Hard to say without logs … maybe double check connection to Nikobus PC Link …
Solved my ERROR: COMM problem. However the PC-Link says ONLINE the Com-port setting was changed.
I’ve got a PC-Link and a PC-Logic in my Nikobus installation. When I connect my OH3-server to the PC-Logic the PC-Link bridge works like it’s connected to the PC-Link (Works on Logic with Link address).
When I connect a second (Snapshot/Milestone) OH3-server to either the PC-Link or PC-Logic port I get the port ERROR: COMM described above. Is my conclusion right that two OH3-servers can’t bridge to the same address?
Is there someone who has two servers linked to a Nikobus installation? Eg with two PC-Link controllers?
Hi
I’m trying to program Nikobus buttons to change my Nikobus lights, but not by Nikobus, but by openhab. I have no clue of what I’m doing wrong, so… . When I test the rule through the OH interface, it works, but when I press the physical button, It does not.
The push button is online.
Test On
triggers:
- id: "1"
configuration:
itemName: NikobusPushButton1522DE5BP231C5_ButtonEvent
state: ON
previousState: OFF
conditions:
- inputs: {}
configuration:
itemName: light_Eethoek_Centraal
state: OFF
operator: =
type: core.ItemStateCondition
actions:
- inputs: {}
configuration:
command: ON
type: core.ItemCommandAction
Test Off
triggers:
- id: "1"
configuration:
state: OFF
previousState: ON
conditions:
- inputs: {}
configuration:
state: ON
operator: =
actions:
- inputs: {}
configuration:
command: OFF
Hey! Not 100% sure what are you trying to accomplish … Please note Nikobus push button does not have a state (on/off) but can trigger commands, see here for details. Please provide more details in order to provide better feedback …
Hey thanks for the reply. I indeed missed the part where it says the buttons don’t have a state and I have to use the filter trigger. From “Beside receiving a status update (ON) when a physical Nikobus push button is pressed” in the documentation I thought there indeed was an on/off state. My mistake.
Hi @crnjan
Apparently there is no way to message you personally through this forum, but I just wanted to let you know that I’m very grateful for the nikobus-code/addon for openhab. It’s magic to see that I can connect my nikobus via openhab to mqtt to my sonoffs to control my garden lights. And you (and of course the other openhab-crew) made that my installation can do things beyond my imagination.
So thank you. Also for the good pointers on my badly asked questions
If I can ever buy you a coffee, let me know.
For the other readers, sorry for hijacking this thread but I didn’t find another way to say thanks
Thank you and glad you find it useful!
Hi
Since some weeks I have weird behaviour on Nikobus buttons which are only used by openhab and not by nikobus, where I check the channel for button pressed.
This button comes online, no issues whatsoever.
UID: nikobus:push-button:ead36cb534:9F8542
label: Nikobus Push Button 10A87E:3 BP35_A_2
thingTypeUID: nikobus:push-button
configuration:
address: 9F8542
bridgeUID: nikobus:pc-link:ead36cb534
This button came online, but since a while I get HANDLER_CONFIGURATION_PENDING
UID: nikobus:push-button:ead36cb534:1F8542
label: Nikobus Push Button 10A87E:3 BP35_C_2
configuration:
address: 1F8542
channels:
- id: NikobusPushButton10A87E_1keukenbovenaanrechts
channelTypeUID: nikobus:trigger-filter
label: NikobusPushButton10A87E_1keukenbovenaanrechts
description: ""
configuration:
command: PRESSED
Any pointers? The weird thing is that it worked without issues, but since an undefinite while - even after reboot - it does not…
Can you check:
Thx for quick reply. They come indeed online like that. Weird thing is that in the UI the delay is set as 0
but when I look in the code (images for proof :D)
there is no 0.
I added it manually, it works again now, thx for that.
Hey! No problem - yes, I have seen this before and not 100% sure if this is a Nikobus binding issue or serialization/store/restore issue within webui or even core … The delay
is a mandatory property but has a default value of 0 - so you shouldn’t need to specify it, but my guess is that it fails to load since it’s marked as mandatory (although 0 is set as default value) …
<parameter name="delay" type="integer" required="true" min="0" unit="ms">
<label>Delay</label>
<description>Delay in milliseconds before triggered</description>
<default>0</default>
</parameter>
FYI
@crnjan I believe the parameter required should not be set to true when there is a default value. In a review of my nikohomecontrol binding, a reviewer asked me to remove it for that reason.
Thank you, good to know, was not aware of this - to be honest, did not spend much time with it since workaround is quite simple, will do a PR to fix it.
I am running OH 3.1.0 and can not find the “Add Channel” button/link in the push button OH GUI?
Has it been added yet or do we have to add channels to push buttons manually?
are you using file based configs? i guess one cannot mix ui and file based configs so if you define thing in file you need to add channels there too … or add thing in ui and then you should see the button …
OK thx!
