I have some syncing issues on a RPI2 running Raspbian and Openhab 1.8.0 with the Nikobus binding
I use both Nikobus switches and corresponding Mios switches to have synced states.
When I control my Nikobus lights through Openhab using a Mios or the Openhab GUI, the real Nikobus light does respond (light goes on or off)
However when I use the Nikobus physical buttons, the status is not reflected in any Openhab (IOS app nor web) or Vera app (homewave nor web)
The debug log does not give any errors on Mios nor Nikobus binding.
Am I overlooking something or could there be a bug?
YESTERDAY I’VE TESTED WITH DISABLING THE MIOS SYNC RULES (ONLY USING THE NIKOBUS BINDING AND ITEMS) and the problem was also existing. Physical commands do not get reflected in Openhab.
Below my items and rules to do the syncing:
items
/* nikobus /
Switch LP_garage “Licht Garage” (Lichten) { nikobus=“1D5E:1” }
/ Mios */
//Switch LPgarageStatus “LP_garage Status” (Lichten) {mios=“unit:vera,device:35/service/urn:upnp-org:serviceId:SwitchPower1/Status,command:ON|OFF,in:MAP(miosSwitchIn.map)” }
rule
var java.util.concurrent.locks.ReentrantLock lock = new java.util.concurrent.locks.ReentrantLock()
rule "Link LPgarageStatus to LP_garage"
Item LPgarageStatus changed
lock.lock()
try {
if(LP_garage.state != LPgarageStatus.state && SystemStarting.state == OFF) {
LP_garage.sendCommand(LPgarageStatus.state.toString())
LP_garage.postUpdate(LPgarageStatus.state.toString())
logDebug(“vera”, “Vera switch LPgarageStatus has been synced with Nikobus switch LP_garage”)
} finally{
lock.unlock()
rule "Link LP_garage to LPgarageStatus"
Item LP_garage changed
lock.lock()
try {
LPgarageStatus.sendCommand(LP_garage.state.toString())
LPgarageStatus.postUpdate(LP_garage.state.toString())
logDebug(“vera”, “Nikobus switch LP_garage has been synced with Vera switch LPgarageStatus”)
} finally{
lock.unlock()
