43.531 [DEBUG] [very.NikoHomeControlDiscoveryService] - discovery service org.openhab.binding.nikohomecontrol.internal.handler.NikoHomeControlBridgeHandler2@61db89
2021-05-03 11:08:43.547 [DEBUG] [andler.NikoHomeControlBridgeHandler2] - initializing NHC II bridge handler
2021-05-03 11:08:43.551 [DEBUG] [l.nhc2.NikoHomeControlCommunication2] - initializing for mqtt connection to CoCo on 10.0.1.7:8884
2021-05-03 11:08:43.552 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - starting connection...
2021-05-03 11:08:43.553 [TRACE] [l.nhc2.NikoHomeControlCommunication2] - Connection state: CONNECTING
2021-05-03 11:08:43.556 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '10.0.1.7' with clientid 10_0_1_71-nikohomecontrol_bridge2_443b00ee3af6
2021-05-03 11:08:43.622 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - error connecting
2021-05-03 11:08:43.623 [DEBUG] [l.nhc2.NikoHomeControlCommunication2] - error in mqtt communication
2021-05-03 11:08:43.624 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - stopping connection...
2021-05-03 11:08:43.622 [DEBUG] [l.nhc2.NikoHomeControlCommunication2] - Connection state: CONNECTING
com.hivemq.client.mqtt.exceptions.ConnectionFailedException: javax.net.ssl.SSLHandshakeException: No subject alternative names matching IP address 10.0.1.7 found
Caused by: javax.net.ssl.SSLHandshakeException: No subject alternative names matching IP address 10.0.1.7 found
at sun.security.ssl.Alert.createSSLException(Alert.java:131) ~[?:?]
at sun.security.ssl.TransportContext.fatal(TransportContext.java:349) ~[?:?]
at sun.security.ssl.TransportContext.fatal(TransportContext.java:292) ~[?:?]
at sun.security.ssl.TransportContext.fatal(TransportContext.java:287) ~[?:?]
at sun.security.ssl.CertificateMessage$T13CertificateConsumer.checkServerCerts(CertificateMessage.java:1356) ~[?:?]
at sun.security.ssl.CertificateMessage$T13CertificateConsumer.onConsumeCertificate(CertificateMessage.java:1231) ~[?:?]
at sun.security.ssl.CertificateMessage$T13CertificateConsumer.consume(CertificateMessage.java:1174) ~[?:?]
at sun.security.ssl.SSLHandshake.consume(SSLHandshake.java:392) ~[?:?]
at sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:443) ~[?:?]
at sun.security.ssl.SSLEngineImpl$DelegatedTask$DelegatedAction.run(SSLEngineImpl.java:1074) ~[?:?]
at sun.security.ssl.SSLEngineImpl$DelegatedTask$DelegatedAction.run(SSLEngineImpl.java:1061) ~[?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at sun.security.ssl.SSLEngineImpl$DelegatedTask.run(SSLEngineImpl.java:1008) ~[?:?]
at io.netty.handler.ssl.SslHandler.runAllDelegatedTasks(SslHandler.java:1528) ~[bundleFile:4.1.63.Final]
at io.netty.handler.ssl.SslHandler.runDelegatedTasks(SslHandler.java:1542) ~[bundleFile:4.1.63.Final]
at io.netty.handler.ssl.SslHandler.unwrap(SslHandler.java:1426) [bundleFile:4.1.63.Final]
at io.netty.handler.ssl.SslHandler.decodeJdkCompatible(SslHandler.java:1253) [bundleFile:4.1.63.Final]
at io.netty.handler.ssl.SslHandler.decode(SslHandler.java:1300) [bundleFile:4.1.63.Final]
at io.netty.handler.codec.ByteToMessageDecoder.decodeRemovalReentryProtection(ByteToMessageDecoder.java:508) [bundleFile:4.1.63.Final]
at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:447) [bundleFile:4.1.63.Final]
at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:276) [bundleFile:4.1.63.Final]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:379) [bundleFile:4.1.63.Final]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:365) [bundleFile:4.1.63.Final]
at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:357) [bundleFile:4.1.63.Final]
at io.netty.channel.DefaultChannelPipeline$HeadContext.channelRead(DefaultChannelPipeline.java:1410) [bundleFile:4.1.63.Final]
at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:919) [bundleFile:4.1.63.Final]
at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:166) [bundleFile:4.1.63.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:719) [bundleFile:4.1.63.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:655) [bundleFile:4.1.63.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:581) [bundleFile:4.1.63.Final]
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:493) [bundleFile:4.1.63.Final]
at io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:989) [bundleFile:4.1.63.Final]
at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) [bundleFile:4.1.63.Final]
at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) [bundleFile:4.1.63.Final]
Caused by: java.security.cert.CertificateException: No subject alternative names matching IP address 10.0.1.7 found
at sun.security.util.HostnameChecker.matchIP(HostnameChecker.java:165) ~[?:?]
at sun.security.util.HostnameChecker.match(HostnameChecker.java:101) ~[?:?]
at sun.security.ssl.X509TrustManagerImpl.checkIdentity(X509TrustManagerImpl.java:455) ~[?:?]
at sun.security.ssl.X509TrustManagerImpl.checkIdentity(X509TrustManagerImpl.java:429) ~[?:?]
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:283) ~[?:?]
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:141) ~[?:?]
at sun.security.ssl.CertificateMessage$T13CertificateConsumer.checkServerCerts(CertificateMessage.java:1334) ~[?:?]
at io.netty.handler.ssl.SslHandler.unwrap(SslHandler.java:1426) ~[bundleFile:4.1.63.Final]
at io.netty.handler.ssl.SslHandler.decodeJdkCompatible(SslHandler.java:1253) ~[bundleFile:4.1.63.Final]
at io.netty.handler.ssl.SslHandler.decode(SslHandler.java:1300) ~[bundleFile:4.1.63.Final]
at io.netty.handler.codec.ByteToMessageDecoder.decodeRemovalReentryProtection(ByteToMessageDecoder.java:508) ~[?:?]
at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:447) ~[?:?]
at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:276) ~[?:?]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:379) ~[bundleFile:4.1.63.Final]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:365) ~[bundleFile:4.1.63.Final]
at io.netty.channel.DefaultChannelPipeline$HeadContext.channelRead(DefaultChannelPipeline.java:1410) ~[bundleFile:4.1.63.Final]
at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:919) ~[?:?]
at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:166) ~[?:?]
at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:719) ~[?:?]
at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:655) ~[?:?]
at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:581) ~[?:?]
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:493) ~[?:?]
at io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:989) ~[?:?]
at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) ~[?:?]
at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) ~[?:?]
at java.lang.Thread.run(Thread.java:829) ~[?:?]
2021-05-03 11:08:43.686 [DEBUG] [l.nhc2.NikoHomeControlCommunication2] - connection lost
2021-05-03 11:08:43.688 [DEBUG] [nal.protocol.nhc2.NhcMqttConnection2] - stopping connection...
Forgive my ignorance, but do you think there is anyway to keep M4 (with it’s fixed electricity monitoring) but rollback the Netty bundle? (As I say, please forgive me, but I don’t actually know what I’m talking about! )
It looks like the issue is not so much with netty, but with the upgrade of the hivemq bundle in the same PR. I have created an issue for it: #2346
It won’t be straightforward to solve this in an M4 install. The more likely workaround would be rolling back to M3 and insert the nikohomecontrol update in there. It may require quite a bit of effort to get it working though. I don’t have a version that was compiled before the hivemq upgrade. I would prefer to wait and see if we get anywhere with the issue resolution.
@Jorggs The fix is now available in the latest snapshot version. As it is a fix to the core, you cannot simply replace the binding. Either switch to the snapshot release, or wait for the next milestone a few weeks from now.
